Question about ASUS Transformer Tf300t Tablet
How to exit
How can i exit my tablet asus from boot mode?
    New Friend:
Just tap ur profile and tap the scroll down menu, sign out or shutdown. Or tap power when u slide from the right side.
Posted on May 08, 2014
Asus zen tablet screen is frozen and says select boot mode tried pressing volume and on button nothing how can I fix this?
press volume up and power at exact time asus screen appears. use volume up to make selection and hold volume down to select.
Aug 17, 2017 | ASUS Tablets & eReaders
Asus zenpad10 tablet stuck in fastboot mode
KEEP HOLDING THE POWER BUTTON UNTIL YOUR PHONES SWITCHES OFF OR PULL OUT THE BATTERY DIRECTLY(If Required) to exit the FAST BOOT MODE and then start your phone normally by pressing only the power button.
Also in case you were trying to enter the recovery mode to wipe cache or hard reset then keep holding the power button and volume DOWN button until you get vibration and release the power button and keep holding the volume DOWN button to enter RECOVERY.
Jun 16, 2017 | ASUS Tablets & eReaders
Asus tablet is locked out of wifi
Go into settings, turn off Wi-Fi, shut tablet down and wait a couple of minutes then turn back on. After boot up go back into settings turn Wi-Fi back on and see if you can connect to Wi-Fi. If not then the Wi-Fi part of the tablet is probably defective.
I’m happy to help further over the phone at https://www.6ya.com/expert/david_c087e4b7d13c0163
Feb 24, 2017 | ASUS Tablets & eReaders
I have an old Asus tablet and have forgotten the password. How do I get into my tablet?
You can boot it externally and get the data from it. Them reimage your tablet to clear the password.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gregg_27a4d257e54e7920
Jan 23, 2016 | ASUS Tablets & eReaders
Reset ep121 asus tablet
http://www.technipages.com/how-to-soft-and-hard-reset-asus-eee-pad-transformer
Dec 04, 2015 | ASUS Eee Slate EP121 Touch
Windows dead:how to reinstall it?
Press delete button during start up to enter its hardware configuration mode, set first boot device as CD ROM, second boot device Hard disc, and set all boot devices to none. Select save and exit option, press OK. Reboot the computer. Check whether it works fine or not. If not, O/S should be re-installed, and you can now put the O/S CD in it CD tray and follow the on-screen instructions. Make sure that the licence key [a 25 character key] is with you, otherwise, you can,t go beyond format option. Gopakumar Gopalan Google
May 10, 2014 | Samsung Q1 Tablet PC
My asus transformer tf300 won't turn on
It is possible you got into APX mode (for transferring files with the device not in the OS using NVFlash. Great if you bricked a device). This mode is Hold VOL UP and tap POWER. In this case, you can try to use the Reset Hole on the left side of the Asus TF300 (between the microHDMI and microSD card). Try it for 3-5 seconds. Another thing you could do is hold the power button for 30 seconds, release, hold it for 3 seconds and see if it boots.
The last thing you could do is hold VOL DOWN and POWER for about 12-15 seconds until some small text appears in the top left.
Dec 11, 2012 | ASUS Transformer Tf300t Tablet
Blue screen c0o00021a fatal system error, even in safe mode. cant get the DVD drive to open; it clicks when the latch is depressed, but doesn't open (to try to boot from a repair disk). How do I overcome...
Should be a small hole in DVD drive lid.
Turn off computer and carefully insert a straightened paper clip.
Gently push & the lid should pop out
May 03, 2010 | ASUS R1F Tablet PC
On a seperate tablet PC I accidentally switched to dual clone mode but television, not monitor and now neither tablet nor monitor output works and it stuck in shut down saving mode, how can I restote...
turn the pc off and turn it back on, when it boots back up hit the fn key for lcd/external monitor until it works by turning it off of course i mean hold the power button down for 8 seconds
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Nov 03, 2009 | ASUS R2H Tablet PC
I am trying to Downgrade an ASUS R1F from Vista Pro to XP Pro. How do I get the tablet to boot from the CD
Hi, if you have computer knowledge, the easiest thing to do is to take the laptop sata hard drive out and connect it to your computer with your sata cables and power and boot your computer up and the laptop drive will be a slave drive then. Now you can back it up if you want and then format it.
Now turn your computer off and put the hard drive back in your laptop. Because there in no Operating system the laptop will ask for a boot device. Now you will be able to boot from your xp cd.
I don't know why but I have found most laptops and computers with vista don't like to boot from a cd and over ride the boot options and go directly into vista which makes it hard for people who want to down grade to XP.
Why someone would want Vista beats me.
You can also load up into bios and change your boot options in there. If not already set as first boot device to be you cdrom/dvd you can change it to be. But like I said most of the time with Vista it doesn't matter! Vista will still boot first. But it is worth trying.
Sep 26, 2009 | ASUS R1F Tablet PC
ASUS Transformer Tf300t Tablet Logo
66 people viewed this question
Top ASUS Tablets & eReaders Experts
Alun Cox
k24674
Are you an ASUS Tablet and eReader Expert? Answer questions, earn points and help others
