Question about Minolta DiALTA DI2510F All-In-One Laser Printer
Manual clothes stuck
  • Minolta Master
  • 6,161 Answers
Clothes stuck where?
Posted on Jan 10, 2015
I need a manual for a Sharp 19NV88BK television. The volume is stuck in the stereo mode, cannot lower it manually or with the remote. TV responds to remote except the volume.
Remove wall plug to the television.
Sit down, drink half cup of tea.
Put new batteries in the remote.
Drink other half cup of tea.
Put wall plug back in as all the power internally should be dissipated.
Try remote again.
Remote still not working? Clean buttons with wet cloth and dish liquid, turn remote upside down, wait 5 minutes. Clean buttons with damp clean cloth.
New Remote
http://www.sharpremotes.com/index.cfm?page=4
Manuals are here
Sharp Corporation Sharp Global
Nov 29, 2016 | Sharp Televison & Video
Cloth stuck in between the bottom
Possible that the cloth is stuck on the agitator of the machine due to gaps with the spindle. You need to reverse the motor manually while holding the cloth to come out freely. If there is friction , slowly agitate to allow free movement to the stuck material. If there is play on the spindle and bearing then you need to reset the mechanism,
check this link: bearings
Jan 02, 2013 | Hotpoint Washing Machines
Whirlpool cabrio washer - a piece of clothing is stuck under the agitator - how do I get it out
Take off the cap on the agitator and remove the bolt. The agitator should pull off and you can rescue your clothing item.
Manual and parts list click here.
Hope this helps.
Zeppelinx12
Feb 24, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My janome machine model 2001.doesnot work properly it thread is loose from down side during sewing ,sometimes work properly but some time while sewing it shows same problem i was cleaning with tooth brush...
I think you may have to careful clean everything and check you havn't dropped feed dogs or changed a setting. I don't really know what you mean by the foot getting stuck, but if the feed dogs ( moving part under the cloth) are down than the cloth can't move. Also, the pressure of the foot may be too high; this can also happen accidently while cleaning.
Get a manual ( sewingmanuals.com) and double check everything. Also, check there is no thread in the thread guides as this may have been your original problem. pull a thread towards to needle
Sep 02, 2010 | Janome 4612 Sewing Machine
My dryer drum is stuck. When I open the top, the drum is set so that I cannot get my clothes out. I looked at the directions to push a button in on the inside, and then manually rotate it. I had to...
It sounds like one or both of the bearings have failed. Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will work you through your problem
Aug 12, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Clothes stuck under the agitator
you really have clothes stuck under the "wash plate" it has almost zero clearance and would be very hard to get something stuck under the wash plate.
if you do have something stuck, then remove the 1 1/2 inch cap in the center of the plate, then a 7/16th bolt that holds the plate down. then grab the wash plate and lift up to remove it.
next time check your pockets and dont let this happen again, it could ruin the outertub by cutting a hole thru it and then leaking.
Jan 04, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Fridgidare dryer problem
there is a front glide assembly, depending on model will have 3 teflon/plastic glides attached t o the felt, this may be your grinding and gap issue
Nov 16, 2008 | Dryers
Clothes covered in lint
You need a new timer. Reducing the cycle time will help the lint and not having a timer stuck on wash will help too.
Oct 30, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Clothes stuck in washing machine
Thanks repair man called and problem fixed
Mar 12, 2007 | Hoover AI130 Front Load Washer
Minolta DiALTA DI2510F All-In-One Laser Printer Logo
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
