Question about Frigidaire FAS257S2A WallWindow Air Conditioner
Compresser wont stay running - Frigidaire FAS257S2A WallWindow Air Conditioner
Riding mower wont crank even after a need battery and ignition switch was put on.
if compression is good and has fuel
not running after the wash down
has to be coil or spark related
May 19, 2016 | Cars & Trucks
Wont stay running, starts and only runs for 5 seconds
What kind of car or truck most the time if it starts means you have fuel.air.compression and spark and almost always if it dies freight after it's related to the fuel what kind of engine?
Dec 24, 2015 | Cars & Trucks
2002 jeep liberty backfiring and wont idle
Sound like bad valve ckeck the compression on the engine ,next the
tempature sensor on the motor.Good Luck.
Feb 10, 2013 | 2002 Jeep Liberty
I have a 1992 ford probe 2.2 that wont stay running
try a compression test on the cylnders, If it overheated when the head blew , the rings can go soft with too much heat
Apr 24, 2010 | 1996 Ford Probe
Wont start replaced fuel pump, injectors working, spark is good, replaced computer, getting low compression reading, turns over sometimes but wont stay running
if compression is 100 psi or under you have internal failure of the motor and is why it is acting the way it is. could be head gaskets , valves or piston rings or even a crack somewhere in the compression camber. how much compression do you have on the all?
Dec 13, 2009 | 1998 Ford Contour
Honda motor wont stay running ,carb not getting enough gas to stay running
as it is gravity fed you would need to remove thfuel line from the carby to check that the fuel is geting to that point,if not removanf clean fuel .bowl and filter . if ok. then a carby service is in order ,they are not difficult but you do need compressed air
Oct 25, 2009 | Garden
2000 toyota celica-gets fuel to the fuel rail but wont stay running, will run with gas sprayed in intake
Check the injectore and see if they need replaced. but if not, you probably just need to put some "restor" in in for the compression.
Jul 11, 2009 | 2000 Toyota Celica
New fuel lines, wont stay run, swapt in/out line, wont stay run
Sometimes simply removing the carb and placing it in a carb dip will clean it without tearing it apart, also check or replace the spark plug. Make sure you have compression, good spark, and that fuel is getting to the carb. If that doesnt work, email me and I'll find you a diagram. Jblee1975@yahoo.com
Jul 11, 2009 | Craftsman 25cc Gas Line Trimmer
Engine shows good compression but wont run
if i was you i would take it out,or do a lot of shimming.
Mar 27, 2009 | 1996 kawasaki VN 1500 Vulcan Classic
Frigidaire FAS257S2A WallWindow Air Conditioner Logo
20 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
