Question about RCA "7"" Dual Screen Portable DVD Player"
Says no disc even tho one is in. sounds like its not spinning
Says no disc. sounds like its not spinning
Minidisc will not eject
Try unplugging it and plugging it in the next day. It sounds bizare, but it works for me.
Jun 04, 2014 | Sony MDS-JE440 Mini Disc Player
Apex DVD player says "no disc" when turned on even tho a disk is inserted.
it sounds as though you may need to try cleaning the lens. you can buy a lens cleaner at an electronics store or you can take the top off and do it with a Q-tip and alcohol, but i suggest trying the first opption first.
Aug 14, 2010 | Televison & Video
Pioneer CLD-95 only spins laserdiscs when it feels like it
It sounds like the read head assembly is not resetting back to the starting point so it can start off reading the "A" side of the next disc. Probably turning it off and then on resets it back to the start of the "A" side. You might try flipping the disc manually to the "B" side, let it go and then try another disc to see if it works.
Mar 30, 2010 | Televison & Video
Brown stains on clothes
Sounds as tho there is an excess of fabric softener build up on the inside of the outter tub. Try Filling with Hot water and bleach and let set for an evening and then turn back on and e tcontinue washing thru cycle.
Jan 31, 2010 | GE WHRE5260E Top Load Washer
Unplayable disc? 4 correct discs tried.
try unplugging the unit for a short while....10min +
plug it back in.... it just might work... fingers xed
Dec 05, 2009 | Televison & Video
Whirlpool LSR8233eq top load washer won't spin most of time
Hi, It sounds like your spin basket drive is going bad. Even tho you cleaned the brake, the pads get worn down enough they will not grab. The only other thing I can think of is the bloch that sits on top the basket drive shaft and lockes the inner tub. Sounds like you have done/checked everything else.
Please let me know if I can assist you further.
Vic
Jun 20, 2009 | Whirlpool LBR4121JQ Top Load Washer
Game not loading
Does this happen with every game or just one particular game?
If it's not loading, then its your laser and it would have to be replaced more than likely.
Did anyone bump the the console or move it while it was spinning? These are the main causes for lasers going bad.
Apr 14, 2009 | Sony Playstation 3 (PS3) Console
Psp3002 when the disc inserted, it made a sound
ok soyou psp made a funny sound when you were loading it up. hmmm i would say you might have a problem wit your disc reader. try other games and see if makes the same noise or doesn't make a noise it used to do like the high spinning revolutions the disc spins at. if it isnt moving then you need to get it fixed because your lense reader have probably shititself from things like smoke ashes or watrer or even heat.
Jan 01, 2009 | Computers & Internet
Ps1 games
ps1 game dont work on the ps2 try ps2 games they will work
Oct 09, 2008 | Sony PlayStation 2 Slimline Console
RCA "7"" Dual Screen Portable DVD Player" Logo
Top RCA Car Audio & Video Experts
Colin Stickland
Colin Stickland
Jeffrey Turcotte
Jeffrey Turcotte
 Mikey
Mikey
Are you a RCA Car Audio and Video Expert? Answer questions, earn points and help others
