Question about Krups FME2 Coffee Maker
Display only flashes
Will not start
  • 1,140 Answers
It is in need of repair or service.
Posted on Nov 30, 2015
Flashing indicator light
follow the next steps and fix it. God bless you
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 06, 2013 | Dishwashers
Lcd display flashing in out
Display components such as LCDs have limited age and years of service. Flashing and fading are two symptomps usually associated with dying LCDs. How old is your display/radio?
es
May 30, 2013 | Radio Communications
Flashing start light
see this causes and fix it. God bless you
Drain Pump If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective YOU'LL need to replace it. Drain pumps are not repairable.
Heating Element If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Heating Element Assembly If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Touchpad and Control Panel If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced
Touchpad If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Check Fault Codes If the display lights are flashing and there is an error code in the display window, check the Error Codes guide on our website to determine which component has failed or is failing
Oct 03, 2012 | Dishwashers
E25
hello,
All error codes start with the letter "E". An error code of E11 will have the five indicator lights flash once and the Start indicator light flash once.
Some models of Frigidaire washers come with a digital readout display that informs the operator of the unit's function and any errors.
Error codes indicate that a problem has occurred and should be addressed. Different models of Frigidaire washers may vary in their fault displays.
Some washer models use flashing lights at the unit's start, door lock, wash, rinse, final spin and control indicators to display error codes.
If the five indica
tor lights flash more than nine times, this signals a letter in the error code. The letter "A" stands for 10 flashes, "B" for 11, "C" for 12, "D" for 13, "E" for 14 and "F" for 15 flashes. An error code of EB2 will have the five indicator lights flash or blink 11 times, and the Start indicator light blink twice
hope this help?
thanks.
Oct 23, 2010 | Dishwashers
How do i set timer
How to program Raindrip R673CT
Download R673CT manual at raindrip
Other models
R683CP
R672CT
Raindrip drip water guide
R673CT
Install 2 AAA batteries to power display
Set current time:
Press TIME and hour digit flashes > Use up-down arrows to set 24 hour clock
Press SET to confirm hour
Use up-down arrows to set minute
Press SET to confirm minute
Use up-down arrows to set day of week
Press SET to confirm day
Program review
Timer can set 16 watering schedules
When programming, look at display:
Notice: PROG for programming mode, #1, start time, run time, SU MO WE for days
Press PROG and display appear just like image above
Use arrows to select 1, 2, 3, 4 through 16 different watering schedules
Programming
Start time hour will flash
Once hour flashes, use arrows to select hour
Minutes will flash
Use arrows to select minute
Press SET to confirm minutes
Run time hours will flash
Use arrows to set run time hours duration (0 to 9 hours)
Run time minutes will flash
Use arrows to set run time minutes
Press Set to confirm
Now #2 shows on display this is about which days the timer will water
Decide 1) every other day, 2) every third day, or 3) watering at will
1) To water every other day:
While 2nd is flashing, press SET and SU TU WE FR will appear in display
2) To water every third day:
While 2nd is flashing, press down-arrow
3rd will start flashing and TU WE SA will display
3) To water at will:
While 2nd is flashing, press down-arrow twice
SU will flash
Press down-arrow to go to MO TU WE etc
Press SET when day you want appear on display
To set another watering program
Scroll back up to "programming" on this page
Press arrows to select programming 1 thru 16
Repeat programming sequence
After programming is set, press clock button and current time will show
Oct 07, 2010 | Raindrip R673CT Digital Water Timer
Siemens serie iq 1430 start problems\r\nThe display just flashes and goes dark Machine will not start
siemens serie iq 1430 start problems\r\nThe display just flashes and goes dark Machine will not start
Sep 18, 2010 | Siemens WFXD8400UC Front Load Washer
Honeywell thermostat display has flashing snowflake /ac not working
the flashing snowflake is it telling you its in % min delay if it doesnt stop flashing within 5min it may be a bad tstat. if it goes solid and the unit is still not working its probably not the stat
Jun 13, 2009 | Honeywell Electronic Programmable...
I have a Digital Voice Recorder DS-2....how do I erase an item???
Press the FOLDER button to choose a folder. Press the FF or REW button to
choose the file you want to erase. Press the ERASE button. CANCEL” is flashing.Press the down arrow button to choose the
START”.
START” is flashing. When the up arrow button
is pressed, it will return to the flashing display of Cancel.
Press the MENU/SET button
while “START” flashing.
The display changes to “FILE ERASE!” and erasing will start.
“ERASE DONE” is displayed when the file
is erased. File numbers will be reassigned automatically.
Apr 01, 2009 | Olympus Audio Players & Recorders
Control Display keeps changing numbers
we unplugged the refrigerator for a bit over 1 minute and replugged and problem went away.
Jan 11, 2009 | LG LRFD21855 Stainless Steel French Door...
Krups FME2 Coffee Maker Logo
125 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
