Question about Weslo Cadence G 5.9 Treadmill
Belt slips once you start running belt slips how how do you tighten
Why is my proform 5.0 crosstrainer is slipping
if your walking belt is slipping it has loosened up. there are two adjustment bolts on the end of the treadmill. one on either side. these are allen heads. tighten clockwise to remove the slack. first start with treadmill running at 2 mph. tighten both one full turn. let belt adjust. check the centering of the belt. whichever side it is closer to tighten that side about a half turn. let belt adjust after each adjustment for a min.once belt is centered and if it still slips tighten both bolt evenly
Aug 30, 2014 | Exercise & Fitness
Tip
When the walking belt is slipping during use.
This is caused by one of three problems. First and most likely, the walking belt is loose. To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns. If it takes more than 2 turns then something else is the problem. The second problem that it could be is the drive belt might be loose. To tighten the drive belt, start by removing the front cover. loosen the bolts around the motor then tighten the drive belt by tightening the motor adjuster bolt. Once the drive belt is tight, tighten the motor back down. The third problem that it could be is the walking belt could be worn and need to be replaced. Let me know if you have any questions.
on May 01, 2010 | Exercise & Fitness
The belt is slipping
Apr 29, 2010 | Dmm Vision Fitness T9500 Treadmill
Belt is slipping
Apr 03, 2010 | Cadence Exercise & Fitness
Belt is slipping
Mar 29, 2010 | RTO Image 15.0R Treadmill Walking Belt
The belt is slipping and making a squealing sound
May 14, 2009 | Proform Crosswalk 500 Treadmill
Belt is slipping on healthrider treadmill
Apr 30, 2009 | Icon Exercise & Fitness
Belt is slipping and catching
Apr 09, 2009 | Exercise & Fitness
Slipping mat
Mar 26, 2009 | Exercise & Fitness
Belt slipping on treadmill
Jan 06, 2009 | Exercise & Fitness
Weslo Cadence G 5.9 Treadmill Logo
Top Weslo Exercise & Fitness Experts
Electro Med Services...
Matt Olenzek
Matt Olenzek
Shehu Pro
Shehu Pro
Are you a Weslo Exercise and Fitnes Expert? Answer questions, earn points and help others
