Question about Dryers
My GE DHDSR46EE1WW Dryers heating coil won't shut off...ever!
The heating coil stays on even when the cycle is over. The only way to turn the the heat off is by unplugging the dryer. I read that it might be the thermal fuse, but I don't see it in the schematic. Is it one of these below?
Thermo Hi Limit Right
Safety Thermo Left
Thanks for your help!
  • Mark Jan 15, 2012
    I experienced a simliar problem, but my dryer was heating to max temp even in "fluff mode w/no heat" selected. What I found was the outer heating element had an insulator that had fallen out allowing the element to short to chassis.
    https://www.geapplianceparts.com/GEAppli...
    Suggested replacement part: Heater Assembly P/N WE11M23 on GE's web site list $175.25
  • Mark Jan 15, 2012
    Dryer schematic can be found inside the control panel.
    Please take note to remove all electrical power by unplugging the dryer from the AC outlet before servicing this device.
  • Dryers Master
  • 3,361 Answers
The start switch on the motor has failed.Replace the motor. One leg of the 220v power comes through the motor start switch. The other leg from the timer through the thermostats. Open the dryer to access the motor. Take a VOM set for continuity. Unplug the dryer. Unplug the 2 large red wires on the motor. Put the VOM leads on the 2 contacts where the red wires were. If you read continuity the motor start switch is bad.
Posted on Jun 14, 2009
  • 82 Answers
I think your heating coil may have broken loose or sagged down so that it may be shorting itself against the shroud. The thermal fuse would not allow the dryer to heat at all, and a hi limit error would cause the thermal fuse to blow.
Coils lights up but no heat goes up to drum
if your heater coil is working
dryers have a cool down cycle built in
the coil heats shuts down
and drum rotates till end of cycle
Oct 13, 2016 | Dryers
Model gtdp180ed2ww. What causes it to stop mid-cycle?
Dryer runs then shuts down wont start up for an hour:
Bad motor windings
IS IT GAS OR ELECTRIC?
Gas Dryer no heat: or shuts down soon after heating CHECK:
Thermal Fuse
If the air flow in the dryer is restricted, the temperature in the heating chamber can get hot enough to blow the thermal fuse. If the fuse blows, it cuts power to the coils that control the gas valve. The fuse is usually mounted to the exhaust duct just inside the back panel. You can check its continuity with an ohmmeter. If, after disconnecting the fuse, you get any reading other than 0 when you touch the leads of the meter to its terminals, it has blown. There's no way to restore it -- you'll have to install a replacement.
Igniter and Gas Valve Coils
TEST with a multi meter: The igniter is an electric conductor that works like the element in an electric heater, glowing hot enough to ignite gas when you turn on the dryer. This conductor can burn out, and when it does, it may glow, but it won't get hot enough to ignite the gas. At times it may give a reading of continuity yet fail mechanically and not get hot enough to ignite flame though it gets hot and glows and even may show Ohms or continuity ( close circuit) ?
Occasionally, the Gas safety valve and the electric coils that control the gas valve are defective -- they can wear out when the dryer gets old. When this happens, the igniter glows, but gas never enters the heating chamber or does not stay consistant.
Performing a continuity test on either part will help you determine whether or not you need to replace it. But the coils should also be tested for amount of resistance as well as Ohms. As they may be showing ohms yet not putting out enough resistance to keep proper gas pressure flowing. Most coils should show at least 1300 ohms ( GIVE OR TAKE 150 OHMS). Anything significantly less Thus u get an ignition but then it soon goes back out. The flame does not stay lit.
Air Flow and Heat
The motor that drives the tumbler also drives a fan that circulates air through the heating chamber and the tumbler and expels it through the vent. If the air can't circulate, perhaps because of lint blockage, the heating chamber overheats, which prompts the cycling thermostat to turn off the gas. The thermostat resets when the chamber cools, but the chamber heats up quickly and the thermostat again shuts off the gas. The result is that the temperature in the tumbler doesn't stay hot, and your clothes take longer to dry, if they get dry at all.
Warning
There's a big difference between a dryer that doesn't heat up at all and one that just doesn't get hot enough to dry your clothes. In the first instance, the problem is usually a defective part, and things should be back to normal after you replace it. In the second instance, the problem is caused by restricted air flow, and you need to clear the lint filter and vents and take steps to prevent lint build-up. If you don't, you'll use more energy for drying than you need and the dryer may continue to malfunction. Worse, you may have a dryer fire.
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!! SO MY ADIVE IS FREE
Dryer Overheats and or Dryer Gets too Hot
Apr 22, 2016 | GE Dryers
How many cubic feet are in GE electric dryer model DHDSR46EE1WW?
Features
  • 7.0 cu. ft. super capacity
    Handles large-size items and family-size loads
  • Auto Dry
    Uses thermostats to monitor air temperature and reduce fabric wear
  • Dura Drum interior
    Provides long-lasting dependability
  • Four heat selections
    Provide the right temperature for the right drying results
  • Interior dryer light
    Lets you see everything inside for easy loading and unloading
Sep 13, 2015 | GE Dryers
How to replace a heating element on a Kenmore Elite Oasis ST dryer
Sounds like you need to replace the timer one the dryer not the element but to make sure I would do a little trouble shooting to rule out the element or heating coil turn on dryer cycle like normal for about 30 seconds then open the door to feel for heat if you do feel heat its your cycle/timer knob if you don't feel heat then it's the coil or element witch are the same also first always check your lint trap and ducts going outside the dryer make sure you have proper airflow through ducts vents. clogged vents ducts ect. Cause over heating of element coil causing a safety fuse to shut down heating coil/element but will not stop cycle also moisture censors detect moisture causing cycle to continue on hope this helps.
Sep 04, 2014 | Kenmore Elite Oasis 6808 Electric Dryer
Ge dryer dcvh515efoww runs on air dry, but when set on any heating cycle, it runs for a few minutes and then it turns off on 00
it is over heating you might have unplugged a wire to the thermostat when you had it apart or the thermostat has went out.
Mar 21, 2014 | GE Dryers
GE Profile dishwasher heating element will not shut off
Sounds like the timer assembly must have stuck on the dry cycle. I'd call a tech before you have a fire.
Aug 08, 2012 | Bosch Dishwashers
Heat turns off while clothes still wet
change the gas coils on the gas valve by removing the 2 screws holding the bracket for the coils,remove the wire harnesses to each coil,dont worry one coil has 2 wires the other has 3 so quite hard to reverse
Jun 16, 2012 | Kenmore HE5
DHDSr46ee1ww has new heating element and switch but will not start.
Have you checked the motor kill switch? Its located by the motor.When the belt comes off the idler pulley actuates this killing power to the machine. Sometimes the switch goes bad over time and needs to be changed. The part number is wd21x10261 and runs around $12
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 18, 2012 | Dryers
Auto dry cycle will not cut off. It stays on even
yes it has or maybe heat senson the side of the heating coil
Oct 23, 2009 | General Electric DHDSR46EGWW Dryer
Electric dryer heat coil off mid cycle
You have 3 thermostats. By the description of the problem it sounds like it needs a new high limit thermostat. All 3 thermostats and the heating coil can be checked with an ohm meter. Also check the ground on the heating coil. It could be grounding it's self out.
Jan 16, 2009 | Kenmore 62602 Electric Dryer
Dryers Logo
181 people viewed this question
Top Dryers Experts
Marvin
Marvin
