Question about Apple iPad Tablets & eReaders
GPURestart 101943.ips.synced came up in my diagnostic and usage data what does this mean
Just would like to know what this is
I have had Wi Fi on my Kindle Fire and now it will not connect and keeps asking for an IP address
See if this article helps you.
http://classroom.synonym.com/ip-address-kindle-fire-15120.html
Jul 12, 2015 | Amazon Kindle Fire HDX 7
I want to sync my phone and tablet
All you have to do is add the accounts, set up and sign into all your accounts on your phone and tablet. Once you have done so, stay signed in and go to settings and set up your sync options. If you have several google accounts, make your you add them in as well for sync. Especially calendar and email. Best sync setting is every 15 minutes to 30 minutes depending on need or usage. I hope this helps.
Mar 02, 2015 | Nextbook Premium 8 Se Android
How do I connect to wi-fi?
To start you need to check you are entering the right password! The password is the one for the WiFi! Is it written on a card or on the router, it will be case sensitive!
Dec 27, 2014 | Amazon Kindle Wireless Reading Device
Find usage for iPad
settings, general, usage,
Oct 15, 2014 | Tablets & eReaders
How come sometimes my screen works real slow, or not at all. but when I restart it the screen works gust fine,
You might have too many apps or you might have too many apps that are active in the background that are slowing your tablet down. Uninstall unused apps or turn them off through settings. Apps always sync in the background, even when you don't use them. When too many apps are running at the same time, they drag down the wifi speed. Go to Settings>Wireless and Networks> Data Usage, view all the apps that are actively syncing. Also, in Settings>Device>Battery, you'll see which apps are actively draining your battery (if this is also an issue). You might be surprised which apps are either draining your battery or always syncing.
Sep 19, 2014 | Samsung Galaxy Tab 10.1 Wifi - Tablet -...
How to delete apps
there are 2 different ways to delete an App on iPhone/iPad:
1) - Simply tap and hold on any icon for about 2 seconds - see them to start to wiggle and tap the X button in the left corner. that's it.
2) - For devices running iOS 5 and later, there is also another way to do this is hidden in the Settings app, in the General tab, under: usage.
- you can manage the apps on your iOS device. Once there, you'll notice (after a certain delay if you have a lot of apps) that your on-board apps are listed in descending size order. That means: the apps that take up a lot of space will be listed first.
Tap on any app and you'll get even more info, including the version, the size of the app and the size of the Documents & Data. Just below that, you'll have a Delete App button in red. At the very bottom, you'll see how much space is available on the device itself.
Deleting apps that take up too much space is helpful when you're trying to install new apps, You may even notice apps that have a lot of storage attached to them that you weren't even aware of before like internet radio apps that sync songs to your device to play during the time you're not connected to the internet.
delete-apps-b0fxfox1xpqm1xswiisyf0vv-3-0_0.jpg delete-apps-b0fxfox1xpqm1xswiisyf0vv-3-2_0.jpg delete-apps-b0fxfox1xpqm1xswiisyf0vv-3-5_0.jpg
Mar 04, 2014 | Tablets & eReaders
My ipad2 is in disabled mode, how can I get back into it?
means too many wrong codes
plug in pc and use itunes to restore
Oct 17, 2013 | Apple iPad 2 WiFi 3G Tablet 32 GB 97 IPS...
How to delete photos from the Ipad
If to have the iPad before the camera was added, you have the original iPad. If you synced the photos from your computer, you have to delete the photos by syncing with iTunes again, but you have to "uncheck" the albums or folders that you want to remove.
1.Connect the iPad to the computer and launch iTunes.
2.Click on the iPad name on the left side under devices.
3.Click on the Photos Tab on the right.
4.Uncheck all of the albums or folders that you want to delete from the iPad under the Sync Photos from heading.
5.If you want to delete all of the photos - uncheck the Sync Photos From heading
6.Click on Apply in the lower right corner of iTunes
Done.
If it can't work, you can refer to the article about Delete photos from iPad.
Good Luck!
Jun 25, 2012 | Apple iPad (16 GB) WiFi Tablet PC
Tunesync - Get IP for computer - failed
Suggest you contact Telecom company for help. In my mind, when wifi was connected, you can surf Internet right away.
Android 4.0 Tablet PC
Jan 20, 2012 | Samsung Galaxy Tab Tablet PC
Tablets & eReaders Logo
176 people viewed this question
Top Apple Tablets & eReaders Experts
Virgil Wolter
Level 1 Expert
Aaron Galvan
Level 1 Expert
John mullen
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
