Question about Dehumidifiers
No power Logik L8DHW10 - no powerwhen plugged in
Logic L8DHW10 dehumidifier manual
its off balance you need a new bolt that holds the fan blades or new blades
Dec 13, 2015 | Dehumidifiers
LOGIK L20DHW12 dehumidifier won't switch on.
Hi Lynn:
Is it possible that the relative humidity is now lower to the setting switch is not within the ON limit?
Oct 24, 2015 | Dehumidifiers
No lights on controls but power at theplug willnot start ?
? power at the plug, so power at the socket, but not in unit. check unit fuse in plug, check for fuses on unit, usually at back near to power inlet
Aug 13, 2014 | LG LD301EL Dehumidifier
Kul dehumidifier error code as unplug and plug back in still has the error code.
"For the above error codes, Power the unit off, and then unplug the unit for 15 minutes. Plug in and power on. If the issue persists, please contact customer service."
https://edgestar.zendesk.com/hc/en-us/articles/201000315-My-dehumidifier-is-displaying-an-error-code-What-does-it-mean-
Apr 28, 2013 | KUL 65 Pint Dehumidifier
Demudifier worked great, all a sudden it just stopped. No power. Now it won't start up. What should I try?
First, check the outlet that it's plugged into, to make sure that there's still power to the outlet. If there isn't, then the circuit breaker for that outlet has been tripped, in your home's circuit breaker panel. Leave the dehumidifier unplugged and reset the circuit breaker. If it trips again, without the dehumidifier unplugged, then the outlet is at fault. Perhaps there's a loose wire connection or the interior of the outlet is cracked.
If it didn't trip without the dehumidifier plugged in, plug the unit it in,. But, before you do, make sure the dehumidifier's Master ON/OFF Switch is OFF. Once it's plugged in, turn the Master ON/OFF Switch to ON and set your controls. If it runs now, GREAT! If it trips the circuit breaker again, there's either a short in the power cord or an internal electrical short. Which will require extensive troubleshooting to find.
Hope this helps you solve the problem. Please let me know. Thanks.
May 05, 2011 | Fedders A7DH45B2A Dehumidifier
My dehumidifier seems to work fine than after about 5 mins. the fan slows down and there is an electrical draw of power for only about 2 secs.then the fan picks up speed till it gets to normal running...
Very interesting. Try plugging the unit into another outlet. One that's not on that same circuit. It may be, that there's another power draw on the circuit, the unit is currently plugged into.
Please let me know what happens. Thanks.
Apr 27, 2011 | Kenmore 54701 Dehumidifier
THERE IS NO POWER OR ANYTHING WHEN I PLUG THE UNIT IN
check outlet
remove cover and check fuse on power supply board
Dec 25, 2009 | Maytag M7DH65B2A Dehumidifier
I have an Airforce BQDD122FW Dessicant Dehumidifier. When I bought it last year it worked OK. I have started using it again this year and although the motor appears to run normally it no longer collects...
Hi There, you have faulty heater inside. They are all the same Delonghi, meaco, Logik, ecoair .Airforce
I have done 100s now. If you good you can just twist the wire in the heater and will go again without any problems.
Its just basic steel wire twisted like a spring.
anyon eneeds help sam on 07590 057545
Oct 24, 2009 | Dehumidifiers
No power
check the plug on the unit could be bad or bad cord
Jun 20, 2009 | Comfort-Aire BHD-301 Dehumidifier
No lights on control panel. Plug is powered.
Independent of the bucket switch, the control panel should light when the unit is plugged into a powered receptacle and the on/off switch is depressed. The problem is likely the 12 amp. fuse located inside of the unit.
Sep 19, 2006 | Haier HDN655E Dehumidifier
Dehumidifiers Logo
69 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
