Question about Samsung UN46ES6100 46 Inch 1080p Smart TV LED LCD HDTV
Remote Displays B T Error
B T Error
When i try and use the remote start, it doesnt work and my 2way displays the message "remote start error"
The parking lights will also flash a number of times to inform you of the error. The most common causes of the error are neutral safety shutdown (7 flashes). This is the toggle switch under the dash. Locate said switch and toggle it to the on position. Six flashes is the hood pin switch. Locate the switch under the hood and make the necessary adjustment so the pin makes contact with the hood when the hood is closed.
Jan 18, 2011 | 991 Responder LC3 SST Security/Remote...
We keep getting an error code 344* when we are trying to transmit a fax. What can we do to fix this?
Error 344 means :-
The remote machine has failed to respond to a fax command from the product because the connection is interrupted.
The remote user has pressed the Stop button while the remote machine was receiving.
Under rare conditions, incompatibility between the two machines can cause the remote machine to simply abandon the call.
Solutions :-
  1. Attempt to send the fax again when telephone-line conditions have improved.
  2. If the fax session was using error correction, disable ECM.
To disable ECM Press :-
  1. Press Setup .
  2. Press the Down arrow (c00326489.gif ) repeatedly until Advanced Fax Setup displays.
  3. Press OK .
  4. Press the Down arrow (c00326489.gif ) until Error Correction Mode displays.
  5. Press OK .
  6. Press the Right arrow (> ) until either OFF or ON displays.
  7. Press OK .
  8. Send another fax to verify that the ECM is enabled or disabled.
Check the Phone Cable connected with the printer.
Make sure the Cable should be connected to line 1 port at the back of the printer and it should be going directly from the printer to the wall jack and not to the Serj protector.
Try to print a fax test page.
  1. On the control panel of the product, press the Setup button (c01361401.gif ).
  2. Press the Right Arrow button (c01185072.jpg ) to select Tools , and then press OK .
  3. Press the Right Arrow button (c01185072.jpg ) to select Run Fax Test , and then press OK . The product displays the test results on the control panel display and prints the Fax Test Report.
Now Do this :-
  1. Send a one page black and white text fax to 1-888-hpfaxme (1-888-473-2963).
  2. When your fax is received by the HP Test Fax Service, we will generate a return fax to you within five minutes confirming that we received your fax. This verifies that you can both send and receive a fax with your fax machine.
If you do not receive a return fax within 5-7 minutes, there may be a problem with the setup of your fax machine. Consult the user manual that came with the product for proper setup and configuration. Try the above steps and let me know if it works for you.
May 10, 2010 | HP OfficeJet 7310 All-In-One InkJet...
My logitech H628 Harmony remote displays System Error a message
Hi!
Unfortunately, system error one is apparently a hardware issue. It means something about the memory being lost in your Harmony Remote. I had to get a replacement Harmony Remote from Logitech but you would have to see if you are still in your warranty period!!!
I hope you are so you can get a replacement!!! =)
-Kennedy
Nov 28, 2009 | Logitech Harmony 880 LCD Remote Control
The unit displays the error message "System Error 1" and "1. Disconnect form USB 2. Remove and re-insert batteries". I've done that and can't get error message to go away. The remote seems frozen.
Hey!
I had this same issue and when I contacted Logitech, they told me it was a memory failure and I needed a replacement harmony remote. I was still under warranty so I got a replacement.
I would advise you contact Logitech to see if you are still in your warranty period so you can get a replacement!
-Kennedy
Oct 29, 2009 | Logitech Harmony 676 LCD Remote Control
Remote control unit displays error code 1250
Type " Leica 1000 Remote control user manual " into your computer search engine. It will bring up sites to go to get manual.
Aug 11, 2009 | Leica Measuring Tools & Sensors
Harmony 659 erroe measage
Call Harmony support. I have the same thing with Harmony 670 and they said it is a hardware error. No fix that I have been able to find. If it is under warranty they will replace it. If not, I don't know what it would cost to repair.
May 21, 2008 | Logitech Harmony 659 LCD Remote Control
VCR Error
If u dont have a remote for these, it is just the programming setup, i have same prob, but because I dont have a remote I cant get past it
Apr 26, 2008 | Televison & Video
Button Problems
What is the model# for your remote? It's hard to trouble shoot the error with out checking the information on the correct remote. Let me know so we can check into it further for yah!
Sep 20, 2007 | Samsung SAM1100 LCD Remote Control
Samsung UN46ES6100 46 Inch 1080p Smart TV LED LCD HDTV Logo
11 people viewed this question
Jerry Greenberg
Jerry Greenberg
