Question about Raymarine Boating
Fitting new wire to st 40 rotorvector
Unit requires longer wire
    Sergeant:
  • 415 Answers
Look on line for aftermarket resellers. I have seen Raymarine wiring on Ebay.
Posted on Nov 25, 2014
Postal code for 40 Boteler St.Ottawa Ontario
There are multiple units at this address. The postal code for unit 101 is:
101-40 BOTELER ST
OTTAWA ON K1N 9C8
Oct 10, 2014 | Computers & Internet
Can I use the existing 40 amp double pole breaker?
Rule of live by: Each unit must have its own breaker. Cooktop needs 30 amps and a double oven needs 40 amps. Never combine the unit as the amps flow if too high can cause the wires to melt. I hope this helps. Be safe!
Sep 13, 2012 | Thermador Ovens
When i key the **** it squeals
open mic and check for any lose or damaged wire check all solder joints and make sure no wires are shortening out this could be you problem hope this helps
Dec 25, 2010 | Cobra 29 WX NW ST 40-Channels Base CB...
1 or 2 circuits to create 2 phase?
How to explain this? your new drop in unit will require a 220v circuit capable of a specified amount of amps. Typically 40, 50 or 60. Should be noted in the manual and on the unit itself. If your original oven and cooktop were electric, then each one was probably hooked up to a 220v circuit. The problem is figuring out how many amps were supplied for each. The simplest way is the go to the panel and find the breaker for the old oven and cooktop and read the numbers (or amps) on the on/off switch. If either breaker has a number the same or greater then the drop in unit says it requires, then your all set. If the drop in unit says it requires 52amps and one of the breakers says 60 on it, your fine. If the drop in unit says it requires 44amps and the breakers are 30 or 40, then you got a problem. Usually a breaker is installed that is the maximum amps allowed for the size (thickness) of the wire connected to it. You CANNOT connected a 50a breaker to wire only rated for 40a. Note the size difference of wire connected to a 20a breaker with wire connected to 40a breaker. If the drop in unit requires more amps then the original units used, then a larger wire will need to be ran from the panel to the drop in unit (Not cheap). Now if the original oven used a 30a and the original cooktop used a 30a, then its possible ( 80% of electricians wouldn't do it because of liability problems) to use both wires together to create 60amps, but both wires (actually a total of 6 wires, 2-120v wires and 1 ground wire from each outlet) would need to be in the same outlet box for the drop in unit connection.. I could (and probably should) try to explain more, but I'de probably just confuse you more. GOOD LUCK!
Nov 28, 2009 | GE Profile JT952 Electric Double Oven
Our water heater is still working after 32 years. Model 22-40-2
not a record, I actually just did a chang out in Annapolis Maryland the had just the 2 wires running into the unit. you know the way houses used to be run back in the 40's just wires no casings, they screwed right to the back of the water heat to 2 screws ans wing nuts, it was a rheem electric
Jun 06, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
I can hear my buddys talking to me on my cb radio but once i try and talk to them it just sqweeks
Usually a squeal is feedback from a very high SWR or a mic wiring issue. Have the SWR tested and try another mic. Make sure it has the proper wiring. Just because a 4 pin mic fits in the jack doesnt mean it has the same wiring configuration. Also if you run an amp dont wire the amp and radio to the same location. That can creat a ground loop and cause squeal, but not always.
Mar 30, 2009 | Cobra 29 WX NW ST 40-Channels Base CB...
New battery goes flat in single day
check for short circuits. it can be stripped wire that makes contact with the bike chassis. This can drain the battery. Also, Charging circuit may be dead (alternator and regulator).
Mar 14, 2009 | 2000 Triumph Sprint ST
Cb radio installation
You can Go with what you have
PlEASE RATE My ANSWER
Jan 16, 2009 | Cobra 18 WX ST II 40-Channels Base CB...
1999 Audi A4 Rear Speakers
The large block is a factory amplifier - in your car (as was in mine) you had a partially-amplified system. The front speakers were driven at speaker level from the head unit, but the rears were fed a line-level signal from the head unit to the amp, which then boosted to speaker level. The harness then sent the speaker level signal to each rear speaker.
What you can do is fit your new head unit. The fronts will interface perfectly with no issues. For the rear, run new wires from the adapter harness at the back of your head unit, back to the new rear speakers, and connect them directly. Then everything will work as it should.
Dec 17, 2008 | Alpine DDW-F30A Car Speaker
Boating Logo
48 people viewed this question
Top Raymarine Boating Experts
Steve
Steve
David Burbee
David Burbee
Are you a Raymarine Boating Expert? Answer questions, earn points and help others
