Question about GE Refrigerators
Gsc3pgxcfss warm fridge, freezer working fine
Both lights in the fridge stop working and it gets warm. the freezer is still frozen and working good. the fridge fan is still running.
    Novelist:
    Scholar:
  • 166 Answers
It could be the servo on the diverter door, but it's most likely to be the main control board. Sorry.
Posted on May 26, 2014
eagle338
  • 4889 Answers
SOURCE: Zanussi fridge freezer - fridge not working
The defrost cycle is not happening like it should, that's what causes the block of ice (and poor air flow). If you have all that defrosted look at the defrost bi-metal, it usually is a small round disk with a couple wires coming out of it and it's clipped on the coils. When it's cold enough, it passes electricity to the heat elements, when it gets hot enough it "opens" and kills power to the heat elements. If that is bad (swollen cracked or bloated) and not passing electricity to the elements that's the problem. Another item would be the defrost timer itself, if it doesn't work (no clock motor turning) then it will never go into defrost. And the last and usually least expected failure would be the heat element themselves not working
Posted on Oct 09, 2007
eagle338
  • 4889 Answers
SOURCE: kenmore 50222000 help me please
I can offer a suggestion. It sounds like you have a plugged defrost drain line. This is where the water goes to in the bottom of your freezer when it goes through the defrost (removal of ice from the freezer coil) cycle. It sounds like that hole is plugged and now the water/ice has now frozen in the vent that lets air circulate down into your refrigerator compartment. What I usually do in this case is to unplug the refrigerator, empty out the freezer compartment. Usually I also end up either pulling off the back panel or the bottom panel (in the freezer compartment) Looking for that defrost drain hole and thawing it out with a heat gun (be careful of melting plastic) or actually I use a hair dryer. I can sometimes do this also by pouring small amounts of HOT tap water onto it and then sopping/absorbing it away with a sponge or dishcloth. I repeat this until I get the water to go down the drain tube
Posted on Oct 19, 2007
  • 686 Answers
SOURCE: fridge is warm even when i adjust temp. control.freezer is good.
if your fridge has 2 set of dials one numbers and the other letters than you need to adjust the dial that has letters on it. If the fan in your freezer is not blowing, then it won't force the cold air from the freezer to the fridge. Make sure fan blows then adjust the letter knob.
Posted on Feb 17, 2009
jumptrout51
  • 3361 Answers
SOURCE: Whirpool fridge is warm, freezer is working
Check the back wall of the freezer compartment for ice buildup. Sounds like you have a defrost issue.
Posted on Feb 22, 2009
GodBlessU
  • 3513 Answers
SOURCE: GE side by side freezer
Hi
First use a multi-meter to test the compressor. For that you have to unplug the refrigerator and remove the start relay off of the side of the compressor. Go to the single pin on the compressor and check to one of the pins that are side by side on the compressor. The run winding will read 1-5 ohms resistance. Then stay on the single pin and go to the other pin. The start winding will read 3-11 ohms resistance. If your readings are out of these ranges, then you have a bad compressor. If they are within these ranges, then you have a bad relay overload.
However there are various reasons to this no cooling issue. Please check this helpful links to get an in-depth idea about why the refrigerator stopped cooling. It will help you troubleshoot your issue:-
http://www.appliance-repair-it.com/refrigerator-not-cooling.html
http://www.appliancestuff.com/refrigerator.html
http://www.acmehowto.com/howto/appliance/refrigerator/diagrefrigerator.php
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Jul 31, 2011
Gsc3pgxcfss warm fridge, freezer working fine, lights off in fridge
James, not sure I understand your message when you say both lights go off, but later say lights begin working. Do you mean they go off when you push the buttons at the door? And when you say no cold air comes from the freezer, is the freezer door closed? See if air begins flowing with freezer door open. If so it would indicate the return air path from the refrigerator to freezer is blocked.....damper staying closed or evaporator coil frozen up. The return air path has to be open to allow the freezer to keep sending out cold air to refrigerator when freezer door is closed. You might thoroughly defrost to make sure coil is not frozen.
If the door button for the refrigerator light is bad it can signal that the door is open all the time, so the freezer will never send cold air to the refrigerator. And that will be good news. Door switches are cheap. If you don't have a volt meter and know how to check switch, just remove the door switch from the refrigerator, leaving wires dangling, and close the door with a thermometer inside to see if it begins cooling (or just wait a while) I had that problem a year ago and was happy to find a bad door switch. More often it's a frozen coil, and that can be more expensive to fix. Sometimes you can discover a bad switch by pushing in the door button and the light stays on, but it doesn't sound like your situation.....sounds more like a frozen coil. If so, maybe all this extra information will help someone else.
Mar 23, 2014 | GE Profile PSW26P Stainless Steel Side by...
Msd3756aew fridge won't stay warm, freezer cold but not keeping frozen. Cioils not frozen, fan working
the ptc overload/relay on the compressor is bad and not starting the compressor,remove back cover unplug the ptc off the compressor and replace it with a new exact replacement part
Feb 01, 2013 | Refrigerators
Fridge is not becoming cool, fridge is running
Hi, I once had this problem. My freezer and refrigerator were both warm, but I could still hear it running. When the repair guy came out he immediately checked the back interior of the freezer (had to remove a panel) and it was entirely frozen solid with ice. He said the defroster had stopped working, which caused the coils to all freeze. It took him about an hour to get all of the ice off. He replaced the defroster. Total cost was around $250.00. Works fine now.
Jul 19, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
My freezer alarm won't stop beeping or blinking. Freezer is warming up. Help
If this is a refigerator / freezer and the fridge is fine, then most likely the freezer coils are frozen up and the fan can't blow the air through them.
If that is the problem, you will need to defrost them.
Jun 17, 2010 | Refrigerators
American fridge/freezer - fridge stopped cooling, freezer side ok
Have you pulled out the refrigerator and cleaned or used a vacum cleaner to get out the dirt and dust off the back of the coils, or if the coils are underneath, you need to get an inexpensive appliance brush for fridge, and clean the coils under the fridge, pull off the panel on the front bottom of the fridge, get a flash light and look to see if the coils are covered in dust....may just need to vacum and use appliance brush underneath...this should be done at least one a year, you will notice your fridge running much better and cooling back to normal.......hope this helps......
Jan 05, 2010 | Refrigerators
Top half fridge not cold freezer department fine
I had the same problem; the top fridge compartment was warming up to 14C while the freezer compartment was starting to defrost (frozen stuff was starting to become soft. I took the rear wall off the freezer compartment and found it all iced up. I defrosted it with a blower heater then powered it back up. It all worked fine for a month when the same thing happened. I figured that the defrost cycle wasn't working. I located the defrost timer on the rear right-side of the fridge. I rotated it several times and found that the fridge was turning on and off. I rotated it until the fridge turned off. I waited 5 minutes then stuck my head into the freezer compartment and felt the rear wall at the bottom where he drain is; it felt warm so I guessed the defrost heater element was ok. I ordered a defrost timer and installed it. I haven't had a problem since.
Nov 09, 2008 | Westinghouse Refrigerators
Kenmore 50222000 help me please
post your email i will send you the manual but souds like you have a defrost problem check the back wall of the freezer for a thick frost build up
Aug 20, 2008 | Refrigerators
KGU 34641 GB TOP REFRIGERATOR
Hi,I believe you may have a blockage in the intake from the freezer to the fridge as cold air is blown up from the freezer to make the fridge coldhope this helps,mike,
Aug 10, 2008 | Bosch KGU34641 Bottom Freezer Refrigerator
Refrigerators Logo
57 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
