Question about Toyota 2010-2013 Prius Steering Wheel Cover Euro-Perf 2 Color, Size 14 1/8 x 4 1/8
How to remove steering wheel
Heelp
    Sergeant:
  • 243 Answers
I would not attempt to pull a newer car steering wheel, with all of the electronics and the airbag. Please if you atempt to do this, disconnect the battery. Is there a reason you want to remove the steering wheel?
Posted on Jan 27, 2015
How do i remove a freelander steering wheel
Ok, here it goes;
  1. Make SRS Airbag system safe, disconnect BOTH battery leads and wait 10mins for SRS battery to discharge.
  2. Remove two torx screws securing Airbag system (rear of steering wheel).
  3. Remove Airbag Module.
  4. Disconnect SRS connection.
  5. Disconnect steering wheel multiplug.
  6. Make steering wheel and front wheels central.
  7. Hold wheel and release/loosen big-fat-centre-nut.
  8. Pull wheel from splines.
  9. Remove and discard big-fat-centre-nut.
  10. Remove Steering Wheel.
Jan 29, 2013 | 2003 Land Rover Freelander
How to remove steering wheel, 2000 blazer
Parts stores sell an inexpensive steering wheel removal puller. Follow repair manual removal procedure, so the air bag doesn't activate. The steering wheel is retained by a large nut on the steering wheel shaft. Remove the nut, and attach the puller to wheel-it should pull right off.
May 16, 2012 | 2000 Chevrolet Blazer
Disconnect battery,,,,,,,,remove screws from back of steering wheel cover.. front of steering wheel cover will come off and may be plugged into steering wheel carefully remove wire plug from tab.remove large nut on center of steering wheel , use puller kit from local auto parts store , prob wont come off on its own but might . BEFORE removal note location of scratch on wheel , matching scratch on post for alignment of wheel on replacement ,slide steering wheel into place, tighten nut just enough, replug wire and dont make screws too tight re hook battery and reprogram radio.... sorry.. yur welcome
Jan 13, 2012 | 1997 Acura CL
How do u remove the stering wheel from a dodge 15oo to replace the whipper control
Disarm the Supplemental RestraintSystem (SRS) (airbag) Remove the airbag assembly. Partially remove the steering wheel retaining bolt. Leave the bolt in the column to push on it. Install a steering wheel puller.(Available at almost any parts store) Remove steering wheel puller, steering wheel and bolt once steering wheel has popped loose from the steering shaft.
Dec 20, 2010 | 2004 Dodge Ram
How do I remove the turn signal/light switch from a 94 Mercury tracer.
TURN OFF RADIO FIRST TO KEEP FROM LOCKING IT OUT.DISCONNECT NEGATIVE BATTERY CABLE WAIT 20 MINUTES FOR AIRBAG TO DISCHARGE THEN.REMOVE STEERING WHEEL COVER RETAINING SCREWS FROM THE BACK SIDE OF THE STEERING WHEEL AND REMOVE THE COVER.DISCONNECT THE HORN ELECTRICAL CONNECTOR AND THE SPEED CONTROL ELECTRICAL CONNECTORS IF EQUIPPED.REMOVE THE STEERING WHEEL MOUNTING NUT OR BOLT.YOU NEED A STEERING WHEEL PULLER TO REMOVE STEERING WHEEL DONT USE A HAMMER ON STEERING WHEEL BECAUSE IT WAS FACTORY MADE TO COLLAPSE DURING A CAR ACCIDENT.IF HIT STEERING WHEEL WITH HAMMER IT WILL COLLAPSE.USE STEERING WHEEL PULLER YOU CAN BUY ONE AT SEARS AUTO TOOLS OR SNAP ON TOOLS ALSO MOST AUTO PARTS STORE CARRY IT ALSO.OKAY AFTER REMOVING STEERING WHEEL.REMOVE THE 4 RETAINING SCREWS FROM THE STEERING COLUMN LOWER COVER AND REMOVE THE COVER REMOVE THE UPPER COVER.DISCONNECT THE 3 MULTIFUNCTION SWITCH ELECTRICAL CONNECTORS.REMOVE THE MULTIFUNCTION SWITCH RETAINING SCREW PULL THE ELECTRICAL CONNECTORS FROM THE RETAINING BRACKETS AND REMOVE THE SWITCH.INSTALL EVERYTHING VISA VERSA.TORQUE STEERING WHEEL MOUNTING BOLT TO 34 - 46 FT LBS.
Oct 15, 2010 | 1994 Mercury Tracer
I have a 2002 Yukon Denali and I was wanted to know, how do u change the bulb in the steering wheel?
Steering Wheel Control Switch Assembly Replacement Removal Procedure
  1. Remove the steering wheel. Refer to Steering Wheel Replacement .
  2. Remove the horn switch from the steering wheel.
  3. Remove the steering wheel shroud retaining screws from the back of the steering wheel.
  4. Remove the steering wheel shroud from the steering wheel.
  5. Remove the steering wheel control switch mounting screws.
  6. Disconnect the steering wheel control switch (2) electrical connector (1).
  7. Remove the steering wheel control switch from the steering wheel.
Steering Wheel Replacement Tools Required J 1859-A Steering Wheel Puller
Removal Procedure
  1. Disable the supplemental inflatable restraint (SIR) system. Refer to Disabling the SIR System in SIR.
  2. Remove the inflator module. Refer to Inflatable Restraint Steering Wheel Module Replacement in SIR.
  3. Remove the horn switch. Refer to Horn Switch Replacement - On Vehicle .
  4. Make an alignment mark in order to note the relationship of the steering wheel to the steering shaft.
  5. Remove the steering wheel nut.
  6. Remove the steering wheel, using the J 1859-A .
Installation Procedure
Oct 04, 2010 | 1995 GMC Yukon
I need to put in another steering collum and I dont know how to do it.its a 91 ford F150.hope you can help me.I got another one out of the junk yard for 125,00 is that a good price .thanks for helping my...
I'd say $125.00 is a good price for a steering column.
First, have to remove steering wheel (but I don't have instructions for the steering column. For that, maybe try alldata.com, but that will cost):
STEERING Steering Wheel REMOVAL & INSTALLATION Without Air Bag EXCEPT F-SUPER DUTY STRIPPED CHASSIS MODELS AND MOTOR HOME CHASSIS MODELS Fig. 1: Remove the screws from behind the wheel - F-150 model without air bag 88288p12.jpg
Fig. 2: Pull away the cover with the wiring still connected 88288p13.jpg
Fig. 3: Disconnect the wiring at the steering wheel 88288p14.jpg
Fig. 4: Matchmark the steering wheel 88288p15.jpg
Fig. 5: Remove the center nut from the steering wheel 88288p16.jpg
Fig. 6: Use a steering wheel puller to remove the wheel 88288p17.jpg
Fig. 7: Remove the steering wheel from the shaft 88288p18.jpg
Fig. 8: Correct steering wheel installation 84928058.gif
NOTE: The factory recommends that the front wheels be set in the straight-ahead position and you paint or make chalk marks on the column and steering wheel hub for alignment purposes during installation. Of these two safeguards, it is more important to mark the column so even if the column is moved slightly, the steering wheel can still be repositioned in its original position.
  1. Disconnect the negative battery cable.
  2. Remove the one screw from the underside of each steering wheel spoke, and lift the horn switch assembly (steering wheel pad) from the steering wheel. On vehicles equipped with the sport steering wheel option, pry the button cover off with a suitable prytool.
  3. Disconnect the horn switch wires at the connector and remove the switch assembly. On trucks equipped with speed control, squeeze the J-clip ground wire terminal firmly and pull it out of the hole in the steering wheel. Don't pull the wire out without squeezing the clip.
  4. Remove the horn switch assembly.
  5. Remove the steering wheel retaining nut and remove the steering wheel with a puller. WARNING
    Never hammer on the wheel or shaft to remove it! Never use a knock-off type puller.
  6. Install the steering wheel in the reverse order of removal. Tighten the shaft nut to 40 ft. lbs. (54 Nm)
F-SUPER DUTY STRIPPED CHASSIS MOTOR HOME CHASSIS MODELS
  1. Set the front wheel in the straight-ahead position and make chalk marks on the column and steering wheel hub for alignment purposes during installation.
  2. Disconnect the negative battery cable.
  3. Remove the one screw from the underside of each steering wheel spoke, and lift the horn switch assembly (steering wheel pad) from the steering wheel.
  4. Disconnect the horn switch wires at the connector and remove the switch assembly.
  5. Remove the horn switch assembly.
  6. Remove the steering wheel retaining nut and remove the steering wheel with a puller. WARNING
  7. Install the steering wheel in the reverse order of removal. Tighten the shaft nut to 30-42 ft. lbs. (41-57 Nm).
With Air Bag Fig. 9: Remove the air bag module and disconnect the wiring harnesses 88288g00.gif
CAUTION
Read the air bag service precautions in Section 6 prior to doing work involving an air bag equipped steering column component. Always wear safety glasses when servicing an air bag vehicle and handling the air bag to avoid possible injury.
  1. Turn the front wheels to the straight-ahead position.
  2. Disconnect the battery-to-starter relay cable for at least one minute to let the air bag back-up power supply discharge.
  3. Remove the air bag module from the steering wheel (refer to Section 6).
  4. Disconnect the horn/speed control wiring from the steering wheel.
  5. Remove the steering wheel retaining bolt.
  6. Install the Differential Bearing Cone Remover/Replacer, No. T77F-4220B1, or equivalent, and remove the steering wheel. Route the contact assembly harnesses through the steering wheel as it is lifted off of the shaft. To install: NOTE: Make sure the front wheels are still in the straight-ahead position prior to installation.
  7. Route the air bag sliding contact wiring through the steering wheel at the 3 o'clock position. Position the steering wheel on the shaft an align the marks. Make sure not to pinch the contact wire. WARNING
    Make sure no air gets trapped between the steering wheel and air bag sliding contact.
  8. Install a new steering wheel retaining bolt, then tighten to 23-33 ft. lbs. (31-45 Nm).
  9. Connect the horn/speed control wiring and clip in place. Connect the air bag wire harness. Tighten the module retaining nuts to 35-53 inch lbs. (4-6 Nm). NOTE: When the battery cable has been disconnected, then reconnected, some abnormal driving symptoms may occur for the first 10 miles (16 km) until the PCM re-learns it adaptive strategy.
  10. Connect the battery to starter cable. Verify the air bag warning indicator light on the instrument panel.
Sep 24, 2010 | 1991 Ford F150
Ok i need to know how to assemble the steering wheel
Steering Wheel Removal & Installation Special Service Tools (SST) Required:
  • J1859-A Steering Wheel Puller
  • J42578 Steering Wheel Puller Legs
To Remove:
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Place the ignition into the OFF position.
  3. Perform the SIR System Disabling procedure.
  4. Remove the inflator module
  5. Scribe an alignment mark onto the steering wheel hub in line with the mark on the steering shaft.
  6. Loosen the steering wheel nut.
  7. Position the steering wheel nut flush with the end of the steering column shaft.
  8. Loosen the steering wheel using the J1859-A SST.
  9. Remove or disconnect the following:
    • The steering wheel controls electrical connector (if equipped)
    • The horn switch lead from the steering hub
    • The steering wheel nut
    • The steering wheel from the steering shaft
    • The steering wheel controls and the steering wheel controls harness from the steering wheel (if equipped)
To Install:
  1. Install or connect the following:
    • The steering wheel controls and the steering wheel controls harness to the steering wheel (if equipped)
    • The SIR connector properly routed through the steering wheel
    • The mark on the steering wheel with the mark on the steering shaft
    • The steering wheel CAUTION
      The fastener is prevailing torque type and may only be reused if the fastener and its counterpart are clean and free from rust and the fastener develops 27 inch lbs. (3 Nm) of torque or drag against its counterpart prior to the fastener seating. If the fastener does not meet these criteria it must be replaced.
      1. Torque to: 33 ft. lbs. (45 Nm)
    • The horn switch lead to the steering hub
    • The inflator module
    • Enable the SIR system.
  2. Ensure that the steering Wheel controls operate properly (if equipped).
  3. Ensure proper horn operation.
Jul 03, 2010 | 1997 Chevrolet Venture
I need to know how to take off a steering wheel from a 2002 chevy pick up truck
1 remove negative battery cable 2 remove air bag module from steering wheel, this is usually bolted thru from the back of the steering wheel 3 remove steering wheel retaining nut. 4 Using a steering wheel puller pull steering wheel from steering shaft.
Mar 16, 2010 | 2002 Chevrolet Silverado
Upgrade 97 Lexus ES300 Steering wheel to 2001.
Yes you can switch steering wheels, the wood grain is pricy. disconect the battery, wait 5min. remove caps from side of steering wheel. remove torx bolts from air bag assy. Remove wires from air bag. Place air bag upsode down in passenger seat. Make sure steering wheel is straight, remove 19mm nut and remove steering wheel.
Mar 06, 2009 | 1997 Lexus ES 300
Toyota 2010-2013 Prius Steering Wheel Cover Euro-Perf 2 Color, Size 14 1/8 x 4 1/8 Logo
81 people viewed this question
Top Wheelskins Vehicle Parts & Accessories Experts
David Harrelson
David Harrelson
RAYMONDO1953
john h
Are you a Wheelskins Vehicle Part and Accessory Expert? Answer questions, earn points and help others
