Question about Mtd Garden
I need a diagram for a yard machine riding lawn mower 20 hp 42'' cut mulching mower model #13B1675H062 belt #754-0440
  • Dwain Pippen May 11, 2010
    Check the model number again under the seat. That does not show to be a good model number
  • 376 Answers
SOURCE: Craftsman 42 inch riding lawn mower is not cutting evenly
The first thing to check is your blades. If one is bent, it will never cut even. It happens a lot hitting roots, antbeds, etc. Mulching blades will bend easier than a straight blade. It's best to take them off and lay one on top of the other to see if they're bent.
Posted on May 25, 2009
bargainbin2
  • 123 Answers
SOURCE: Craftsman 42 inch cutting deck riding lawn mower.
Some of the 42 inch Craftsman mowers Have a cable that goes from the blade leaver to the deck some have a linkage if it has the cable check it to see if it has broken. Find where it connects to the deck pully and pull on the cable wire not the cable cover and see if if comes out also make sure it is connected to the top of the idler pully. If it has a linkage there is a clip that holdes that linkage to the deck it most likely came off.
Posted on Aug 28, 2009
  • 376 Answers
SOURCE: Belt Diagram needed on Craftsman Kohler Command 20 Hp RidingMower
Go to... http://www.searspartsdirect.com/partsdirect/index.action Enter your model #, click enter, then scroll down to the sudcomponent list and click on 'Mower Deck' if it's your blade belt you need to see or 'Ground Drive' for your transmission belt. Hope that helps. Dwain
Posted on May 15, 2009
  • 202 Answers
SOURCE: I have a Troy bilt 17hp 42 inch cut ride on lawn
yes they have a charging system, not like a car but a charging system one the less. as i said before either under or around the flywheel. some newer mowers also have an electronic regulator.
Posted on Jul 31, 2009
  • 143 Answers
SOURCE: mtd yard bug model - 198707 riding lawn mower blade belt size?
I dont know the belt size but if you go to mtd belts in Jackssmallengines.com you should find it. Stephen.
Posted on Aug 23, 2009
DIAGRAM OD DRIVE BELT ON 46 INCH CUT HUSKEE MOWER
You will need the model number to find this info. Usually on a plate or sticker under the seat. The use a parts site like jackssmallengines.com or simply Google your make and model followed by "deck belt"
Oct 07, 2016 | Huskee Tractor Replacement Riding Lawn...
Belt diagram for 46" mtd yard machine riding mower
You can find the belt diagram for the MTD Yard Machine mower in the MTD Owner Manual. The diagram is on page 21.
Feb 02, 2013 | Craftsman 20 Hp 42" Deck Lawn Tractor
We are needing a diagram on how to put a deck belt on a 42 inch yard machine
Needing a diagram on how to put drive belt on 42" 20hp poulan pro lawn mower
Jul 23, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
I have a model 944-604810 riding lawn mower and find that it leaves a trail of cut grass even though it is equipped with a mulching blade and a new mulching cover. It would appear that the grass is not...
yes that is most likely the cause of it, also, you have to cut more often when mulching, and the higher the cutting deck, the more likely the grass will blow out without getting mulched enough. More than likely, the blades are dull, and/or the grass is too high, or possibly even wet if it is high.
Aug 23, 2010 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
We need a belt diagram for a Craftsman V20 riding lawn mower
Look under the footrest for a sticker with the diagram on it.
Jul 17, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
I would like to replace the mulching blades on my Sears Craftsman riding mower with regular cutting blades. I can find plenty of sources for new mulching blades, but not cutting blades. My mower is a model...
The straight blade for the 42 inch mower is 138971.They cut better and are easier to sharpen and you will need them if you use a gass catcher. If you do not want to use sears for parts you may be able to find good deals on ebay.
Jul 16, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
May 15, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Trying to find replacement belts for a Craftsman Riding Lawnmower. 6 speed 46'' cut EZ 3 Mulching Family SKH 624U1G2RB Model #CV207 Serial # 2811705321
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=craftsman+rider+belts&_sacat=See-All-Categories
They do have some for your rider here on ebay.
You can also Go to http://www3.sears.com/ Enter your correct model number (the one under the seat; starts with 917) then continue to the diagrams list
May 13, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Weedeater 12.5 hp 38
thats a ayp deck.
the 38 and the 42 take the same belt
Aug 29, 2008 | Garden
Garden Logo
965 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
