NTV3202LCDHDN REMOTE CODE
I WANT TO KNOW THE CODE OF THIS LED REMOTE
What is the code for a sharp t.v on a innovage jumbo universal remote
Don't know the codes... but it has a search function to find them itself.
Start by turning on the device that you want to program.
(1) Press & release the device button that you want to program, lets say "VCR" LED will flase once
(2) Press & hold the "CODE SEARCH" button until the LED stays on.
(3) Press and release the POWER button. Point the remote at the device.
(4)The LED will flash as the remote is searching for the code.
(5) As soon as the device turns off press and release the "ENTER" button.
The remote should NOW be programed
Let me know if this works for you... and please leave feedback for me! Thanks!
Oct 12, 2010 | Innovage Jumbo Remote Control
I don't know the code or how to program it to my magnavox tv or zenith dvd/VCR player
Manual code entry
1.Turn on your television or other electronic component that you want to program the remote control for.
2.Hold down the "Code Search" or "Setup" button until the LED indicator light turns on.
3.Hit the button for the component that you are programming (TV,DVD VCR, etc.). The LED light should flicker and stay on.
4.Enter the 3-digit or 4-digit code that corresponds to the TV or device that you're operating.The LED light should go off if the code is valid, but will flash if it is not. Try other codes you have.
5.Try turning the television or other programmed component off to ensure that the remote works properly, once the light has gone off.
Auto configuration
3.Hit the button for the component that you are programming (TV, DVD, VCR, etc.). The LED light should flicker and stay on.
4. Press and release the "Power" until the television or other component turns off while waiting at least 2 seconds between each press.
5.Press "Enter" or "Save" once the remote has effectively turned the power off. The LED light will shut off and the remote will now operate the device.
You can get your codes from below website
http://www.jascoproducts.com/support/universal-remote-codes.asp
Thanx
Aug 05, 2010 | GE RM24912 Universal Remote Control
How do i get this remote programed to work with my television?
I hope this would help you.
1, Turn on the tv.
2. On the remote control, press the tv key once.
3. Press and hold SET until the LED blinks twice, then release SET.
4. Use the code to locate the typ of device and brand name and then enter the first four digit code for the device. If performed correctly, The LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter the same code again.
5. Aim the remote control at the tv and press power once. The TV should turn off. If it does not repeat steps 2 to 5. trying each code for your brand until find one that works. If it doesn't work, try searching for you code.
BTW, I don't know the brand of your tv so you might as well try these steps to search for you code but if you want to use the steps above just reply to this and send me the brand of your tv so i can search for the code.
1. On the renote control, press TV once.
2. Press and hold SET until the LED blinks twice, then release SET.
3. Enter 9 9 1. The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate between pressing POWER and TV. Stop when the TV turns off.
5. To lock in the code, press and release SET. The LED will blink twice.
Jun 10, 2010 | One For All URC-6131 Remote Control
I do not know the code to my Innovage television remote.
If you do not know the code for your remote or have the manual handy, I recommend using the auto-search function.
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
I hope that helps.
Dec 21, 2009 | Innovage Jumbo Remote Control
I need to reprogram my jumbo remote to my tv and dont know how or any codes.please help?
I recommend using the auto-search function of your remote to find the codes for your TV.
  1. Turn on your TV.
I hope that helps.
Nov 27, 2009 | Innovage Jumbo Remote Control
How do i prowgram my tv
To program your URC-3021 remote control to operate your TV, you need to look up the brand of TV you have in a list and program the code for your TV into the remote control. If you don't know the brand of your TV, or the codes in the list don't work, the remote has a code search function.
To search for a code for your TV:
  1. On the remote control, press TV once.
  3. Enter 9 - 9 - 1.The LED will blink twice.
  4. Aim the remote control at the the TV and slowly alternate between pressing POWER and TV. Stop when the TV turns off.
  5. To lock in the code, press and hold SET until the LED blinks twice, then release SET.
Hope that helps.
Oct 04, 2009 | One For All URC-3021 Remote Control
No instruction manual for a Radio Shack remote
SEARCHING FOR YOUR CODE
If your device does not respond to the remote after
trying all codes listed for your brand, or if your
brand is not listed, try searching for your code. For
example, to search for a code for your TV:
1. Press TV once.
2. Press and hold P until the red LED blinks
twice, then release.
3. Enter 9 9 1. The LED blinks twice.
4. Aim the remote at the TV and press Power.
The remote sends IR codes from its library to
the selected device, starting with the most
popular code first.
5. If the TV responds, go to step 6. If the TV
does not respond, press CH+. The remote will
try the next code. Continue until the TV
responds.
NOTE: Press CH- to try the previous code.
6. To lock in the code, press P once. The LED
blinks twice.
7. To search for other device codes, repeat steps
1 to 6, substituting the appropriate device
key.
Mar 23, 2009 | Radio Shack 15-2142 Remote Control
Remote control code for Emerson LC200EM8
Have you tried the searching for your code option on the 15-2147?
for example, turn on your Emerson LC200EM8( press the appropriate key on your remote, if this is a TV.#1.press the tv key on your remote)..#2.Press and hold the little 'p' key till the LED lite,on the remote, blinks twice..#3..then enter 9 9 1.(the led should blink twice).#4.Aim and..Press the Power off on the remote....(the remote will start sending IR codes from its library to the selected device, starting with the most popular.)#5..If the TV responds go to step 6..if not, press the CH+ button, until it does...step #6 when device responds, to lock in the code, press 'p' once, the LED blinks twice.
Once you have your number locked in,,,you can get the remote to tell you what sequence the code is in by #1Press the appropriate key on the remote.(i.e, TV press the TV key ....Dvd player or VCR, then press that key). (Note: make sure you are aiming the remote at the device so the IR(infrared) enters the device.) Step #2 Press and hold the 'p' key(upper right corner of controller) until LED blinks twice, then release....Step #3 enter the code 9 9 0 ..the LED lite blinks twice. ..Step#4 to get the first number of the code press th e number 1 on the controller...the LED will blink the once for 1 //twice for 2...three times for3...etc...write down how many times the LED blinks(if it doesnt blink the first number of the code is 0) Repeat step #4 to get the remaining numbers, i.e. for the second mumber of the code enter 2...third number enter 3...till you have all four numbers.( when done you can press a different device key to get you off... then press the right device key for your device to operate it remotely. Hope this helps
Aug 31, 2008 | Radio Shack (15-2147) Remote Control
Living Solutions Jumbo Remote
for code retrieval:
press and hold "code search" until led lights up solid red.
press the device button (TV for tv, DVD for dvd player, etc.)
press each of the buttons 0-9 untill the light blinks. that means you have the 1st number of the 3 digit code.
repeat to find the 2nd and 3rd.
After you find the 3rd digit, the led will turn off.
Now you have the code!
So, what you do is:
turn on the device you want to program.
aim the remote and hold code search until light remains solid red
press device button
enter the code, led should turn off
after that, press the on/off key.
Jul 19, 2008 | Big Button TV Universal Remote
Apex Digital GB4308 remote
Programming the Remote Control Remote-control switchover Press VCR/DVD, SAT/CABLE or AUX to select the device you want to control. To program the remote control Press and hold VCR.DVD, SAT/CABLE or AUX for over 2 seconds until the LED on the remote control turns off. Release the button the LED will light again (the remote control enters the PROGRAMMING mode). Enter three-digit code number for your equipment. If the correct code number is entered, the LED blinks three times. If you enter a code not listed below, or you press any other buttons than SEARCH and 100+, the LED turns off. To search codes Press ad hold VCR/DVD,SAT/CABLE or AUX for over 2 seconds unil the LED turns off. Release the button (the LED wil light again) and the remote control enters the PROGRAMMING mode. Press SEARCH. Press CH+/- to search codes downwards or upwards. Each time you press CH+/-, the code number decreases or increases by 1 while the remote control sends the code number for POWER button on your device. If the desired code number is found,press 100+ to program the code for your device until the LED blinks three times.Then the remote control exits from the PROGRAMMING mode and returns to norml operation. Or press any other button to exit from the PROGRAMMING mode after the LED blinks rapidly eight times, and the operation is not active. To check the current code number Press and hold VCR/DVD, SAT/CABLE or AUX for over 2 seconds until the LED turns off. Release the button (the LED will light again) and the remote control enters the PROGRAMMING mode. Press 100+ . You may read the code numder according to the LED display status as follows. * If there is no operation within 20 seconds during the steps mentioned above, the remote control will automatically exit from the appropriate operation. Code Number First - digit 0 1 0 1 Second - digit 0 0 4 5 Third - digit 0 6 3 0 First - digit Blinks rapidly once Blinks once Blinks rapidly once Bliks once Secod - digit Blinks rapidly once Blinks rapidly once Blinks four times Bliks five times Third - digit Blinks rapidly once Blinks six times Blinks three times Bliks rapidly once
Jan 05, 2007 | Apex Digital GB4308 43" Rear Projection...
Televison & Video Logo
11 people viewed this question
Top Televison & Video Experts
Electro Med Services...
