Question about Bosch Hammering
11316EVS how to install a service kit
  • Bosch Master
  • 1,792 Answers
This is the only BOSCH machine that i leave it to the specialists of BOSCH because of the otiosity by this model unfortunately there are to much problems with leakage of the hammer tube in 90% of the service these tubes must replaced, the newer ones not anymore but these models have to much problems after the most operating hours. and its to expensive in much cases and if you doit yourself you should be very lucky in 20% of the change it will be worth the 1 or 2 hours you should spend on it the light aluminium house to get closed you must take other bolts and locktite to get it closed again and if it closed then there should be an other problem , if they were new then it was a nice hammer, but it was basically a misfit among the forest tools for affordable service. ONLY THIS KIND OF MODEL .
Hot Item High Quality 11e 1500W Electrical Demolition Hammer
Posted on Feb 26, 2016
Because my Bosch 11316EVS does not turn on I plug it into the light and it does not turn on
Bosch Parts Service Online Illustrated Part List
Control the power cable for wire breakage second remove the carbon brushes and control them on the collector surface for if there is a little black pin was coming out of it thats an auto protection build in then replace the brushes , but there are more things because there can be a problem with the electric field on a contact measure both coils and all the collectors (commutator around) on the armature that there is no-one lost the last option is the electronics
May 02, 2017 | Bosch Hammering
Which parts need to be greased before I put it back together
Bosch 11316evs a hammer where are complete maintenancekits for with the right grease beware of the parts that are have high priority to observe ALLWAYS REPLACE POS 41 and 39 together to get the neccesary pneumatic vaccuum for the mechanism because if there is leakage of oilseals the o-rings are to early getting HOT and harden prematurely again. also
Also note that the statorfield is mounted with two screws, because it does happen often that these 2 screws are not used!! and this in order to prevent the mangle with the four sliding contacts
A nice old model hammer GBH 11 in the Netherlands and or the same as this new product
http://dasen-hammer.en.made-in-china.com/product/BMgJKvoEXFpm/China-High-Quality-11e-1500W-Electrical-Demolition-Hammer.html
but finally this is what you are looking for your hammer .!!!
POS 898 partnumber 1.617.000.190 a consumables kit
http://www.powertools-aftersalesservice.com/public/boschprof/service?p_auth=aR4sBRMv&p_p_auth=WUDGLa1r&p_p_id=WSRP_bc93764e__6873__4b00__9a29__b331c9759da9&p_p_lifecycle=1&p_p_state=normal&p_p_mode=view&_WSRP_bc93764e__6873__4b00__9a29__b331c9759da9_wsrp-navigationalState=L0JPUy9QVEFTLVBULVNJUy1TaXRlL25sX05MLy0vRVVSL1ZpZXdQcm9kdWN0LURpc3BhdGNoO3BnaWQ9YmI5NWI3MGRjM2E3NzQxY2ExYzA0OGYyM2IzMF9fNDlzR3JsO3NpZD1QMzhKeVRtclkxWndER19mQlhFVk1qWWdLYlM2S19Dd3BYNktZcnNMOW1TVHlMb0F2ZDg9
May 16, 2015 | Bosch 11316evs Elec Vs Sdsmax Demolition...
How to repair bosh 11316evs
Purchase a service kit # 1-617-000-190
This will have all the normal wear parts including brushes & new grease.
This is a fairly easy hammer to rebuild - make sure you thoroughly clean all the parts, install new rings & grease - the kit comes with a parts breakdown to help. Service Pack 1617000190 for Bosch Power Tool eReplacement Parts
Apr 15, 2014 | Bosch SDS - max Demolition Hammer 11316EVS
How to remove demolation hammer shift plate
Dont be afraid to damage it with a screwdriver behind but only detach it from the lower mounting .
Nov 13, 2013 | Bosch SDS - max Demolition Hammer 11316EVS
Bosch 11316EVS demolition Hammer soft start not working. Starts at full speed and does not impact until slowed down.
Variable speed control module has failed, however you can still use the tool. Hammering action will improve with a good cleaning of internal parts and apply new grease. Hammering action is caused by air/vacuum cushion between drive piston and driven piston which inturn hits a third piston that actually impacts the bit. If third piston is worn, chipped and lodged with debris, there will be light hammering action. After use, store the hammer with the nose pointing down so that the driven piston will slide to end of cylinder and ready for next use.
Sep 27, 2011 | Bosch 11316evs Elec Vs Sdsmax Demolition...
Bosch 11316EVS doesn't star. Power cable is good What another issue is possible?
most common problems with these units is brush replacement, or even the on/off switch, I work for a home depot tool rental and are constantly replacing the brushes.
Oct 09, 2010 | Bosch 11316evs Elec Vs Sdsmax Demolition...
It doesn't star. Power cable is good What another issue is possible?
The electric field contacts carbon brush autostop in it is activated or is stuck on dirt .
Sep 29, 2010 | Bosch 11316evs Elec Vs Sdsmax Demolition...
Hammering Logo
164 people viewed this question
Top Bosch Hammering Experts
John Trevino
snowycreek
Are you a Bosch Hammering Expert? Answer questions, earn points and help others
