Question about Echo Rapid Loader, Trimmer Head
Carberator needs adjustment Echo GT weed and trimmer
Whastt are the adjustment proceedure for the jets
#1 Taper
  • 1041 Answers
SOURCE: Echo weed trimmer only run with choke half on
Check the fuel lines for breaks. When they get old, they become brittle.
If this doesn't work, you will need to clean the carburetor. Disassemble the carb. and spray with carb. cleaner. Use a Den Tek Brush,(http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in the carb. Make sure the small screen is free of debris. Reassemble and start.
If neither one of these solutions work then you will need to buy a carb. kit and replace all appropriate parts.
Jim
Posted on Jun 09, 2009
moretons
  • 155 Answers
SOURCE: weak spark on an Echo GT 1000 trimmer
Recomended spark is 6mm or more if there is no play in the crank bearings you can try closing the magneto air gap to 8 thou if that does not work you will need a new ignition module.
Posted on Jul 26, 2009
  • 10 Answers
SOURCE: What is the correct ratio for fuel mix for a ECHO
A 50:1 ratio with 89 Octane fuel can be used in all ECHO 2-stroke equipment, provided the oil is ISO-L-EGD and JASO M345 FC/FD certified. ISO-L-EGD and JASO M345 FC/FD oil must be used with a mid-grade (89 octane) or premium gasoline in all 1997 and newer engines.
A 50:1 Ratio = 1 US Gal. 89 Octane + 2.6 fl. oz. ECHO POWER BLEND OIL
Echo Power Blend Universal 2-Stroke Oil can be used in all of our 2-cycle air-cooled equipment ever made. You may also use this oil in any other brand of 2-cycle air cooled equipment, but it should always be mixed at the 50:1 ratio whether or not it was a 32:1 or 16:1 etc. machine. This oil is the highest quality 2-cycle oil on the market today. There is no need to have more than 1 tank of fuel for your 2-cycle equipment any more.
Use only fresh gasoline with a minimum octane rating of 89 through 93 (mid-grade to premium) at all times. The gasoline suppliers blend mid-grade and premium gasoline with greater amounts of detergents and anti-oxidizing additives to keep the engines clean. Lack of these detergents and additives in a 2-stroke engine will cause a heavy build-up of varnish and gum deposits on the piston surface and ring grooves. Regular unleaded 87 octane or lower gasoline may not contain enough of the detergent additives that are needed in a 2-stroke engine to keep varnish, gum, and tar deposits from forming. Use of 87 octane fuel may shorten the life of the engine.
ALL TWO-STROKE OILS ARE NOT EQUAL!
ECHO POWER BLEND OIL, is manufactured exclusively for ECHO, Inc. and meets the (ISO) International Standards Organizations highest performance rating of ISO-L-EGD for Air Cooled 2 Stroke oils and is JASO M345 FC/FD REGISTERED. Years of research and testing have resulted in an oil that is fully compatible with fuels containing 10% ethanol and can be used in all air - cooled, outdoor power equipment 2-Stroke engines at 50:1 ratio. ISO-L-EGD and JASO M345 FC/FD rated oils must be used with a mid-grade (89 octane) or premium gasoline in all 1997 and newer engines. Always look for the JASO M345 FC/FD square logo and registration number to ensure you are using the highest quality 2-stroke oil for your ECHO product.
ECHO POWER BLEND OIL is made for high revving, (7,000 RPM and up) air-cooled 2-stroke engines that are E.P.A. and C.A.R.B. emissions certified. Make sure the oil has a EGD and FC/FD certification. Oils that meet ISO, EGA/EGB/EGC and JASO FA and FB are of lesser quality, designed for applications such as water-cooled boat engines, low RPM lawnmower engines, or snowmobile engines and should not be used in ECHO Engines. Prior to 1997, oils were not manufactured to these higher standards. Some or most of the oils were simply 30 or 40 weight 4-stroke engine oil with minimum amounts of additives. ECHO POWER BLEND OIL is the highest quality 2-Stroke oil available and will provide maximum protection against engine wear and carbon buildup.
Posted on Sep 05, 2009
  • 1126 Answers
SOURCE: i need an instruction manual for echo srm 225 weed
http://www.echo-usa.com/documentation.asp?Model=SRM-225&lang=E
Hope this link helps.
Posted on Sep 08, 2009
SOURCE: I have a Echo Weed Eater, it starts and runs, but won't rev up
Echo has a spark arrestor screen on the muffler-if this is stopped up with carbon it will give you the problem you describe-check your owners manual-it tells where this screen is located
Posted on Oct 12, 2009
How do you tune a carburetor on a Echo Srm-211 weed trimmer?
search--- workshop manual for Walbro carby
search for --workshop manual for ZAMA carby
there are pdf versions for download and both are excellent manuals for all small engine carby , repair , maintenance and adjustment
May 13, 2018 | Echo Garden
How to adjust carberator on echo cs 315
The carb is sealed for emission reasons. If the engine is not running correctly you may have dirt in the carb jets. Remove the carb and blow out the jets with compressed air.
Sep 09, 2016 | Echo Garden
How to check fuel needle setting in Echo 2100 weed eater
Jack, Check the attached links for trimmer carb. tuning,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Tune Up an Echo Trimmer
http://www.echo-usa.com/getattachment/e8f287f6-0f5c-4f36-b0fa-ea8fa4a550b9/SRM2400241025012501S2510es_120194
echo srm 2100 weed eater
May 07, 2016 | Echo Garden
I have an echo gt 2000 weed eater. I was using it the other day and it was working great and all of a sudden the trimmer head would not spin. What could it be?
one of two things has happened. 1 the trimmer head has melted where it gets driven by the shaft and needs to be replaced or 2 you have a fault in the drive line
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Jan 05, 2013 | Garden
Husqvarna vs Echo gas weed trimmers...needing your opinion.
They are very reliable brands stihl is a very good brand also.
Jul 19, 2010 | Husqvarna 28cc Gas Line Trimmer
Ryobi weed eater runs at full choke, but stalls when choke is turned to run position
does it blow out alot of blue or dark exhaust? if so adjust screw on carberator as it maybe be running rich, if this doesnt work have the switch checked for malfunctioning
May 30, 2010 | Ryobi 15" Electric Factory Reconditioned...
Echo Rapid Loader, Trimmer Head Logo
290 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
colesmowers
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
