Question about Amana NFW7200TW 3.5 Cu. Ft. Front Load Washer
Washer does not spin
Controls work but tub does not turn
  • Amana Master
  • 5,323 Answers
No agitation or spin? try these:
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Transmission or clutch assembly not engaging due to going out or slipping.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Posted on Apr 11, 2015
Jacuzzi tub will only turn off if tub is empty
This sounds like maybe you have a bad circuit on the control that turns the pump on/off.
Get the model number off the control box under the tub and let me know what it is and we can solve that issue for you.
Rod
US Parts Center
888-521-6183
May 03, 2014 | Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner...
Purge line
The breaker the manual is referring to will be the main circuit breaker at the panel.
If the system is not running the purge cycle as it is supposed to and turning the power on and off does not reset the control box then it is likely that the control box has a bad part in the circuity and should be replaced.
Rod
US Parts Center
Apr 13, 2014 | Maax Home
Lasco bubbler massage tub
Sounds like you may have a circuit that is bad in the control box under the tub.
Very unusual for that type of issue unless there is a problem on the circuitry.
Call a technician to have them trouble shoot it for you. It may need to be replaced. Those are not usually an item that is fixed.
Rod
US Parts Center
Feb 02, 2014 | Jacuzzi Nova Whirlpool Tub H532
Do I have the correct controller for my Hot Tub? I have a Jacuzzi Lexus L.C. with a Balboa F1089R1A processor. I ordered a topside control panel online and received a Balboa VL701S but nothing is working...
Curios, why did you order another control panel? I need some history, when it worked, how it failed, any other information like if it was moved or rewired for power...etc.
Nov 13, 2013 | Jacuzzi Home
I bought a used whirlpool tub without a motor. How can I determine. What size and type motor fits it if there are no identifying markings to determine Brand ....?
There are many different pumps that could work with your tub. You need to find out if there is a control on the lip of the tub to turn the pump on/off and what does that control look like.
Rod
U S Parts Center
Oct 31, 2013 | Home
Hot tub breaker not tripped but nothing works
Sounds like your controller has sustained damage. You need to have a professional inspect it to determine what has gone wrong.
Apr 14, 2010 | Pool & Spa
The topside control panel is dysfunctional for turning on the jets. The on/off button doesn't work. The lights and temperature buttons work ok. The on/off button doesn't click on/off like the others.
It may be a bad control pad (topside) or control box (mounted behind the pump under the tub). I have replaced three bellavista control pad and boxes in the past 2 weeks. If you plan on keeping the tub have both the box and topside replaced. You can check the topside by gently prying it off the tub with a stiff putty knife or a blade of some kind, be very careful and take your time. When you have removed the topside, check the circuit board attached to the cable, if there is any corrosion on the board the topside is bad. It will cost 200.00 less shipping, the control box will cost 320.00 or more less shipping. topside part no. M465000 Control box part no. S474000 Both can be found on the internet under their part numbers.
Mar 13, 2010 | Jacuzzi Bellavista, 5.5ft Soaking Bathtub...
I have a jacuzzi corner tub. The control panel
I would expect there is a Jacuzzi dealer in your town and I would guess he has parts. If you purchase parts locally, not only are you helping your neighbor but also, you will have the opportunity to pick his brain on tips to install.
Thanks for your interest in FixYa.com.
Feb 20, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Washing Machine Keeps Filling with Water through Detergent dispen
This machine has a water valve that works on vaccuum from the tub. You will see a small clear hose that runs from the side of the tub up to this valve. This valve is adjustable to change the water level in the tub to desired setting on some machines, but if it goes bad, it will not shut off, thus overflowing the tub. Find this valve and replace it if adjustment does not work.
Oct 10, 2009 | Kenmore 24032\24036 Top Load Washer
Hot tub has power but nothing else works
MY control panel was replaced ,it cycles but, no lights ,no jets,no heat works..What's the problem .
Oct 01, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Amana NFW7200TW 3.5 Cu. Ft. Front Load Washer Logo
94 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Terry Schneider
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
