Question about Ingersoll Rand 2135TiMAX 1/2" Drive Titanium MAX Air Impact Kit with Lighte
How to remove direction buttons
I'm trying to remove the directional buttons and don't know how
My nokia x2-00 came out of the washing machine and has some moisture on the inside. have removed the battery, sim and memory card. pls help
try putting both thumbs on back panel and push in one direction try all four direction's one at a time the panel will slightly move now grab the edge sticking out and wiggle loose do not force it will come loose don't get frustrated, if not working put it down and do something else for one minute then try again this panel can drive you crazy. good luck
Aug 26, 2012 | Nokia Cell Phones
Don't the user name or password for my motorola SB900 can you help ?
That's depends...First, do you have the password to log into the modem? it seems that the default is admin/motorola. If that hasn't been changed, you could log in and remove the WEP key.
In addition, most modems and routers will reset to factory defaults if you press and hold in the reset button for around 30 seconds with the device turned on. Forgetting the password is a common problem. Don't be worry...Or if these all can not work, you can call or ask directly to the customer service of Most modems and routers will reset to factory defaults if you press and hold in the reset button for around 30 seconds with the device turned on. Forgetting the password is a common problem. Don't worry... or if the above ones all didn't work, you can call or ask the Motorola customer service directly, maybe they know the solutions because they produce it!
May 30, 2012 | Computers & Internet
I have the code but don't know how to setup??
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
    Code Search Method
    1. Manually turn on the device (TV, VCR, etc.) to be controlled.
    2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
    3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
    4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
    5. Press and release MUTE to install the code. The indicator light goes off.
    Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Mar 23, 2012 | Televison & Video
Useing a universal remote doesnt work for it
Hello
I don't know which remote contro handser are you using to synchronise with your tV. Anyway I'll give you some codes for RCA TV here. Try with them.
Three digit codes are:
000/ 003/ 004/ 005/ 007/ 009/ 011/ 048/ 078/ 082/ 083/ 094/ 096/ 098/ 099/ 101/ 102/ 103/ 107/ 113/ 129/ 133/ 167/ 179/ 181/ 187/ 188/ 194
Four digit codes are:
0031 0004 0048 0054 0094 0100 0102 0107 0129 0191 0005 0009 0000 0162 0163 0342 0003 0015 0022 0096 0113 0125 0179 0187 0188
Direct Code Entry
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
OK.
Jun 25, 2011 | RCA L32HD31 32 in. LCD HDTV
How do I attach the replacement blade on my B&D jigsaw model 7504? I have the replacement blade but don't know how to attach it....
Locate the small hole with the screw inside it directly above the handle, which usually is in line with the blade. Loosen the screw with a flathead screwdriver. Once the screw is loose, gently pull the blade out from the unit .. this works with older Jigsaws for newer ones ,,Locate the release button just above the portal where the blade enters the body of the unit. Depress the button and gently pull the blade out from the unit.
Insert the new blade into the same portal that the old blade was removed from while depressing the release button. Ensure that the new blade is facing the same direction that the old blade faced. Once the blade is fully inserted into the portal, let go of the release button.
May 13, 2011 | Black & Decker Vacuums
DON';T KNOW HOW TO SEE THE PICTURES
Usually there is a button on the back of the camera, it is a green square with an arrow I think. Press that and then use other buttons (usually directional buttons) to scroll through your pics.
Mar 26, 2011 | Cameras
Brady 300 mvp displays "Ribbon in" warning. Whats does this mean?
I've got the same issue. This means the brady machine is configured for direct thermal transfer (no labels in the machine). Press setup, use the - and + buttons to scroll to direct transfer. Again, press select and again use the plus or minus button to select thermal transfer (labels in the machine).
I must say that the setup menu is tricky. If a password is needed, that's another story. Not impossible, but you have to know how to use the label maker, which I don't . I'm unable to remove the flashing errror message.
http://www.zebra.com/content/dam/zebra/manuals/en-us/printer/z-rzseries-ug-en.pdf
Dec 21, 2009 | Brady Office Equipment & Supplies
"Dell Media Direct" on Inspiron 1525
Make sure you do not have a bootable CD or DVD in the drive. If that does not resolve, then try holding the "home" (Media Direct) button while pressing the Power button on.
Nov 02, 2009 | Dell Inspiron 1525 Laptop
Internal error 11
Is your printer connected directly to your PC? I?ve found some literature that suggests this is or is related to a communications problem. I would suggest removing the printer and reinstalling it from scratch. If you run into problems try another cable, remove all other USB devices (if you?re using USB to connect the printer) or if using a parallel cable switch your parallel port to ECP or bi-directional printing mode. Let us know if this helps and please don?t forget to rate this post.
Feb 15, 2007 | Samsung ML 7050 Laser Printer
LCD showing "remove len cap and press reset button" always
Simple! Read warnings carefully! It said "remove lens cap and press SET button"! So remove the lens cap and then press the SET button (or arrow downward in the four directions button)! You don´t need to RESET anything...
Jan 15, 2007 | Panasonic Lumix DMC-FZ1 Digital Camera
Ingersoll Rand 2135TiMAX 1/2" Drive Titanium MAX Air Impact Kit with Lighte Logo
74 people viewed this question
Top Ingersoll Rand Air Tools & Compressors Experts
elunsford
Eddie Tucker
Level 1 Expert
John Trevino
Are you an Ingersoll Rand Air Tool and Compressor Expert? Answer questions, earn points and help others
