Question about Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD HDTV
My remote does not have input button. how to get to hdmi input on sony
HDTV sony 55 in.
3 Suggested Answers
Baker Audio
  • 29 Answers
SOURCE: I have a Sony FWD-40LX2F tv and I cannot change
This is Something you'll have to talk to the Manufacturer about. Sounds Like it may just be plain Broken
http://esupport.sony.com/US/perl/contact-land.pl
Posted on Jan 15, 2011
  • 12962 Answers
SOURCE: I'm trying to program a Comcast cable remote silver with red ok button to operate my Sony BDP-S3200 Blu-ray/DVD player and need the code please.
This is a Comcast baby - U are paying them plenty for the service - they should help you with the remote. Don't let them off the hook.
Posted on Nov 07, 2015
I have no remote for an rca l32wd22 hdtv lcd tv and cannot find the inputs to change to HDMI?
Unfortunately, the L32WD22 doesn't have an Input button on the front panel of the TV. You need a remote control that matches the Input code for the remote. Here's one link to a remote that should work: http://remotes.com/store/rca/l32wd22.html . Other universal remotes may work if you find the correct code if the remote has an Input or Source button.
I hope this helps.
Apr 16, 2013 | RCA L32WD22 32 in. LCD HDTV
Where do to plug in the cord to connect the tv to the DVD player?
Hello
You have several options for connecting your DVD player to your GV42L FHDTV10A - HDMI,
Component, S-Video and Composite (AV) inputs. Based on your home theater configuration, you can
decide which option is the right one for you.
connected to the HDMI input of the VIZIO GV42L FHDTV10A for optimal results.
To maintain the display quality, use a VIZIO certified HDMI cable available up to 10 meters or less.
1. Turn off the power to the LCD HDTV and DVD player.
2. Connect a HDMI cable to the HDMI output of your DVD player and the other end to the HDMI
Input (white color area) at the rear of the LCD HDTV.
3. Turn on the power to the LCD HDTV and your DVD player.
4. Select HDMI using the INPUT button on the remote or side of the LCD HDTV, or directly by
pressing the HDMI button on the Remote Control.
a) If you are already using the HDMI 1 input for another component, or you do not want to use
the HDMI 1 input for the DVD player, you can connect the DVD player to the HDMI 2
connection.
b) Refer to your DVD player user manual for more information about the video output
requirements of the product.
OK
Apr 24, 2011 | Vizio 42 in. LCD TV
Just set up the tv... have cable going to hdmi 1 and dvd to hdmi 2... checked all wires, but tv saying NO SIGNAL... wondering what am missing. is there a setting i have turn on for hdmi input
On your Sony TV remote, press the "Input" button and make sure you select HDMI 1. Also, check to make sure you HDMI is plugged into your cable box.
Feb 14, 2010 | Sony Bravia KDL-37M4000 37 in. LCD HDTV
I have a sony bravia kdl 37m3000. We have cable and the wide screen would not go away so we unplugged the cable to reset the tv. Now the cable and the tv comes on but no picture.
Make sure you change the input that the cable is coming in on, If you was watching in HD mode then you was using an HDMI or compontet hook up.Look on tv remote for Video input button to select the componet input 1 or 2 or HDMI inputs which it is connected to. Look for a button on the remote called TV/VIDEO or INPUT
Dec 15, 2009 | Sony Bravia KDL-37M4000 37 in. LCD HDTV
How do i turn on the hdmi setting to make a ps3 work
Turn off TV, unplug it from AC socket, plug PS3 in HDMI input, turn On PS3 and then turn On TV so TV will recognize PS3 through HDMI
Oct 10, 2009 | Sony Grand WEGA KDF55E2000 55" Projection...
How do i get on the HDMI input channel?
Hello Jeff. I just have a basic question for you. Was the Blu Ray player turned on when you first plugged it into the tv? TV's are becoming so complicated that they are becoming less user friendly. Try setting your tv to the first HDMI input using your tv remote's input button. Then unplug the HDMI cable from the tv, make sure the player is turned on then plug the HDMI cable into the left most input if horizontal or top input if vertical. Hopefully if you do that and have the input selected, it should work for you.
Also: Whi9le attaching the cable, I find it helpful to have it in a position where I can see the tv, because when a device hooks up the screen usually flashes or turns blue or something similar.
Hope this helped
-Chris
May 01, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Ps3 sony grand wega (4 yrs old)
Press the input button on the tv itself to select the proper input you desire.
Dec 27, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
KDL-32XBR6
Try resetting the TV by holding down the "up" button on the remote (with the TV powered on) and then, while you hold down the up button on the remote, hit the power button on the TV. This should do a "factory reset" which will wipe all settings in the TV. There is no reason why the TV should not "remember the last input it was on when it was ;last turned off. Also be sure that the TV is not plugged into a switched AC outlet, like the outlet on the back of the cable bix. The TV should be plugged into an output that receives power at all times.
Oct 19, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD HDTV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
