Question about Worx Electric Blowervac With Carrying Case 644515
Lost my manual. I can't get it open to fix it
How can I open my WORX Blower?
The Jaw won't close... How do I fix?
carefully remove all the screws you can find open the handle and look for a cam follower my neighbors daughter broke hers and had opened it lost cam follower . took me a couple days to find it she had not read the instructions and the chain had popped off inside . .
Apr 27, 2015 | Worx Jaw Saw Wg307 - The Chainsaw...
My blower doesn't have reaction while I put in the recharged battery(20v) after store in garage for one winter.
see if you can rotate the blades with your finder sometimes that's all it takes to get her going
Apr 13, 2015 | Garden
Worx leaf blower/vac WG500 - tried to use it this season and I plug it in and I get nothing - the extension cord is good, but the Worx doesn't suck or blow. Seems like no power. Any thoughts
Try cleaning the connection prongs on the leaf blower..some times corrosion builds up when not in use..also if you have a multi meter and know how to check continuity you can check the run switch...just use something like tape to hold the switch in the on position..and the with the meter in the ohlms " continuity " position touch the meter wires to the connection prongs..you meter should show continuity if not the switch is not making connection with the power supply..may need cleaned or replaced...if it shows continuity and still Does not work...need to be serviced...
Sep 30, 2014 | Worx WG500 All-In-One Vac Mulcher Blower,...
I lost my owners manual
It's pretty simple to use. But if you feel you need help go to WORX.com & download it.
Sep 02, 2013 | Worx 10" 18v 2 In 1 Grass Trimmer/In Line...
Manuals
You may download the quick-start guide and the owner's manual from http://www.worx.com/en-US/worx_trivac_wg500.aspx
May 30, 2013 | Worx WG500 All-In-One Vac Mulcher Blower,...
Can you fix the Worx WA3152 battery instead of buying a new one?
CHECK WORXBATTERY.COM .. THERE ARE LITH.BATTERIES W/ CERTAIN SERIAL #'S THAT HAVE THE FLASHING RED LIGHT ISSUES. SEE IF THEY REPLACE YOURS FOR FREE . THEY DID MINE WA3512 18vt. hope this helps.
May 21, 2010 | Worx 18 VNiCd Battery for Electric Line...
I need to replace the on/off switch on my WORX grass trimmer do you have a schematic?
usually one side of the switch to the ign. coil and the other to ground or earth. simple mate
Apr 02, 2010 | Worx All-In-One Blower/Vacuum/Mulcher
Cannot remove bag
I am not familiar with this brand, but I will be glad to try and help you. Did you put the bag on, or did it come out of the box with the bag on? Any idea if it twists and locks, or does it have a latch on each side?
Oct 23, 2008 | Worx All-In-One Blower/Vacuum/Mulcher
Worx Electric Blowervac With Carrying Case 644515 Logo
41 people viewed this question
Top Worx Garden Experts
Tim Whalen
ray gallant
Wayne McNeil
Are you a Worx Garden Expert? Answer questions, earn points and help others
