Question about HP ECS ACER 946GZT-AM V1.0 SOCKET- LGA775 SATA2 INTEL MOTHERBOARD
Continuous beep motherboard will not boot
Continuous beep on boot-up with no display. Power is getting to the motherboard as CPU cooler fan is working. Tried various sticks of RAM to no avail. Re-set BIOS jumper, no change.
  • HP Master
  • 3,204 Answers
Check the battery for the mother board memory. flat battery can make it no startup. also if that is fine remover the hard drive lead and turn on if it comes on then the hard drive is causing the fault. do same with rom's.
Posted on Mar 24, 2014
SOURCE: HP P4B-MX beep
HP P4B-MX is Award Bios
Award and Phoenix BIOS:
1 short beep: Normal
2 short beeps: CMOS error
1 long and 1 short beep: DRAM error
1 long and 2 short beeps: Video card error
1 long and 3 short beeps: Keyboard error, or video card error
1 long and 9 short beeps: ROM error
Long continuous beeps: DRAM not installed correctly, bad memory, or incompatable
Short continuous beeps: Bad power supply
Posted on Jan 19, 2009
Daholk
  • 41 Answers
SOURCE: My HP dv5000 laptop has AMI BIOS beep code - 4 beeps
It sounds like either RAM or VIDEO problem to me. (I can't remember the specific beep sequence for AMI bios errors).
Hard to diagnose in Laptops.... if it was a desktop you can just start swapping out the RAM DIMMS..... are you techo enough to check whether you have 1 or 2 RAM cards installed? If 2 then run it with each card in turn to see if it boots (indicating 1 faulty RAM stick). If only 1 then try running MEMTEST on it to see if any errors. (I like HIRENS if you have it... I think it usually has latest MEMTEST on it).
If your cards all pass then its very likely a video problem. If its onboard video with no expansion slot (likely in a laptop) then you may be buggered.
Let me know if you need a hand doing any of the above.
Posted on Mar 25, 2009
indus3
  • 212 Answers
SOURCE: pavilion dv2125nr won't boot
it could be dead mobo, it's actually the most probable cause of your problem, but there is this thing i've encountered with HP several times already. i know it's a long shot, but i'd like you to try and boot the laptop up after you've removed the DVD-drive. if this works, it's the DVD-drive that's broken, if not, it'll be the mobo...
Posted on Jul 01, 2009
  • 20 Answers
SOURCE: p4sd socket 478 motherboard is not booting up at all !!!
1st check if the voltage from the plug has correct groung , neutral phase set .then
try a new smps , with minimum 400W output.
before connecting the same.
please remove all the parts out of the cabinet please connect only motherboard and smps and check its getting switched on , if not then your board is burnt you will have to replace it , if there is power indication then connect the RAM and check , if its also fine then connect the rest and try.
all this u have tried and no use , please post me a msg with full detail of your PC configuration , I can try a resolution
dil.
Posted on Aug 02, 2009
AndystUK
  • 131 Answers
SOURCE: I get a continuous beep when trying to boot my HP
Beeps like this can eminate from the memory modules, you need to check each module is seated correctly. TURN off the unit and pull the power lead out. open access to the memory modules and simply removed ach one completely then reseat it back gently, never force these things.
Do it to all modules. Hopefully this is all that is the issue. failing this you may have a faulty module so try without one or the other or all to see what happens.
Check visibly for othere clipped in units for the secure seating status. There is an error on the board that has developed and needs to be found by a process of elimination.
AndystUK
Posted on Nov 08, 2009
Hi I am working on a abit A 17 mother board it was taken apart by my nephew. I think I have every thing back togather, but when I turn it on it beeps and shows code 92,well I think thats what the l e d box...
Hi, you can download a manual here:
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=AI7&fMTYPE=Socket 478&pPRODINFO=Manual
The fault could be the cpu, wrong type of ram, a faulty ram module
or a fault in the mainboard.
Check all the settings in the manual and the bios aswell.
Here is a list of beep codes:
Basic Beep Codes for ABIT AWARD BIOS Motherboards
  1. No beep at all - this means your motherboard is dead, either due to a defective or underpowered power supply, poorly seated CPU or RAM, or a dead-on-arrival board
  2. One beep - board is working fine
  3. One long beep then machine shuts down - faulty, improperly installed or missing CPU
  4. 1 short(Beep) System booting is normally
  5. 2 short(Beep) CMOS setting error
  6. 1 long - 1 short(Beep) DRAM ERROR
  7. 1 long - 2 short(Beep) Display card or monitor connected error
  8. 1 long - 3 short(Beep) Keyboard Error
  9. 1 long - 9 short(Beep) ROM Error
  10. Long(Beep) continuous DRAM isn't inserted correctly
  11. Short(Beep) continuous POWER supply has a problem
  12. A two-tone siren, generally caused by overheating or out of specification voltages
  13. Four beeps then machine shuts down. This is because this version of the BIOS will shut down your machine if no fan tachometer signal is detected on the fan header. Make sure you attach a fan to the FAN1 or FAN4 header or clear CMOS to reset to default (no checking).
Sep 07, 2011 | Abit AI7 Motherboard
Continuous beep and the systems is not coming up {boot}
Hardware problem:
* dead RAM
* dead video-card
* RAM not fully "seated" in its slot(s)
* video-card not fully "seated"
* dead fan on top of the CPU/heatsink.
* failing power-supply.
Jul 12, 2011 | HP Compaq dc5100 Small Form Factor PC...
I am running Unix Tru64 5.0 on Compaq Alphastation XP1000. The computer does not boot and does not display anything and does not beep. The power supply works and some LEDs are on on the logic board and the...
Hi.first pull-out your motherboard in the CPU case then power on without memory only processor installed.if you hear continuous beeping your motherboard is working good.
try this beep code means.
No beep means short,no power,bad CPU,loose peripherals.
One beep means everything is normal running motherboard.
Two beep means CMOS error IC.
One long beep,one short beep means motherboard problem.
One long beep,two short beeps means video card problem.
Three long beeps means keyboard error.
Repeated long beeps means memory error.
Continuous hi-lo beeps means CPU overheating.
Hope can help you.
Jun 18, 2011 | Compaq AlphaStation XP1000 PC Desktop
Beeps on startup but no video and continues to have long beeps with no video
Check the the cpu, ram and video card are seated properly. If they all are, then the board is defective and will need to be replaced.
Mar 05, 2011 | Abit NF8-V Motherboard
I get continious beeping in my computer with no display
No beeps Short, no power, bad CPU or motherboard, or the CPU is not installed properly. One long beep, then two short beeps Video problem Continuous hi-lo beeps CPU overheating Repeated long beeps Memory error All other beeps Memory related error
If you are getting hi lo beeps, refit CPU and heatsink
If continuous long beeps, check memory is seated correctly, if more than 1 stick, try each one on its own, 1 may be faulty, or incompatable
Aug 23, 2010 | Foxconn 45CMX socket LGA775 motherboard...
When I press the power button of my CPU i hear 3 Continuous beeps which repeats thrice. Again the beeps come during the windows login. This beep was not there in the begining. It started recently. But...
It is true that your computer is working properly without any trouble.Three continuous beeps means that your keyboard component is not ready to input the data.That's why it is calling you as beeps.You might have to check your keyboard that it is attached with the CPU properly or not.
Apr 06, 2010 | ASUS M4A79 Deluxe Motherboard
I have a mecer computer, LGA 775 motherboard asus and the problem is the computer turns on when switching on and there is no display it beeps non stop . CPU and power supply fans are working ,lights goes...
continuous beeping is Power supply, motherboard, cpu, or keyboard problem. somecases it can also be the memory.
start with the memory then cpu and powersupply and finally motherboard.
let me know if the beep code changes as you change components, count the short and long beeps.
Jan 07, 2009 | ASUS P5VDC-X Motherboard
No boot, continuous Beep
I would take the CPU back out. Remove the excess thermal compound, you should only use a very thin layer. Make sure the CPU is oriented and seated properly.
Jun 06, 2008 | ASUS AI Lifestyle P5N32-E SLI...
HP ECS ACER 946GZT-AM V1.0 SOCKET- LGA775 SATA2 INTEL MOTHERBOARD Logo
332 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
