Question about Empire Industries Empire Priva PR48DC Priva 48" Vanity-48" W x 32.4" H x 21.6" D
Rough in I think my plumber has the wrong rough in dimensions. What are the correct ones
We think that it stopped running due to no fuel. the engine ran rough ever since. Seems to be flooding to the point that fuel was getting into the oil in the sump. Running rough ever since.
Get a cylinder compression test done to check head gasket and to check head is not warped or cracked.
if head gasket or head problem = one cylinder may be affected causing fuel could get into the oil via a blown head gasket. if one cylinder not firing it would run rough.
Has the engine been over heated recently ?
May 06, 2016 | Cars & Trucks
Engine runs rough.
You probably put the wires back on the wrong plugs check the firing order
Apr 20, 2014 | 1999 Mercedes-Benz M-Class
Rough at idol
run fault codes to find which sensor is not correct
Jan 30, 2014 | 1990 Daihatsu Charade
Replaced timming chain now does want to run correctly bad fumes
It sounds like the timing chain was replaced one tooth off. The only other option if the timing chain is correct would be to adjust the ignition timing. Since the timing chain was replaced I would think it to be the first problem.
Dec 17, 2013 | Cars & Trucks
Grohe 35015 valve
These valves are mounted behind the drywall or the cement board. IT is located next to a stud and is held in place by plumbers strap around the inlets and outlets. It is anchored after it is soldered onto the pipes.
Dec 13, 2013 | Grohe 35015000 1/2" Male Rough-In Valve...
My thermostatic mixer shower will not turn off
he probably put it together wrong.
there is usually a blue gasket inside for testing purposes, if that is not removed, the valve will not turn off.
May 12, 2010 | Grohe Integrated 1/2'' Shower Thermostatic...
My thermostatic concealed shower valve only gives either boiling hot water or cold water, there is no inbetween temperature? the cold is fed from mains and the hot from a combi boiler. the plumber has said...
If the hot and cold are fitted the wrong way round then the thermostat on the shower unit cannot operate properly!
Most thermostatic mixer showers have a 'bi-metallic' thermostat, if you supply the hot to the cold and vice versa IT WILL NOT WORK.
It is like wearing the left shoe on the right foot and the right on the left! It doesn't work.
Re-install the hot and cold to the correct supply, and this will sort it.
I hope this helps.
Jul 07, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
Looking to buy/install Toto Aquia II in my circa 1964 co-op apt.
When you say 10.5 inches from wall, do you mean that from the center of the drain in the floor to the back wall is 10.5 inches? If so, you need a toilet for a "10 inch rough-in" dimension. The Aquia doesn't come in that dimension. Sorry!
Caroma Sydney Smart model 270 comes in a 10 inch rough-in and is a dual flush model. Note that all dual flush toilets are fairly expensive as compared to normal toilets. HOWEVER, genrally speaking, ALL 10 inch rough-in toilets are fairly expensive just because the low volume that are sold.
Jul 02, 2009 | Toto Aquia II Dual Flush Toilet
Cj7 w/15cid 4-cyl running bad after tuneup?
i had this problem with my cherokee your not getting the right fuel mixure
Aug 18, 2008 | 1985 Jeep CJ7
Empire Industries Empire Priva PR48DC Priva 48" Vanity-48" W x 32.4" H x 21.6" D Logo
80 people viewed this question
Top Empire Industries Building Materials Experts
hpgwva
Tom Chichester
ray gallant
Are you an Empire Industries Building Material Expert? Answer questions, earn points and help others
