Question about Sony DAV-SB100 System
No audio the sound seems to be muted and the CD does not work.
Iam not having the audio device in my lap top unable to raise the volume or remove the mute itry to remove the mute in control panel clicking the option of sounds but didn't work out they said...
it seems that your windows did not installed properly. some files may be missing. so you should repair your window from the windows cd and then check out your volume control option. If still it would not work then check out the audio drivers.
May 30, 2011 | Computers & Internet
While trying to reset clock lost all volume - how do I restore - unit seems to be working, just no sound (and not on mute)
go back into the menu and search for internal amp turn on. you probably turned the internal amp off.
Mar 28, 2011 | Alpine CDE-9841 CD Player
No sound
Hi, Confirm again is Volume controller not mute, Ifit confirmed, not in mute,
check the all players Check and confirm all video and audio players in your laptopare not mute or very less Volume state. Video or Audio Players like : WinAmp, Windows Media Player,VLC and so on... If everything fine, check the Sound Card drivers areinstalled and working fine. If not youneed to installed the appropriate drivers, To Check follow the Steps:
• Go to Start>
• Control panel>
• Double click on "System" Icon> (it shows the System PropertiesWindow)
• Select "Hardware" Tab>
• Select "Device Manager" Tab> (it shows the Device Manager Window)
• Select "Sound, video and game controllers">
• Expand "+" symbol> (check the audio Codecs, Legacy Audio Drivers andothers are not in Questioned Mark (?) symbol with yellow color. If yes, need toinstall the drivers. Download the drivers from Website or if you have Motherboard CD, > insert the motherboad CD, browse>select audio driverfrom CD or downloaded path >install. After completion, restart computer andcheck.
Jan 19, 2011 | Gateway Computers & Internet
The volume of my computer is not muted at all but when i play a video or any other audio song the sound does not come out so what should i do.
Hi, Confirm again is Volume controller not mute, Ifconfirmed not in mute,
• Go to Start>
• Control panel>
Jan 19, 2011 | Computers & Internet
I have a Kenwood KDC 135 car stereo wont un mute.
behind the face plate there is a little recessed reset button. push it using the tip of a pen or similar. that will fully reset the radio to like it was when you bought it.
Some times head units hicup. this is how you reset it. In most error cases this solves the problem.
Dec 15, 2009 | Kenwood KDC-135 CD Player
JVC AX-66 Integrated Amplifier seems to be muted?
You need to have a jumper between the 4 standalone jacks on the right side of the column of stereo connectors. A stereo RCA cable would work for this.
Oct 14, 2009 | JVC Audio Players & Recorders
No Sound when I play a DVD, but I do have sound when I play a Music CD
Open your sound controls to make sure nothing is muted or set on low volume.
If that's not the case, open your audio drivers program and check to see if nothing is muted.
Oct 22, 2008 | Computers & Internet
My laptop is always on mute mode
Try the following
START \ SETTINGS \ CONTROL PANEL \ SOUNDS AND AUDIO DEVICES
Then make sure the Mute box is unchecked. If that doesn't work,
click
AUDIO \ SOUND PLAYBACK VOLUME
and make sure that all the mute boxes are unchecked.
Sep 09, 2008 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Help with CD rom the music cd is playing without sound on the media player.
Try to uninstall the Audio driver in your system and restart the system.after restarting install the correct driver for your audio. if this not work maybe there some loss cable connection to your speaker. try to check the system speaker maybe set to "mute". you can double click the volume speaker at the "taskbar" . not see in the taskbar you can go to control panel and click "sounds, speech and audio devices" then click "sounds and audio devices" uncheck the mute box opposite and apply.
Dec 11, 2007 | Microsoft Windows XP Professional With...
CD player that doesn't play
I had the same problem.
I cut the orange wire which went into the black connecter block
and WOW I had sound...
brilliant
thanks a lot
Andy - North Yorkshire, England
Oct 11, 2007 | Panasonic CQ-C1303U CD Player
Sony DAV-SB100 System Logo
19 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
