Question about Adaptec Computers & Internet
Accents alarm proximity switch
Proximity switch on door not working
SOURCE: e drive problem. Self propelled feature drives in reverse, but not in forward.
I took the wires loose from the drive circuit card. Using the ohm meter to check for a broken wire, all three checked out fine. I then rigged up a set of jumpers that allowed me to jump across the terminals on the circuit board from the common to the two neutrals. Sure enough the drive motor works perfectly both forward & reverse. The magnetically sensetive transister type switch was the culprit. I have replaced the switch & it works great. I wish I could identify the transistor & only buy it & solder it in.
Posted on Jun 25, 2007
  • 12 Answers
SOURCE: Proximity Switch faulting out irregulary
I dont know what the inviroment is but it sounds like a plant of some sort, the inviroment is important and the electrical service is important. There could be serveral issues here. I would check the electrical service for phase balance and investigate harmonics created through electronics.
Posted on Jan 25, 2009
motor1258
  • 6674 Answers
SOURCE: reverse lights not working
Not 100% sure on that particular vehicle but many have safety neutral & back-up switch as one on transmission. Maybe dealer or part store can look up part & tell you if one switch in your case does both.
Posted on Jul 25, 2009
co7196
  • 3433 Answers
SOURCE: 2008 CTS - Key fob doesn't always open the doors
The battery may need replacing. I've experience the same problem and the battery was the problem. Good luck. Ned
Posted on Oct 09, 2009
  • 437 Answers
SOURCE: BMW 318i engine leak close proximity to Oil
Remember, the leak is detected at the bottom. Follow it to it's source.
Just like a roof leak, the water shows up where the roof meets the wall but the leak is way up above.
Posted on Nov 04, 2009
ERROR CODE MC COMM ERROR, MC COMM TIMEOUT
The out-feed Rollers will move all the way towards the machine to start. There's a stainless static bar with bristles on it right after that. If you have that upside down it stops the roller bar from getting to it's home position. This causes that alarm. To test remove static bar and hit "C" to reset. It should clear. You may have to push the roller bar in manually. If you remove the front plastic cover there are two gears on the right. One on top has a strip of metal that goes between a c shaped proximity switch. If that Roller bar is restricted it won't go into the proximity switch.
Jan 30, 2014 | Formax FD-280-20 High-Volume Tab Delivery...
Kyrocera hyro
A simple way to explain how Screen Proximity Safety works is by giving the phone the ability to turn the screen On or Off when the proximity sensor detects that the phone is near or far from the phone's surface to the user's ear. For example, when you answer your phone and hold it up against your ear, the proximity sensor will tell the phone to turn the screen off to save battery life and also prevent the phone from heating up the side of your head thus prevent overheating when your are on the phone.
Jun 29, 2013 | Cell Phones
We recently purchased a 2007 Veracruz Limited with a Proximity Key. We realized you didnt have to put the key in the ignition to start the car. However, now every time we open the door, regardless of how...
Hi, My 2012 Cadillac SRX did the same thing to me last year. I replaced the battery in the remote and it fixed the problem. The old battery wasn't strong enough to trigger the proximity sensor on the car. Click on link below.
I hope that will fix yours. HYUNDAI 5WY8740 EN Factory OEM KEY FOB Keyless Entry Remote Alarm Replace
Jun 25, 2017 | Hyundai Vehicle Parts & Accessories
Please assist me on how to set alarms to my Gps when i get close the destination i am heading to.
to create a proximity alarm for one of your waypoints is a very simple process. First you will want to create a waypoint for you destination. Be sure to name the waypoint something that will remind you of the destination. After this is done go to your main menu by pressing the "menu" button 2 times. Navigate to the "proximity" icon select it by pressing "enter" it will now allow you to create a proximity alarm select the open space and press "enter" it will now give you a list of items you can use select "waypoint" using "enter" and pick the waypoint you created earlier. now all you will have do is select a radius for thee alarm. You can also use the other items to create your proximity alarm such as cites addresses and any other navigation category.
Hope this helps!
Mar 15, 2011 | Garmin GPSMAP 76CSx GPS Receiver
1998 bmw 740 il will not start....lights, radio come on, doors lock and unlock, not sure why it won't strart seems to be locked, is it the alarm system?
Could be the alarm system, the key proximity sensor, etc.
But start with the easy stuff first, like the neutral safety switch, etc.
If it does not start in park, try neutral.
To see if the starter is ok, jump the large terminal at the solenoid, to the small solenoid energizing push on terminal. (make sure in park or neutral, and parking break engaged!)
It is possible to simply wire a momentary contact switch and bypass all the alarm stuff.
Jan 24, 2011 | 1998 BMW 7 Series
Screen turns black after making a call
Sorry to say this,This phone is named for this bug.This is a bug which is present in Samsung Memoir...The light sensor and the proximity sensor is being linked together in this phone.These two sensor works together based on their sensitivity.
But we can still solve this issue but it does not give 100% success to all.You have to change the proximity sensor settings in the phone.The proximity sensor is being located near the top of the phone where you keep the ear.Once you take it to the ear the accelerometer will detect the change in phone and the phone detects when it is in calling state and turns on the proximity sensor to detect it..So when you take it to ear or your body.the phone keypad will get locked and to save the battery the lights will get off.
Steps to increase the proximity sensor settings:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Dial ##77647269700 or try this #77647269700
It will ask for service code:Six zeros type '000000'
Now scroll down to field test and get into proximity call.
Take the palm or finger and show i near the holes 1/2 or 2 inch
away and press yes
Show it until you hear sound and say successful message.
Do this until your proximity detection less.
Hope this will solve it.If still problem persist take it to nearest service center.and ask him for the proximity settings.
Please do rate the solution if the issue is
resolved or post a comment for further
assistance.
thank you for using fixya have a nice day:-)
Aug 01, 2010 | Samsung Memoir SGH-T929 Cell Phone
Weird noise, picture, and nubers, what does it mean?
The only thing i can think of is that a proximity alarm is set for a point of interest. You will need to use the manual to switch off the alarm.
If it is a proximity alarm it will do it again at the same point on the road.
Peter
Feb 22, 2009 | Tomtom ONE GPS Receiver
Jan 23, 2009 | Omron E2K-C25MY1 Proximity Switch
Computers & Internet Logo
70 people viewed this question
Top Adaptec Computers & Internet Experts
Rommel Balcita
Martin Murray
Robert Graf
Are you an Adaptec Computer and Internet Expert? Answer questions, earn points and help others
