Question about Konica Minolta Copy Toner, 40000 Page Yield, Black
My machine minolta 4000 showing code c0700 - Konica Minolta Copy Toner, 40000 Page Yield, Black
  • Konica Minolta Master
  • 6,696 Answers
DId you open close the front door. if that does not work then take the toner bottle out. turn of the machine then turn it back on with no toner bottle in the machine. let the machine do its thing the machine will then ask to replace the toner at that time install the toner if that does not wok you have a problem with the toner motor and associated circuitry.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Sep 30, 2014
How to reset minolta 4000
Reset what sir/mam the machine for a code a password?
Jan 15, 2014 | Minolta EP4000/5000 CS/PRO Copier
Code error c0700
Open close the front door. If that does not work , power off the machine, remove the toner bottle, be careful if the hole is on the bottom when you pull it out toner is going to go everywhere. With bottle out and front door closed turn on the machine. Let it go through its normal warm up. If the code appears open close front door. When the machine asks for toner install the bottle correctly, if the nubs on the bottle are damage get a new bottle those nubs are what the toner bottle motor uses to turn the bottle. If the code still comes back you need either a new motor/sensor/or accurator worse case a new control board.
Dec 23, 2013 | Minolta EP4000/5000 CS/PRO Copier
C0700
I discovered the ELM327 presents code C0700 and should be presenting C0070. the problem relates to ABS system on right front wheel.
May 07, 2012 | Cars & Trucks
Minolta ep 4000 Copier shows: Call Maintenance M4
stop 0 stop1 sets the machine service mode. select consumable clear the copy kit counter
Mar 31, 2012 | Minolta EP4000/5000 CS/PRO Copier
Problem cs pro 4000 minolta code c400
exposure lamp the brigh light under the big glass section
open the front door, look to your left small cover remove thescrew with machine on press trouble reset if the code comes back see if the web site below has the lamp and or the circuit board that controls it
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Feb 17, 2012 | Minolta Office Equipment & Supplies
C 50
There is no C50 code on this machine. All Minolta fault codes on the 4000/5000 series machines are a letter followed by 4 numbers. So the code would be like C0050 or more likely C0500. Let us know the actual code so we can be of assistance.
Thank You
Sep 14, 2010 | Minolta EP4000/5000 CS/PRO Copier
Code problem
CALL THE NEARST DEALER OR GO ONLINE AND TYPE THE MANIFATURE NAME ONLY AND LOOK THREW THE LIST OF SUBJECT AND CLICK ON THAT LINK
ROD
Jan 29, 2009 | Minolta EP4000/5000 CS/PRO Copier
Copies shows: Call Maintenance M2
Hello, the error code M2 means that the machine needs to have maintenance done ( like tune up to a car).. The only way to clear it would be to reset the counters and the service tech mode.
Jan 07, 2009 | Minolta EP4000/5000 CS/PRO Copier
How to clear M2 on minolta EP 4000/5000 cs/pro copier pls send solution to michofolasenterprises@yahoo.com
clear web or drum count and developer,you will not effect the the machine aporation,by clearing count
Sep 16, 2008 | Minolta EP4000/5000 CS/PRO Copier
Konica Minolta Copy Toner, 40000 Page Yield, Black Logo
82 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
