Question about Hitachi (H3500U) 500 GB USB Hard Drive
What voltage is my hitachi h3500u
Lost the power cord. Look for a replacement. Any idea where to start. I'm not sure what the voltage is!
Is it ok to use the power cord from my monitor to power my hitachi 42 hds 69 tv
if the connections are the same as would be the correct voltage ===yes
a power cord is just a power cord and carries electricity regardless of the voltage
however if the connection at the power outlet in the wall is different then that suggest that the cable in questions is connecting different voltages to the unit than is allowed
Sep 08, 2017 | Hitachi Televison & Video
I lost the power cord to my "vintage fiber optic light" and would really like to use it. I don't know the voltage, so I can't even try to use another cord. Any ideas I what I can do?
If it is the type that has a cord, a power transformer and then the unit, look on the area where the power cord plugs into the unit. It ought to have the voltage, milliamps needed and the polarity.
If you have only lost the power cord, it just need to same type of plug.
Dec 11, 2016 | Office Equipment & Supplies
HITACHI HARD DRIVE MANUAL
The USB port powers the hard drive. It has no external power just the USB connector to the computer.
Jul 20, 2016 | Hitachi (H3500U) 500 GB USB Hard Drive
Where can I find replacement power cord and adpater?
what country you need to state voltage that come out of power point - is it 120 volt or 240 volt because it has to match with power supply check with seller before buying anything and definately before plugging it into a power point .
. Try amazon see http://www.amazon.com/Adapter-Supply-Charger-Dell-Printer/dp/B00L1WTFCA/ref=sr_1_fkmr3_2?ie=UTF8&qid=1404525964&sr=8-2-fkmr3&keywords=DELL+AIO+V313+ac+power+supply or search in google with Dell AIO V313 ac power supply
Jul 04, 2014 | Dell V313w AllInOne InkJet Printer
I have a boston acoustics speaker ba635 i have lost the power cord how can i get another one
try universal power plug sold at any CVS or Wallgreen start from lowest voltage and go up till it works make sure the plug matches and polarity
Mar 02, 2011 | Boston Acoustics MicroMedia Computer...
Can not get hp 1210 to start -power is getting to machine but it will not start..
Solution one: Make sure the electrical outlet works
  1. Unplug the power cord from the electrical outlet.
  2. Plug another appliance into the electrical outlet to make sure the outlet works.
    • If the electrical outlet does not work , plug the product into another outlet that does work.
    • If the electrical outlet works, but the product still does not turn on , continue to the next step.
Solution two: Make sure the power supply is compatible with the HP product
  1. Make sure the voltage and amperage specifications printed on the power supply match the voltage and amperage specifications printed on the HP product. Voltage and amperage specifications printed on the power supply Voltage and amperage requirements printed on the HP product c01962881.gif c01962212.gif In this example, the voltage (+32 V) and the amperage (2000 mA) from the power supply is compatible with the voltage and amperage specified on the HP product.
  2. If the voltage and amperage specifications between the product and the power supply are compatible, make sure the connector on the power cord is the same shape and color as the connector on the HP product. WARNING: Do not force a power cord into an HP product that is incompatible with the HP product (different shape or size).
    • If the power cord is not compatible with the product, replace the power cord with a compatible cord. To buy a compatible cord, right-click the following link, How to Buy HP , and then click Open in New Window .
    • If the power cord is compatible with the product, but the products still does not turn on, continue to the next step.
Solution three: Reset the power module and test the power Step one: Reset the power module The power module has a safety feature inside that protects the product during a power surge. If you experienced a recent power surge, the power module might need to be reset. Use the following steps to reset the power module.
  1. Unplug the power supply from the rear of the product.
  2. Unplug the power cord from the electrical outlet, power strip, or surge protector.
  3. If the product uses a power module with a detachable power cord, disconnect the cord from the power module.
  4. Wait 15 seconds.
  5. Reconnect the power cord to the power module.
  6. Plug the power cord back into the electrical outlet. Do not use a power strip or surge protector.
  7. Check to see if the power module has an LED.
    • If the power module does not have an LED, continue to the next step.
    • If the power module has an LED, check to see if the LED lights up.
      • If the LED does not light up, contact HP to replace the power module. To buy a compatible power module, right-click the following link, How to Buy HP , and then click Open in New Window .
      • If the LED lights up, continue to the next step.
Step two: Test the power on the All-in-One Follow these steps to test the power on the product.
  1. Reconnect the power supply to the rear of the product.
  2. Press and quickly release the Power button (c01602202.gif ) to start a Power On/Off cycle. Do not hold the button down. Figure 1: Press and quickly release the Power buttonc01896071.gif c01733891.gif If you press and hold the Power button too long, the product might turn on and then off without restarting. If this happens, press and quickly release the Power button (c01602202.gif ) again.
  • If these steps resolved the issue , there is no need to continue troubleshooting.
  • If the issue persists , see the next step.
Solution four: Test the power with a compatible power cord from a different product If you have another available power cord that is compatible with your product, use the alternate cord to repeat the steps in Solution three: Reset the power module and test the power .
  • If the product turns on with the alternate power cord, the original power cord caused the issue. Contact HP to replace the power cord. Right-click the following link, How to Buy HP , to buy a compatible power cord.
  • If the product does not turn on with the alternate power cord, continue to the next step.
Solution five: Service the HP productIf you have completed all the steps listed above and are still experiencing a problem, service t
Dec 01, 2010 | HP PSC 1210 All-In-One InkJet Printer
I lost my tv power supply cord my tv is 110-240 can I use a 10a 125V cord from my computer that fits in my tv (to replace the one I cant find)?
No,tries websites like Partstore.com,Amazon.com,Ebay.com to buy the right power cord.They're different cords tv power cord 110-240 voltages.The computer a/c power cord 10 Amp to 125 voltages.Don't try it,will burn somethings on the tv.
Sep 17, 2010 | Westinghouse LTV-27w7 7 in. LCD HDTV
I have lost the power cord and would like to know the replacement price
you dot necesarily need to buy a replacement, these power cords are universal and you should be able to use any other power chord from even a completely different device. PLEASE NOTE THAT THE VOLTAGE OF THE POWER CHORD MUST MATCH THE VOLTAGE OF THE SPEAKERS
Oct 08, 2009 | Kinyo SW-7352 Computer Speakers
DC power cord
You can finalize the DVD using a computer and a software like Nero.
To get a replacement power cord you can contact Hitachi using the number printed on the owners manual, or use the link below:
Hitachi DZ-GX5080A Battery, Camcorder Chargers, Adapters
Sep 05, 2009 | Hitachi DZ-GX3200A DVD Camcorder
Hitachi (H3500U) 500 GB USB Hard Drive Logo
64 people viewed this question
Top Hitachi Computers & Internet Experts
AJMAL KHAN
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
