Question about Kodak Office Equipment & Supplies
Agfacolor 50 projector
Where can i buy a lamp for the agfacolor 50 projector
    President:
  • Kodak Master
  • 412 Answers
Try www.bulbman.com or storefront "Batteries Plus Bulbs". With both suggestions, if they don't have it in stock, they can order it! Good Luck ! Jim
Posted on Apr 23, 2014
Where can I buy a main board for an Infocus SP7200 projector? The part number is 510-1720-3L-00
This projector, although its original retail price approached $7,000 was last shipped in 2005 and is obsolete. Parts are extremely difficult to find and a replacement lamp may cost more than 50% of the replacement cost for an entirely new 1000 Lumen home theater projector. I would suggest replacing the projector rather than attempting to repair it.
Dec 31, 2014 | InFocus Office Equipment & Supplies
Can we still buy a bulb for an Agfacolor 50 projector?
Most bulbs (regardless of vintage) can usually be found at a number of places: you can also try a retail chain called "Batteries PLUS Bulbs". The 3-letter ANSI code that identifies the lamp (can be found on the top of the old lamp, the base of the lamp or in the projector's manual) will make the search simpler. I just did a quick search on "Osram 64610" and found the code to be "HLX", 50 watt, 12 volt. Found a few on Amazon for under $4 each. Happy Hunting !!
Nov 19, 2014 | Office Equipment & Supplies
Can you replace the Bulb only instead of buying the whole unit, if so where do i get one from? many thanks
I don't believe that you can purchase this lamp as a bare bulb through official channels. It is an expensive lamp + projector and buying cheap copies is likely to be a risky business, definitely not supported by Barco. Prices seem to start at around £3500 GBP (ex VAT) or $5500 USD (ex TAX)
If you are in the UK, here are the 1st two suppliers I found
http://www.london-projectors.co.uk/projector-lamps.php?&brand=BARCO&model=SLM+G5+EXEC
http://www.jp-uk.co.uk/projector-lamps/barco/slm-g5-perf/barco-r9840740-projector-lamp.html
If you are in the US, again here are the 1st two.
http://www.amatteroffax.com/itempagey_invid_1366421801_d_premier-barco-oem-r98-40740-projector-lamp.html
http://www.advancedlamps.com/Barco-Genuine-OEM-R98-40740-Projector-Lamp?m1track=nextag&utm_source=nextag&utm_medium=cse&utm_campaign=export_feed&osCsid=bceddfd8470265866c6c1dd7172b765e#nextag
Given the fact that it is such an expensive lamp you should be able to negotiate a competitive price. I'd get on the phone to any potential supplier and ask them for their very best price rather than buying off the net.
Feb 15, 2011 | Barco SLM G5 DLP Projector
SANYO PRO xtrax MULTIVERSE PROJECTOR
Likely the projector has seem some hours on it before being sold second hand to you. A worn out metal arc lamp will wink out like this when it is at END OF LIFE. As the lamp operates, pressures build from high voltage arc current passing through the pressurized bulb. More and more voltage is required to keep the arc struck and operating as temperature rises. As the bulb ages, it requires more power to maintain the arc in the glass envelope bulb. It can rise to a point where it overruns the ability for the power supply in the projector to safely maintain the arc and it winks off, only the fan is left running. When the unit cools, the arc re-strikes and illuminates the lamp.
In short - replace the bulb, but buy TWO of them. One to fix the projector, the other as a spare on hand while awaiting another replacement bulb down the road. These metal-arc lamps typically run anywhere from 50 to 100 hours depending on power supply design and cooling ability of the projector as a whole.
May 10, 2010 | Sanyo PLC XU35 Multimedia Projector
What the model lamp for projector thomson 50dsz644
www.myprojectorlamps.com/rptvprojector/THOMSON/50%20DSZ%20644.html - United States
www.chooselamps.co.uk/search/projector-lamps/make/THOMSON - www.soundandvisionav.co.uk/.../THOMSON-50DSZ644--DLP-TV-UHP-Lamp-.html -
There are some links above.
Mar 24, 2010 | Thomson 50DSZ644 50" DLP Rear Projection...
Panasonic PT-AE900U Projector Lamp stops working (intermittent)
Could be a heat sensor, fan bearing issue..have you listened to the fan speed etc, But I think more along the lines of the lamp needs replacing..each time you resit it is thinking ah a new lamp and then realises hey someone is fooling me and shuts down...this scenario is doing you a favour as typically if it blew and shattered the glass it will inevitablly scratch the mirror and lcd block... and if it does that you might as well toss it in the rubbish or sell on ebay for $50 ..
Regards Kevin Andreassend, ICE AV Technology Ltd www.iceav.co.nz iceavtech@gmail.com
Apr 03, 2009 | Panasonic PT-LB10VU Multimedia Projector
Canon XEED SX50 Multimedia Projector - Poor light on screen
the canon xeed sx-50 should beside its noisyness give a brilliant bright picture. if not check if there ist something wrong with the lamp? is it aged? did you buy it used? the lamp counter can be easily reset... the only reason for a faint picture could be the lamp's age or tons of dust inside the matrix :)
best
Mar 22, 2009 | Canon XEED SX50 Multimedia Projector
Sony projector - replacement lamp counter
  • Set the projector in standby mode.
  • Press the following buttons on remote control in following order for less then five seconds each...
  • RESET,
  • ENTER
Lamp timer is reset now.
This is also mentioned in user manual page 50
Thank you.
Dec 12, 2008 | Sony LMP-H130 Projector Lamp Projector...
120 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
