Question about Saws
Performax bevel It's new out of box and can't get the bevel to release, is there something I need to loosen. It has a front lock 10"
5 Suggested Answers
  • 5 Answers
SOURCE: 10in sliding compound mitre saw
turn the bevel lock to counter clockwise
Posted on May 29, 2008
  • 299 Answers
SOURCE: 2000 avalon front caliper not releasing. new caliper not helping
Replace the hose, hose is damaged internally working like check valve.
Posted on Jun 19, 2009
  • 14 Answers
SOURCE: I have just gotten my Hitachi 10
the hndle at the front is for your mitre. there should be one at rear of tool to bevel (COMPOUND) IT SHOULD HAVE A HANDLE AS WELL possibly left hand thread !
Posted on Jan 05, 2010
SOURCE: My lock mechanism sticks when
if someone has sprayed oil in it. Locks do not like oil. use a contact cleaner to wash out the oil. let dry and apply Lock lube only. Put the lock back together making sure everything moves free and be sure all piece's go together with out being in a bind . the lock should preform great.
Posted on Dec 14, 2010
New Hitachi miter saw C10FCG can't get clamp lever to loosen to set bevel angel. Help?
I have a Bosch, and I am not really familiar with your model Hitachi. However, I do know that most compound miter saws have a locking pin that clicks in at frequently used settings like 90 and 45. This pin must be released (pulled out) before the bevel can be changed.
Nov 15, 2017 | Hitachi Saws
Bosch 10 duel compound saw won't bevel.
Be sure to release (pull out) the bevel locking pin.
Apr 29, 2017 | Bosch Saws
How do i assemble a stanley block plainer
1, Lay pencil on the table top, place body of plane with the front (toe) resting on the pencil, so the light passes beneath the front and middle of the plnes body.
2, lay blade, bevel side up, in to body of plane, ideally sharp end is sticking out of the mouth ever so slightly., 1/2-1mm.
3, Release the knob or lever cam on the lever cap and place on top of blade.
4, tighten knob/turn leaver till it tightens on the blade. and your ready.
5, If the blade isn't protruding the mouth correctly then:
6, Loosen a knob/lever a little to allow the blade to just move, adjust the blade forwards/sidways, lock it in place by re tighten the knob/lever.
Plane a thin piece of wood, re adjust as necessary till wafer thin shavings collect in the mouth ontop of the bevel.
Aug 29, 2014 | Bailey Stanley 12-920 - Block Plane
Clamp Lever - How to loosen and tighten to adjust bevel.
The 8mm bolt head, which is below the "stop plate"--- for olack of a better word-- is only to ALLOW ROOM to complete the swivel of the bevel-- ONCE THE CLAMP LEVER IS LOOSENED!! I neither have been able to loosen the CLAMP LEVER!! There is a large philips screwhead inside the handle of the lever, which I tried to loosen without much luck. I am very afraid to force that... ALSO, i tapped on the lever handle itself to see if it would unstick, but with no luck AND DIDNT WANT TO FORCE THAT EITHER!! So here I am online looking for answers again!!
Apr 15, 2014 | Hitachi C10FCE2 10" Compound Miter Saw
New hitachi miter saw can't loosen the clamp lever
Any answer to this question? We are having the same issue.im sure it's something I'm not realizing but need to get this thing unstuck
Apr 14, 2013 | Hitachi 12" Compound Miter Saw with Laser...
2004 avalanche tailgate lock will not unlock and the tailgate is up without access to the inside. The lock turns to the unlock position but does not unlock.
The lock mechanism is likely bent because the latch has become rusted or plugged with dirt. Lift the handle and spray lots of WD40 in the centre of the lock mechanism (under the fibreglass piece). You will need to manually open the lock with a long screwdriver. Look to the right of the latch mechanism you will see something that looks like a C. Use the screwdriver to lift that piece up. That should unlock it so that you can open the tailgate. When it's open, you'll have to use a torx screwdriver to unscrew the outside two torx bolts and then remove the plastic bevel which surrounds the latch handle. There will also be two plastic pins holding the bevel onto the tailgate. You may have to gently pry those pins loose with a screwdriver. When the bevel is off, the lock will come with it. Check the lock to see that the little metal lever is at a straight right angle. If it is bent you will have to straighten it with pliers and then reattach the bevel. If the metal lever is broken, you will need a new lock.
Jun 27, 2010 | 2004 Chevrolet Avalanche
My saw is really stiff when you try to change the angle .I oiled it but this didn't help. I would like to know how to take it apart but I am un sure how to do it and what is in the boxed off area...
Exploded diagram with parts list for LS1016 10" Dual Slide Compound miter saw is here.
Owner's manual is here. If these aren't quite what you need, you can view other models of Makita miter saws, here.
One thing to bear in mind. There's a miter angle lock and a slide lock on the bottom front of the saw. If you don't have the miter angle lock loose enough, it will be difficult to turn the saw.
If this answer was useful, please vote for it. Thanks!
Apr 14, 2010 | Makita 10" Dual Bevel Sliding Compound...
I have just gotten my Hitachi 10'' compound mitre saw (C10FCE2) out of the box, and have disengaged the packing pin, and put on the stabilizion bar and handle. I can not seem to get the blade to tilt back...
Jan 04, 2010 | Hitachi C10FCE2 10" Compound Miter Saw
How do I change the transfer belt unit in a magicolor 7300
moz-screenshot.jpgmoz-screenshot-1.jpg1- power off the printer and make sure the indicator is not red.
2- Remove the drums and waste box
3- Remove the front door by sliding it left after releasing the two stoppers (turning them 90°) and sliding the left hinge to the left (after loosening a screw).
4- Release the green Synchronozing Roller lock levers (2).
Release the black Secondary Image Transfer lock levers (2).
Release the green Secondary Image Transfer lock lever (2).
5- release the sensor assy by turning it 90° and loosen two screws to release the belt.
6- You can now pull the belt out of the printer and replace it with a new one following the reverse procedure.
Oct 09, 2008 | Konica Minolta Office Equipment & Supplies
Saws Logo
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
