Question about General Electric CSHS5UGXSS Stainless Steel Side by Side Refrigerator
Ge side by side getting warm
Freezer down to 29, fridge to 43. Something turning on and off.
  • General Master
  • 5,323 Answers
FREEZER /FRIDGE NOT COOLING: Optimum refrigerator temperature at or below40° F(4° C). The freezer temperature should be0° F(-18° C). Check temperatures periodically. Appliance thermometers are the best way of knowing these
Check ur cold control thermostat, ur thermistors in both fridge and freezer ( they should be checked for both ohms and for amount of current being put out as per ur model ), ur air flow vent from freezer to fridge.( to make sure it opens and closes without any restrictions) On thermistors check for A close circuit and amount of ohms not just an Ohm reading. As per ur model. Most should atleast show 1200 ohms. Also Check door seals for leakage.
Evaporator coils
Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
FAN check to see if it is operating or restricted A fan that is not blowing or restricted will not circulate the cold air properly.
Often, the first thing that folks do when their refrigerator starts to feel warm is turn both controls on the coldest settings.This is exactly the WRONG thing to do.Turning the cold control to the coldest settingwillkeep the compressor running longer and make lots of cold air.
But turning the air door to the coldest settingclosesthe airway to the food section. Lots of cold air is made, but most of it stays in the freezer section, and the food section actually getswarmer.
Condenser
Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
May also need to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
THE COMPRESSOR:
If you hear a clicking sound coming from the back of your refrigerator/freezer, then the problem is most likely the compressor, relay and or capacitor is overheating or not getting proper power and will not start.The compressor is the component on your refrigerator that allows your refrigerator to cool. If this component is not working properly your refrigerator will stop cooling. Most of the time the compressor is not the component that has failed.
To check ur compressor with multi meter:
Disconnect and remove the relay and capacitor from compressor, some located next to compressor in a casing.
You wills see 3 prongs coming out of compressor. 1 goes to ur srtart winding, 1 goes to ur run winding and the center goes to ur ground.
Place ur meter connector or prong on the start prong and the other on the ground (center prong) take note of the reading in OHMS for example 5 ohms.
Next place meter prong on run prong and the center ground prong agin. Take note of the reading in OHMS. Example 4 ohms
Next place meter prong on the start prong and the other on the run prong, now take note of the reading example 9 ohms. Now match the total of this ohms test with the total of ur two separate test. 9 ohms, if they match ur ok give or take 5 percent plus or minus. One more test to make to test of there is a short in compressor attach meter prong to ground prong and rub the other end of meter prong to metal ( scrape the metal clean of paint and test on metal surface not painted surface. If it shows continuity or ohms , u have a short in ur compressor. It should show infinity
Lastly you should also check ur THERMISTORS in the freezer and fridge section for continuity OHMS and for amount of OHMS current being put out. In most models around 13000 ( give or take 150 ohms) ohms is required.
Read more:http://removeandreplace.com/2013/10/31/fix-refrigerator-freezer-wont-cool-freeze/#ixzz3WDEo5NDJ
REMEMBER GOD IS THE REASON FOR GOOD ADVICE"
ge side by side getting warm - 23896468-fvsmv4etqgwauuwz5eop31ms-5-9.jpgges/23896468-fvsmv4etqgwauuwz5eop31ms-5-9.jpg" alt="23896468-fvsmv4etqgwauuwz5eop31ms-5-9.jpg" ge side by side getting warm - 23896468-fvsmv4etqgwauuwz5eop31ms-5-14.jpgttp://i.fixya.net/uploads/images/23896468-fvsmv4etqgwauuwz5eop31ms-5-14.jpg" alt="23896468-fvsmv4etqgwauuwz5eop31ms-5-14.jpg" class="h_mi" />
Posted on May 06, 2015
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
Hi our ge refrigerator has freezer on top its freezing but not keeping foods cold in fridge.fridge is warm and theres two holes in fridge on top that keep freezing up.what should we do?
by the number on the refrigerator its a side by side,if the freezer is actually on top,then remove rear cover inside the freezer and the drain hole in the freezers plugged with mold take a wire and rat out this hole to get water to flow down the hole again
Aug 07, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer temp on GE profile French door fridge was rising rapidly. I believe I did not shut the freezer door tightly after retrieving something about 9pm. Outside of freezer on sides of fridge was very...
This is by design. It should be warm. This is where the heat exchanger is located to save space.
No worries.... right now it is being over-worked until it reaches operating temp.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 05, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Side by side fridge freezer warm on upper levels
the cold coil is in the freezer side at the bottom . the fan moves the air over coil . ck that your fan in freezer is working . mm
Apr 19, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Coils freeze up in freezer and fridge gets warm
You have to completly thaw out the the freezer and dry off all moisture with paper towels then turn back on be sure to wipe the rubber seals down so no moisture is pulled out of the air between the seals of the door and cabnet.
Oct 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Monogram will not accept freezer/fridge
Turns out the problem was because we didn't shut the freezer door tightly. The temperature re4set itself in about three hours. All OK and no expense :-)
Jun 05, 2009 | GE Monogram® ZISS420DMSS Side by Side...
Freezer is ice cold, fridge won't cool lower than 42*
Sounds like it's not defrosting, so unplug open freezer back panel and use a hair dryer to melt ice from evaporator coil. Your refrigerator has a defrost timer on bottom near floor, but if freezer is frozen we need to defrost it so we can make sure there is not some other problem. Let me know when you are ready, Sea Breeze
Apr 22, 2009 | Refrigerators
Ge Fridge not cooling
Make sure that the light in the ref side is not staying on when the door is closed. Could have a bad door switch. Probably have a defrost problem in the freezer. Check to see if there is a lot of frost build up on the inside/back of the freezer. If there is then you have a bad heater or defrost thermostat or a bad timer. Also another possibility is make sure the freezer fan is working. If there is no circulation of air then the fresh food side will get warm. Then replace evaporator fan motor.
Apr 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile Side by Side is getting too cold on the fridge side.
I have a GE refrigerator with the same problem of my food freezing in the refrigerator. I spoke to an appliance part person and they sold me a temperature sensor for 20 bucks. They said it would be located in the control panel, but I took the control panel off and can't find the sensor. I'm now looking on yahoo answers to find out where the sensor is located.
Mar 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile- Freezer/ Fridge at 56 wont go cooler!
check freezer for frost build up and if fan is blowing, check condenser, make sure its clean, and fan blowing, check vents in refrig. make sure no blockage, controls should be in the middle setting, check make sure compressor is running
Aug 25, 2007 | GE Profile PSW26P Stainless Steel Side by...
General Electric CSHS5UGXSS Stainless Steel Side by Side Refrigerator Logo
63 people viewed this question
Top General Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Shehu Pro
Shehu Pro
Are you a General Refrigerator Expert? Answer questions, earn points and help others
