We own a Maytag Bravos Quiet Series 300. Model number MVWB450WQ1 and the add a garment light will not go off.
I have tried to unplug washer and restart. That did not help. I have tried different amounts of clothes in machine and the light still won't go off.
    Master:
  • 966 Answers
Did you try adding a garment? Try that because it may reset after you add.
Posted on Mar 24, 2014
Testimonial: "Yes, I tried different amounts several times. I tried to start a load and it won't do anything except hum and the add a garment light stays on."
5 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: My Maytag Bravos quiet series
Hi and welcome to FixYa, I am Kelly.
My response is very long and will be in 2 parts this is PART 1
Here is what the service manual says about Ld:
"Ld" (Washer is taking too long to drain
water from the wash tub)
Check the following:
Is the drain hose kinked or clogged?
Is the drain hose installed properly? See
"Connect the Drain Hose," page 2-5. Press
PAUSE/CANCEL to clear display
Also:
Is the drain hose clogged, or the end of
the drain hose more than 96? (244 cm)
above the floor?
See "Drain System," page 2-3.
6. To remove the drain pump: (there are 2 pumps... the drain pump is on the left)
a) Loosen the clamps and pull the inlet
and outlet drain hoses off the pump.
Note that there is a tab on the outlet
connector that fits into a slot in the
hose.
b) Remove the three 5/16? hex-head
screws from the drain pump and remove
the pump from the tub.
Check the pump inlet and the tub outlet for obstructions.
Pump electrical winding resistance test:
-Disconnect the wire connector from the
drain pump terminals.
- Set the ohmmeter to the R x 1 scale.
- Touch the ohmmeter test leads to each
of the drain pump terminals. The meter
should indicate between 10.5 and 14 ?.
----Due to the design of the machine the 2 wires going to the drain pump have be notorous for backing out of the plastic connector. Check the connector of the pump for loose terminal connections. --
From the Ld troubleshooting steps / procedure:
Long Drain
Ld flashes when the water level does not change after the drain pump is on.
• Is the drain hose or the drain pump clogged?
• Is the drain hose height greater than 96? ?
• Is the pressure hose connection from the tub to the machine/motor control pinched or plugged?
• Is the pump running? If not, see TEST #7.
TEST 7
TEST #7 Drain/Recirculation
Perform the following checks if washer fails to drain or recirculate.
1. See Activation of Manual Diagnostic Test
Mode, and perform the Manual: Pumps
test.
2. Remove the console to access the machine/
motor control assembly. See Accessing
& Removing the Electronic Assemblies.
3. Visually check that the P4 connector is
inserted all the way into the machine/motor
control.
If visual check passes, go to step 4.
If visual check fails, reconnect P4 and
repeat step 1.
4. Remove connector P4 from the machine/ motor control and check resistance values of pump motor windings. Resistance values should match those shown in wiring diagram, page 7-1.
If resistance values are good, go to step 7.
If winding measurements are much higher (tens of ohms to infinity) than shown in wiring diagram, a problem
exists in the motor winding or in the connection between the machine/motor
control and the motor. Go to step 5.
5. Tilt machine forward to access the bottom
of the machine and the pumps. See
Figure 1, page 6-13.
6. Check the resistance at the pump motor. Remove the connector at the motor and
take measurements across pump terminals. Measurements should be as shown in the wiring diagram.
If winding measurements are much higher (tens of ohms to infinity) than shown in wiring diagram, replace the
pump motor.
If the resistance at the pump motor is correct, there is an open circuit in the wiring between the motor and the machine/
motor control. Repair or replace the lower wiring harness.
If the pump motor windings and machine/ motor control check OK, repair or replace the pump. Be sure to check
the pump and tub sump for foreign objects before replacing pump.
7. See Activation of Manual Diagnostic Test Mode, and perform the Manual: Pumps test.
8. If the Manual: Pumps test failed, then the machine/motor control has failed:
Unplug the washer or disconnect power.Replace the machine/motor control assembly.
Perform the Manual: Pump test.
Posted on Nov 21, 2010
KevinWhite
  • 1902 Answers
SOURCE: have a maytag bravos quiet
Hello & Welcome to FixYa
Ld means long drain and is displayed when it takes longer than 5 minutes to pump out the water to a point where the pressure switch resets. To solve this problem make sure that the drain filter pump assembly located inside the bottom front panel is clean and after cleaning if the error returns then the pressure switch needs to be tested and if bad then it needs replacement. Please get back to me if you have any other questions.
Kevin
Posted on Jun 25, 2011
TheMobilian
  • 8220 Answers
SOURCE: MAytag Bravos Quiet Series 300 washing machine
F-51 RPS senses rotation when basket ought to be stopped.
It is probably loose or worn out.
Video How To
Posted on Oct 22, 2011
richroth
  • 9472 Answers
SOURCE: Maytag Bravos Quiet 300 Auto. washing machine won't wash, DL code appears. Also, the 'add a garmet' light won't turn off. How can I fix the problem?
What is the model number?
Posted on Oct 31, 2012
Maytag Bravos quiet series 300. Hate it. Prior owners of house didn't leave manual. Once unbalanced can't get it started.
This is not a well rated washing machine (Maytag, right?). Anyway, I have provided a link where you can download the manual (you will need the exact part number). This link shows you what to look for on their machines. Customer support phone numbers are also listed and they will be able to help you better than I can. Have you tried rebalancing your load? Sorry, had to ask.
https://www.maytag.com/services/contact-us/find-your-model---serial-number.html
Dec 07, 2017 | Maytag Washing Machines
I have a maytag bravos quiet series 300 dryer with the error message f73. What does that mean?
Maytag Bravos 7.0 Cu. Ft. Electric Dryer F73 - Questions ...
www.fixya.com/search/p688923-maytag_bravos_7_0_cu_ft.../f73
have a bravo dryer , wont start shows error code f73 ? lights come on but dryer ... I think there was an F73 or F93 error message but we did not write it down.
Sep 22, 2015 | Maytag Dryers
MAytag Bravos Quiet Series 300 washing machine starts to fill, stops and shows code F51
Video How To
Oct 22, 2011 | Maytag Bravos 3.8 Cu. Ft. Washer
My Maytag Quite Series washer is making noise on the spin cycle.
Perhaps a wire from a garment has got between. Remove the tub and look.
Bravos service manual
Aug 23, 2011 | Maytag Bravos 3.8 Cu. Ft. Washer
Washing Machines Logo
245 people viewed this question
Top Washing Machines Experts
