Question about Mitsubishi WS-55313 55" Rear Projection HDTV-Ready Television
Won't turn on light comes on right back off
Went turn on right back off
I go to the store. Turn truck off. Go inside and come back outside and the truck won't start. Wait about 20 minutes and truck starts right up. This has happend 3 times in the last week. This morni
usually this is a cam position sensor I have found this problem many times by replaceing the camshaft position sensor I believe this will solve your problem if this is helpful please leave good feedback
Apr 13, 2013 | Ford F-150 Cars & Trucks
Truck will crank but it won't fire.
My guess would be the key switch.
Jul 08, 2012 | 1997 Chevrolet S-10 Pickup
I started sewing and my machine just went black and stopped. It won't come back on. There is no sound, no lights, nothing. What can I do?
it's possible that either the computer motherboard went out on it.
since it's a janome computerized sewing machine I would suggest
having it serviced to see what's wrong.
Apr 17, 2012 | Janome Memory Craft 9000 Computerized...
I replaced the bulb worked fine for a week now it won't turn on
All these sets if they do not come on will have a light or lights on the front blinking -----which are blinking?
Also it might be a smart idea to remove the lamp you installed and have a look at it to make sure it went into the socket right where the plug on the back of the lamp is--I always suspect when a issue happens shortly after a part has been replaced.
Mar 19, 2012 | Mitsubishi Televison & Video
Replaced stock bcm with used. Was reprogramming with the method of turning key to start position (vehicle won't start) then leaving it in the on postition for approx 10 minutes until the theft lock...
A used body control can be used in a vehicle other than the vehicle it was installed in. the body control module when first installed is programmed with the vehicle vin number. the vin number can not be changed was it was written to the BCM. the oprions can be always change in the BCM but not the VIN number. basically the used bcm you have installed has the vin number from the vehicle was installed in, now the vin number in the used BCM doesnt match all the other control modules
Jun 07, 2011 | Chevrolet Equinox Cars & Trucks
My BB pearl won`t turn on, first the screen went white
You can re-charge your battery fully by the provide electrical charger for 6 hr , then you can try and send me status.
Jul 22, 2010 | RIM BlackBerry Pearl 8100
Left signal lights wont shut off all back running lights off
sounds like a turn signal switch on the column
Apr 04, 2009 | 1997 Eagle Talon
WON'T START
my 2006 pt cruiser won"t start. the light do come on but it will not turn over just a clicking sound. i drove it for about an hour then went back to it 30 mins later and it didn"t start. just clicking sound.
Sep 21, 2008 | 2006 Chrysler PT Cruiser
Open Questions:
See all Mitsubishi WS-55313 55" Rear Projection HDTV-Ready Questions
Mitsubishi WS-55313 55" Rear Projection HDTV-Ready Television Logo
50 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
