Question about Ice Cream Makers
Taylor 345 27
Code to get into service screen
I have a taylor ice cream machine thats keeps a constant beep even when ice cream is ready model 339-27
I'm not 100% on this model but here goes....
A "beeping" tone will sound to alert you
of a fault.
To discontinue the tone, access the Operator
Menu and enter Option B. Correct the fault, then press
the OFF (<--) key, and the tone will stop.
FYI Fault Description
(Option B)
This option lists any faults detected by the control and
allows the operator to clear them from the system.
When a fault is detected it will be displayed on the
second line of the LCD. Pressing the MENU/SEL key
will display the next fault found or return the display to
the Operator Menu if no additional faults exist. If the
OFF key is pressed when a fault is displayed, all faults
that have been corrected will be cleared from the LCD
upon returning to the Operator Menu. To return to the
Operator Menu, press the MENU/SEL key.
for 337.....
Screen display.....
The POWER SWITCH OFF screen indicates that the
power switch is in the OFF position.
POWER SWITCH OFF
The normal operating screen will display the current
mode of operation and the level of mix in each mix
hopper. (The power switch is in the ON position.)
MODE: OFF
MIX:
L = OK
Operator Menu
_________________________________
The Operator Menu allows the operator to access
operational information and to set non-critical
functional parameters. The Operator Menu also allows
access to the Service Menu. (Note: Only service
technicians who know the access code may use the
Service Menu.)
Operator Options
A
Exit From Menu
B
Fault Description
C
System Information
D
Current Conditions
E
Service Menu
Pressing the OFF (<--) key will move the cursor one
position to the left. Pressing the STBY (-->) key will
move the cursor one position to the right. Both keys
include the "wraparound" feature. This means that
when the cursor reaches the end of the option, any
further movement in the same direction causes the
cursor to "wraparound" (to be placed at the opposite
end of the option listing)
here's the manual if you don't have it....
http://www.taylorfreezersales.com/op_man/0337op0.pdf
Best to you hope this helps a little
Mar 05, 2018 | Taylor Ice Cream Makers
Lost instructions for ice cream maker sunbeam gel canister
Can you flip over the unit and get either a product code or a model number off of the unit so I can find the correct manual please?
Here is why:
http://www.sunbeam.com.au/support/instruction-manuals
If you find the product code enter it on the link above and download the manual. Otherwise I need the product code or model number to search other sunbeam sources please.
Thanks,
Kelly
Aug 06, 2011 | Gel Canister 106765 1.5 Quart Ice Cream...
Where can I find a repair man for Taylor Frozen yogurt machine? I live in Los Angeles, CA zip code 90024.
Call toll free number 1-800-665-1125 or www.dslinc.com and they will tell you who you can get in your area. The name of the company who services Taylor is DSL
Apr 09, 2010 | Taylor 632-27 Ice Cream Maker
Taylor 8756. Electrical service too high???
As a general rule, most unit can handle a voltage of =/- 10% of rated voltage. I would call Taylor to be sure. You can get a "Buck and Boost" transformer that would lower the voltage but you may not need to.
http://www.taylor-company.com/
Go to this web site and look up your local distributor or contact them directly.
Mar 20, 2010 | Taylor 632-33 Ice Cream Maker
Ice Cream Makers Logo
43 people viewed this question
Top Ice Cream Makers Experts
ray gallant
Ruth summersides
Are you an Ice Cream Maker Expert? Answer questions, earn points and help others
