Bush id dv3 TV
HOW TO CONNECT A HDMI CABLE
  • 374 Answers
SOURCE: connection to TV by HDMI cable
The 625 is not a high definition receiver and therefore does not support hdmi. You can use RGB or S-video to provide a higher quality picture than the coax output. If you need more options let me know. Thanks for using Fix Ya.
Posted on Mar 06, 2009
  • 441 Answers
SOURCE: LG HT502 wont recognize hdmi cable. it says hdmi
go into the video setup menu, and select HDMI set up and select "ON" that should do it
Posted on Jul 15, 2009
SOURCE: Bush iD HDMI 37inch tv hdmi problem
There should be a Zoom button on your remote control (Around the Teletext area, the word "WIDE" is below it) Select 'Zoom 1' and the TV Will display true 1920x1080 for your PC...
This is not a problem of any sort... for some reason the TV is defult to 'Zoom 2'
Peice of Cake.
Posted on Nov 07, 2009
SOURCE: I have connected my Bush DS-A332B dvd player to my
I have same problem sound but no picture, have tried it on 2 different tv's but no luck, have tried 2 different hdmi leads (both Bush 26602bu) but no luck. I even thought it was the port on my tv but it works fine with another dvd player and the same lead. I even returned the dvd player and exchanged it, still the same... It's driving me nuts...
Help please......
Posted on Dec 28, 2009
  • 132 Answers
SOURCE: I'm using receiver AVR 2309 and now I would like to connect my cable TV set top box which has HDMI port with this receiver. Which HDMI port (DVD/HDP/VCR or V.AUX) on this receiver should I connect
The DVD/HDP/VCR port will give you the high definition sound properties. If not then connect the set top to your receiver via RCA cables... red/white/yellow
Posted on Jan 12, 2012
Testimonial: "Thank you very much."
I have a bush tv and I can put 1 him cable in to connect my sky had box but when I try to put a second one in for my ps4 it's say hdcp is not supported can someone help.
Try fitting cables in a different orderor swapping the working sky conected cable to the ps4 cable. I have several hdmi and scart cables into my LG tv. Sorry but can't help more as I don't have sky or a ps4
Oct 28, 2015 | Bush Televison & Video
Bush id dv3 hdmi sound no picture
Check whether its back-lights are ON. If not, check and replace damaged components. In most cases, back-light inverter boards are found faulty. Try this link. http://electronicshelponline.blogspot.com/ There are more than two thousand and five hundred posts. All are related to television and other domestic electronic equipment service help.
May 20, 2013 | Televison & Video
How do I tune a DV3 set top box to my TV
The best way would be to connect your DV3 using an AV cable that way you don't have to tune your TV. If your TV has an AV input at the back ( Yellow / Red / White ) all you need is a AV cable and connect the DV3 to the TV using this cable and select AV1 or AV2 according to which socket you have connected. This way you bypass the TV tuner and get better picture and sound form your cable service.
Aug 27, 2011 | Televison & Video
No sound, picture ok, volume nil
What cable u are using?Like a RCA AV component cable or a HDMI cable?Tries another AV holes in the tv,if use a HDMI cable tries another HDMI hub on the tv.Or replaced with it the new RCA AV component cable or a HDMI cable.
Feb 10, 2011 | Bush DVD2038 DVD Player
I have connected my Bush DS-A332B dvd player to my Sharp Aquos 32GD8E 32 inch flat screen TV with a Bush HDMI cable (26602BU) but can only get sound and no picture. The cable is slotted into Ext 5 yet when...
Help please......
Sep 14, 2009 | Televison & Video
turn laptop on when the hdmi cable is in it not after laptop is on
Sep 03, 2009 | Televison & Video
PS 3Not connecting to HDMI
Connect the PS3 using another cable then go into the menu setup and make sure that the resolution is set to a level your tv can handle. Start with 480p and go up from there. I would imagine BUSH (never heard of it) isn't the highest quality tv so you have to make sure it can handle the signal. Start with that.
Mar 03, 2009 | Onkyo HT-SR800 System
Poor signal bush hd set top box
I have a saterllite reciver just bought a bush hd freesat top box i am running my virgin cable tv through my samsung hd television i put my satallite cable in to my bush top box connect the hdmi cable to get the freesat turn my virgin box off source the hdmi cable on tv get the freesat logo but nothing else what am i doing wrong
Aug 31, 2008 | Televison & Video
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
