Question about Kenwood KSC-WD250 Car Subwoofer
How does a self amplified sub work? Does it still need to be hooked up to the car battery?
  • Raymond Ramirez
    Raymond Ramirez May 11, 2010
    yes it does... you should have a positive and negative lead for it
  • 32 Answers
Obviously!! every thing takes power
Posted on Jun 14, 2009
Subs wont turn on
make sure there is correct wattage with the subwoofers and the power supply
Dec 07, 2013 | Sony Xplod XM-554ZR Car Audio Amplifier
I just installed my 10 inch square pyle sub and its hooked up to the dub amplifier..the amplifier is in safe mode and the subs woint hit..what do i do to fix this?
ok if the amp was in safe mode before the sub was hooked up then the amp needs to be fix , make shor the suds are hooked up right an the wires arent touching , the amp is in pro mode so there for u have to find out more on why the amp is not working or let me know what is goin on with it ,
Jul 19, 2011 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
I have a Korean JARGUAR SUHYOUNG PA-203XG stereo mixing amplifier. I can find any label on the back of it to tell me where to hook up my power subwoofer to this amplifier. Please help! Thanks
The unnamed sub itself would dictate what you need to feed it.
Many self-powered subs accept either Line Level or Speaker Level inputs.
You should look at the manual that came with your sub.
Should it need Line Level, you could replace those jumpers with RCA-cable splitters and share that signal with the internal amp and the Sub amp. If the Sub Amp accepts Speaker Level input, use that.
Mar 28, 2011 | Audio Players & Recorders
Sub cutting out
Check the 12v wire running from the battery to the amplifier. Also the sony explode is a garbage subwoofer compared to the Alpine.. sony (they say 1200w max but its more like 100w to power the thing) Amp could be going. Is the amplifier hot when running. If there is a burnt smell comming from the amp, its the amplifier
Mar 27, 2009 | Alpine Type-R SWR-1222D Car Subwoofer
Amp powers on but sub does not come on
I would double-check your RCA's on the amplifier. You should hear a thud if you unplug them. If not they are either not hooked up or defective.
Feb 07, 2009 | Sony XM-2150GSX Car Audio Amplifier
KAC-9102d no sound, Amp powers on but no sound to the subs.
If the sub isn't working, you won't get a pop. All you need is a small speaker. Don't need a sub, you just want to test the sound. I recently blew 2 subs, no smoke, no smell, no sign of being blown. Absolutely nothing from the subs.... In the past my sub locked up. You can take your sub out of the box and hook the + and - to the battery to see if you can get the sub to pop there. I believe a small box will push a sub into a deep excursion to the center of the cone. I have 2 lanzar VW12D's that just quit. I hooked a 6 x 9 up to my amp and low and behold I had sound! Try that and see what you get...
Feb 07, 2009 | Kenwood KAC-9102D Car Audio Amplifier
One speaker is working more than the other
I would replace the wire your sub is hooked up to and try hooking up the sub that was sparked to the opposite channel on the amp to make sure the amp is not the culprit. Also switch RCA cables L to R, R to L
Feb 02, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Car system
if you have dual voice coils connect on each seporate sub negative left channel to possative right channel of the subwoofer same to other sub then conect the left possative and the right neggative to your box power terminal same to other sub then conect the two sub outs on your box left speaker positive to your positive left channel bridge then conect left speaker negative to the right speaker possative then connect your right speaker negative to your right channel negative brigdeg to your amp is single coil hook the box its self up the same way to your amp i have two dual voice cooil 12" hooked up to the same amp that way and it rocks without the power protecter turning on
Nov 09, 2008 | Pyle PLA2200 Car Audio Amplifier
Car Audio & Video Logo
167 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
