Question about Husqvarna Garden
My spring break is broken,how do i put the new on?
It wont go forword or backward springbreak is broken
  • Husqvarna Master
  • 2,478 Answers
On what? Most drive springs hook idler bracket to right side of frame.
Posted on Mar 24, 2014
Tractor wont stop when forword pedal is released.Must hit brske
there might be a spring off or pedal needs adjusting
does it have a neutral that works correctly?
if so adjustment is ok check springs
Oct 17, 2015 | Husqvarna Fast Tractor YTH24K48 48" 24HP...
Need to redo pull starter spring
Normally the spring doesn't just sprung, it usually breaks. The springs on these engines are bent backwards on both ends so that they catch on to pieces on both the housing and the starter pulley. I would need to see a picture of the unit you have so that I know which screws to tell you to remove. Homeline trimmers are the cheapest on the market and they are very hard to get parts for. Some times if the spring is broken at the ends, we can heat the spring up until it is cherry red and then put a new bend in it and it will work fine. Other times this will not work. Just depends on the unit or where the break in the spring is. If you try and bend the spring with out heating up the metal, you will just break the spring again. So be sure to heat the spring up with a lighter or propane tourch.
Sep 24, 2012 | Homelite Mighty Lite Lawn Trimmer
In game, psp thinks i am pushing back on analog stick when im not
Your Analogue Stick may be faulty because what you are describing appears to be a hardware issue. If your casing is old and/or broken I recommend replacing the housing or replacing the analogue stick to the bottom left hand side of the console. you can order these parts of Ebay and the housing will take 40 minutes to an hour to replace and the analogue stick should only take 10 minutes to replace.
Jul 25, 2010 | Sony PlayStation Portable (PSP) Console
Motor runs backwards (forword is reverse-reverse runs forword)
is this an electric motor? if so, you can just switch the polarity around. meaning connect positive to negative and negative to positive. hope this helps!
Feb 17, 2010 | Boating
My driver's seat slides and does not lock into place. I can't figure out what replacement part I need to fix this issue.
the seat is on a track when u move the handle latch forward or backward a long wire and spring do the same on other side of seat if wire or spring break/or disconnect seat wont lock into track
Feb 08, 2010 | 1999 Chevrolet Silverado 1500
I have a 2003 dodge durango and the transmission
are there any DTC's if there is It is likely the selonoid valve assembly if not then it is likely in the valve body and easy to fix.
had the same problem it was a broken OD accumulator piston spring in the valve body. Just buy a transco SK 45RFE shift kit it comes with all the accumulator piston seals an updated and much thicker and stronger accumulator retainer plate AND the kit includes a "spare" set of accumulator springs (1 large & 1 small) in case the spring(s) are broken ,which they do from timt to time. It is only 6 bolts to remove the valve body (carefully) and 7 screws to remove the accumulator plate to access the accumulator pistons and springs. The instructions included in the kit are excellent and very straight forword, you won't need all of the parts but save them they may come in handy some day later.
Sep 08, 2009 | 1999 Dodge Durango
Break lights wont go off
brake light switch little spring inside it is weak stuck or broken.
Apr 11, 2009 | 2000 Chevrolet S-10
My 2002 dodge 1500 p/u transmission only shifts 1st&2nd when going to 3rd transmission acts like in neutral &service engine lite came on
I had the same problem. I replaced the govener sensor and the govener sensor solinoid and it sovled the problem. It cost me $228.00 for parts and it took me 45 minutes to do it myself.
Aug 30, 2008 | 2000 Dodge Ram 1500 Truck
Garden Logo
70 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
