Question about John Deere 42 in. EZ Trak Bagger
John deere 17hp kohler
No fire to plug died imediate restarted once after rengauge of blade then died.
    President:
  • 1,627 Answers
YOU MAY NEED A NEW SEAT SWITCH OR THE PARK BRAKE SWITCH IS EITHER ENGAGED OR IT IS DEFCTIVE.
Posted on Oct 11, 2009
    Scholar:
  • 81 Answers
Make sure your electronic ignition (modular, coil, or whatever you want to call it) is not the problem. Check this by replacing old plug with new (I'm sure you already did this), but before putting the new plug in connect it at the top to the ele ign wire, then lay it on the machine or any piece of metal, (screw driver will do) then try to start the engine. Watch to see if you have fire between the spark plug and the metal. If not it is the ele ign that isn't any good and must be replaced.
Posted on Jun 15, 2009
Where can i find the oil drain plug on kt17 kohler motor
look for a pipe that has a plug in the end or a pipe cap .
Oct 04, 2017 | John Deere Garden
John Deere 214 with Kohler K321
Check carby is not to rich,"mixture screw" check for fuel blockage on fuel tap.
Sep 27, 2016 | John Deere Garden
Need Drive Shaft for JD 317 with 17hp Kohler engine, 1981 year bought
The I had I just replaced the U Joints in it. But yours might have been let go to long and tore up the ends . You can buy them new on ebay link attached. Has some good picture JOHN DEERE OEM UNIVERSAL DRIVE SHAFT AM37875 317
Mar 17, 2016 | Garden
John Deere L130 riding mower w/23hp Kohler Engine,
need carb rebuilt one problem may need valve job carb rebuild 80.00 valve job 100.00 per cylinder have to take in to shop for this
Sep 14, 2014 | Garden
JOHN DEERE L130 SPARK PLUGS ARE NOT FIRING
first i thought this engine had only one spark plug ?? second it's a kohler engine right ? this model has a coil (thing that makes fire for plug) that sits right on top of engine under cover this allows grass and other stuff to get inside it and cause things to overheat a bit this makes coil go out when things get hot in there but it usually will restart when it cools off after a few hours your gonna need to remove cover replace overheated coil and clean this entire area with compressed air to get things cooling again , ck out youtube for some of my easy dissassembly videos of this motor (kohler coil change)
May 31, 2014 | John Deere L100 Series
John Deere X304 PTO Engagement Problem When Warm
Hi, check your belt tension, check all idler pulleys and drive pulleys for free rotation with the belt off and finally check that the belt is not bottoming out in any of the drive pulleys. If so, replace the belt. The blades should come up to speed imediately wether hot or cold and it sounds like your belt is slipping in one or more of the pulleys which drags the motor revs down until it grips. Regards Phil.
Jun 13, 2012 | John Deere Garden
I have a john deere K series 17hp riding mower. when I try to engage the blade the safety mechanism works but the blade will not engage. the switch has been replaced.
Hi, sounds like the clutch. If you feel confident you can strip the mechanism down, clean and replace, otherwise its a new clutch.
Aug 29, 2010 | John Deere Garden
Kohler small engine problem
1989 Kohler 20 backfires through the exhaust. What are the possible causes?
Jun 02, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
John Deere 42 in. EZ Trak Bagger  Logo
430 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
