Question about Garden
Sp454 runs to fast on start
V35 engine
How to install a bose sa3 to a bose v35
How to install a bose sa3 to a bose v35....http://m.topix.com/forum/who/bose/TOH8RAETEKGB8966I/p2. See the link above . Sometimes audio cable quality n the ohm makes a difference . 12_27_2013_11_17_29_pm.png
Dec 12, 2013 | Audio Players & Recorders
Engine runs fast and slow
Take a spray of carb cleaner and clean the linkage mechanism from the governor to the carburetor and make sure they move with out sticking.
Dec 07, 2013 | Briggs Stratton Portable Generator 305cc...
Bad distortion of Bose Lifestyle V35
It may be due to one of the component attached. Detach all the components and test by connecting one by one. Try connecting radio at last.
Mar 24, 2013 | Bose Lifestyle V35 Theater System
Bose Lifestyle V35, sound but no image.
Thank you so much the unplug the power from the system worked after hours of trying other stuff
Huge thank you
Aug 14, 2012 | Bose Lifestyle V35 Theater System
I bought a Bose V35 2 weeks back. I played my system yesterday and switched off. Since this morning I am unable to switch on the system. Green light keeps blinking and I keep getting the message "iPod...
With this system being so recent from purchase you should return it to the store as it is faulty. DO Not Attempt to do any "Mr Fix It" type repairs as it will invalidate any warranty (standard is 12months from new in UK)
Jan 07, 2011 | Bose V35 Theater System
Just bought a mountfield sp454 mower filled it with petrol the petrol then started to pour out of fuel bowl there was a plug missing fitted a small bolt in the hole then started the mower it felt as though...
Get he model, type and code off of the engine shroud and take them to your local small engine parts dealer and get the proper bolt for the fuel bowl. They use a special bolt that is hollow and with a weep hole for the gas to flow through the inside of the bolt and up into the carb. Get the right bolt and it will most likely run for you.
good luck
roundo4
May 23, 2010 | Garden
Need to replace the screen on my Viewsonic V35
If you have cracked the screen the only way to get that fixed is to send it back to whoever the manufacturer is, I have never seen anywhere that will just replace the screen in any phone shop, but you know what, they do have small repair shops in most cell phone companies, maybe give them a call, worse case scenerio they can at least give you the number to contact someone who can fix it...
Jun 13, 2009 | ViewSonic V35 Pocket PC
Garden Logo
11 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
