Re: Marantz DV4001 DVD player Progressive scan will not work
Re: Marantz DV4001 DVD player Progressive scan is not working ? altho when the player is loading the DVD if I press PLAY player will start the DVD where I previously stopped watching yet, if I let the DVD player search without pressing play will start the DVD from the beginning. I have never owned a progressive DVD player that needed too be manually programmed for the progressive feature to work
Need Advice (If this is a dumb question yes I know I'm electronics, illiterate)
Thank You
atticwebs@msn.com
  • 10,594 Answers
You can set DV4001 on progressive scan permanently by following procedure...
Press SETUP button on remote and select VIDEO SETUP PAGE by cursor/ navigation buttons on remote, select PROGRESSIVE in that menu and confirmation box will appear, select OK and dvd player is set on progressive scan mode.
In Progressive mode dvd will give Video only in Component Out pins so make sure that you have hooked dvd player and TV on Component terminals. There would be no video out in yellow pin in progressive scan mode.
Let me know if you need further info.
Click HERE to download instruction manual copy of DV4001 and check page-37 for details.
Thanks.
Posted on Jun 14, 2009
Marantz DV4001 DVD player suddenly won't power up. Rental DVD stuck in player. Besides the lack of power issue - is there way to open the DVD player manually?
YES, UNPLUG, REMOVE SCREWS @ BACK & SIDES, CHANGE FUSE ON POWER BOARD,OR YOU CAN TRY & RELEASE THE TRAY BY WINDING THE COGS BACKWARDS. CHECK YOUR PLUG FUSE FIRST.
Oct 10, 2013 | Audio Players & Recorders
My memorex combo dvd & vhs player is not working right. can you help me? the vhs player works fine, but the dvd player display's a split screen on the tv with a large yellow box with the word PSCAN....
PSCAN is a short form for Progressive Scan - a line scanning format used for High Definition TV. Standard TVs use Interlaced scanning. On your DVD/VHS player, the VHS is an analogue signal recorded in interlaced mode so is fine for a standard TV. The DVD is a digital signal and cazn be processed for progressive scan output in order to produce a better picture on a High definition TV (or a TV capable of handling progressive scan). If you cannot to your TV via the HD outputs then you should be able to set the DVD player to output interlaced instead of progressive scan.
Mar 05, 2011 | Memorex MVD4540 DVD Player/VCR
Progressive scan mode on screen
Your television probally does not support progressive scan mod. many do not.
Apr 12, 2009 | Zenith XBV342 DVD Player/VCR
Marantz DV-4001 front display not working.
Unplug the AC ..Let it set for a few minutes. PLug it in.
If no display still , it may be the backlight for the display that's quit.
Let me know,
Scott
Mar 18, 2009 | Marantz DV4001 DVD Player
Split screen on DVD player
This sounds like a progressive scan issue (unit in P.Scan Mode) here is a C&P from the manual
Set "Alt Video Out"
Highlight "Alt Video Out", then press the RIGHT button to select
one of the following options:
• S-Video - Select this if you are using the S-Video OUT jack on
the rear panel to connect to a TV.
• Component - Select this if you are using the COMPONENT
VIDEO OUT jacks on the rear panel to connect to a
Progressive(480p) or Interlaced (480i) TV.
• See your TV owner's manual to determine what type of TV you
have.
- Interlace : Interlaced Scan mode will work.
- Progressive : Progressive Scan mode will work, and Video
and S-Video will not work.
• Press the Progressive button on the front panel if you have a
Progressive scan TV only. Otherwise, the picture will be
disturbed.
Feb 04, 2009 | Samsung DVD-V3650 DVD Player/VCR
Compatibility with Samsung LCD Display
It sounds like the HDMI port on the back of your Marantz is damaged. if you know for sure that the HDMI port works on another tv still you might just use component connection because the visible difference between component and HDMI is not very recognizable.
Jan 13, 2009 | Marantz DV4001 DVD Player
DVD player stuck on progressive scan
Try unplugging the power cord from the wall for at least 24 hours. This should cause the unit to 'forget' the setting for progressive scan, and return to the default interlaced. If this doesn't work, you will need to find a remote to get into the menus to reset this option. Perhaps a universal remote will work? Let us know if this works!
Oct 06, 2008 | Protron PD-800 DVD Player
DVD stuck inside
Open the case and take it out manually.
Feb 03, 2008 | Marantz DV4001 DVD Player
Split screen from DVD player, cable is fine no problem
The progressive scan can work only throug progressive scan CTV.. while some of the newest DVD player today has a progrissive... now you must turn OFF the progressive scanof your DVD on the set-up menu to see the real screen display.
Jan 07, 2008 | Televison & Video
Cannot remove progressive scan mode
press stop and keep hold of the stop button while you eject the dvd, it worked for me, i played around with it and found pressing stop and holding it while ejecting works
Sep 30, 2007 | Televison & Video
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
