Global Star Software School Tycoon for Windows Logo
A
Anonymous Posted on Mar 23, 2014
96% INSTALL install
I live in Benton Illinois 62812 I own a lot and want to put a double wide trailer on it can I
Mobile Home - conventional mobile home designed for permanent habitation and constructed for transportation on wheels. Does not include a mobile home served by individual utilities and resting on a permanent foundation with wheels, tongue and hitch permanently removed.
PUBLIC SAFETY
(430 ILCS 120/) Illinois Manufactured Home Installers Act.
(430 ILCS 120/1)
Sec. 1. Short title. This Act shall be known and may be cited as the Illinois Manufactured Home Installers Act.
(Source: P.A. 89-522, eff. 7-19-96.)
(430 ILCS 120/5)
Sec. 5. Legislative findings. The Illinois General Assembly finds that manufactured homes are a viable housing resource for many citizens in Illinois. The General Assembly also finds that improperly installed manufactured homes can impair the public health and safety. Therefore, it is in the public interest that manufactured homes are properly installed by responsible and qualified individuals.
(430 ILCS 120/10)
Sec. 10. Guidelines for manufactured home installers.Within one year after the effective date of this Act, the Illinois Department of Public Health shall work with all interested parties to publish guidelines for persons who install manufactured homes in this State. These guidelines may include in whole or in part any national guidelines or standards for persons who install manufactured homes.
(430 ILCS 120/15)
Sec. 15. Accredited manufactured homes installer courses.Within one year after the effective date of this Act, the Illinois Department of Public Health shall work with all interested parties to propose rules for the accreditation of courses for persons installing manufactured homes in Illinois. The courses shall provide instruction on how to install a manufactured home to the specifications of the manufacturer, review the installer guidelines, and test the written and practical installation skills of the individual installer.
(430 ILCS 120/20)
Sec. 20. Notice to buyers. A person selling a manufactured home one year after the effective date of this Act shall encourage the buyer of that home to use an installer who has successfully completed a manufactured home installer course accredited by the Illinois Department of Public Health. The seller shall also inform the buyer that failure to properly install the home may invalidate any implied or expressed warranties concerning the home.
(430 ILCS 120/99)
Sec. 99. Effective date. This Act takes effect June 1, 1996.
(Source: P.A. 89-522, eff. 7-19-96.) 430 ILCS 120 1
Illinois Pro Bono Regulation Legislation and Use of Mobile Homes
1helpful
How to install a heater core?
1994-96 Models
(see Figure)
  1. Use quick disconnect tool T85T-18539-AH to disengage the water hoses from the core, then plug the hoses.
  2. Remove the lower left-hand trim panel by unsnapping it.
  3. Loosen the core cover screws from both sides of the case.
  4. Remove the core and seal.
Fig. : Heater core and cover assembly-1994-96 models
To install:
  1. Install the seal and core.
  2. Install the cover and tighten the retainers.
  3. Install lower trim panel.
  4. Connect the hoses and fill the cooling system.
  5. Fill the cooling system. Disconnect the heater outlet hose at the water pump until coolant begins to escape and this will bleed the system.
Hope this help (remember comment and rated this).
1helpful
5helpful
How do I change a fuel pump on my 1995 Ford F350 7.3 2WD Power Stroke Diesel Do I have to worry about the timing eccentric? How and what do I rotate?
Hi, I hope this helps...
1994-96 Engines
See Figures 3 and 4
0900c15280262dd1.jpg Fig. Fig. 3: Details of the fuel pump assembly-1994-96 diesel engine
0900c15280262dd2.jpg Fig. Fig. 4: View of the fuel pump-1994-96 diesel engine
  1. Remove the turbocharger assembly.
  2. Remove the fuel line banjo bolt at the pump.
  3. Remove the fuel line fittings at the rear of the cylinder heads.
  4. Remove the fuel lines assembly.
  5. Loosen the two hose clamps at the fuel pump fittings.
  6. Disconnect the water drain hose at the fuel filter.
  7. Disconnect the filter and position it forward.
  8. Remove the fuel pump retaining bolts, then lift the pump out of the crankcase bore.
  9. Remove the fuel pump tappet from the crankcase bore.
To install:
  1. Rotate the engine so the fuel pump eccentric is on the base circle.
  2. Install the fuel pump tappet in the base of the fuel pump.
  3. Replace the O-ring on the fuel pump base.
  4. Install the fuel pump and bolt it in place.
  5. Install the fuel filter and connect the water drain hose.
  6. Connect the two fuel hoses at the front of the fuel pump.
  7. Tighten the fuel line clamps and install the fuel filter retaining bolts.
  8. Install the fuel line assembly and new seal rings at the rear of the pump.
  9. Loosely install the fuel line fittings at the rear of the cylinder heads.
  10. Install the fuel line banjo fitting at the pump. Tighten the fitting to 40 ft. lbs. (54 Nm).
  11. Tighten the fuel line fittings.
  12. Install the turbocharger assembly.
How do i install electric fans in a 96 impala ss?
I am not the most mechanical guy and i did it with out much problem. You can get the fans at alot of car parts houses. i just layed under neith the front bumper and there were only a couple of screws and a connector to plug back in.
Photosmart 3310 All-In-One - Cannot install..... Downloaded software from HP web site - 96% install it brings up a "FATAL ERROR" message and then uninstalls it. Running Vista - Help
Hi
The installation will get stalled at 96% , because due to 3rd party service running, will not allow to install HP printer driver.To resolved this follow below steps
1.Disconnect the Printer and uninstall the software.
2.Reboot the PC.
3.Click start, then in "start search" box type "msconfig"(without quotes).Click OK.
4.In System Configuration Utility, Under GENERAL tab, click on SELECTIVE STARTUP, Uncheck "Load System Services" and "Load Startup Items".Click on Apply
5.Then Click on SERVICES tab, at the bottom Check "Hide all Microsoft Services" and then click "Disable all".
6.Click apply and OK. Reboot the PC.
7.Now install the software.
Please let me know once you have done this.
Thanks
Rizwan
Top Global Star Software Video Game Consoles & Games Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Global Star Software Video Game Console and Game Expert? Answer questions, earn points and help others
