Question about Kenmore Washing Machines
Need instruction manual for kenmore washing machine
Need a copy of a Kenmore washing machine model 21302991
  • 1028 Answers
SOURCE: Schematics for washing machine
look under console
Posted on Jul 05, 2008
EllaWatson25
  • 725 Answers
SOURCE: oil leaking on kenmore model 110
This is probably transmission fluid leaking out. You can fix it. Depending on the age of the unit and how much you are willing to spend on a unit that age. Call us for parts. 972-859-0929. We ship next day air and nationwide. Hope this helps you.
Posted on Aug 28, 2009
megarza
  • 88 Answers
SOURCE: need to instructions on how to stack a kenmore
to stack you will need the stacking kit. It can be order through Sears Parts/Product Repair Service department.
Posted on Sep 23, 2009
  • 1937 Answers
SOURCE: My Kenmore Elite top loading washing machine won't spin or drain
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
Following is a description of how to release the console for access to the pins.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
If the problem isn't in the switch, and the Timer continues to move, the problem is likely in the transmission.
We had the same problem:
If you lift the lid, put it down again and the washer begins to spin, the problem is likely in the transmission "Neutral Drain Assembly".
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode.
Apparently, by opening and closing the lid, torque from the motor starting throws the cams into the right gears so that the washer will spin.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
You don't have to remove the drum.
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside.
Remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main
agitator shaft), remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
Posted on Dec 07, 2009
  • 401 Answers
SOURCE: Sears Kenmore series 80 washing machine stops after wash cycle
Sounds like the lid switch.
Posted on Jan 02, 2010
Need a copy of the manual for our Kenmore Cooktop/Oven, Model 79045799103, Serial NF23616028
go to the Kenmore website www.kenmore.com and enter your model number you can get a downloadable/.printable copy for free
Dec 11, 2014 | Kenmore Washing Machines
Just purchased kenmore model 110.21302013 no manuals store told me to get on line
You may download a copy of the manual at http://c.searspartsdirect.com/mmh/lis_pdf/OWNM/1112421L.pdf
If you want the Kenmore website, type "kenmore.com" into your browser's address box, not into a search box.
Oct 31, 2012 | Kenmore Washing Machines
I need a washing machine manual for a Kenmore top loader, model number 22422100
Please check your model number. Kenmore washers have a 3 digit prefix followed by another 8 digits. If your full model number is 110.22422100, then Manage My Life has the manual here: http://www.managemylife.com/mmh/owner_manuals/12008/KENMORE-Residential-Washers-L0407343?brand_name_search=110.22422100 . This is a generic manual for all Kenmore one-speed automatic washers. A copy of the descriptions of the washer settings is available here: http://www.managemylife.com/mmh/owner_manuals/15224/KENMORE-Residential-Washers-L0305156?brand_name_search=110.22422100 .
I hope this helps. If your washer has a different prefix, please add a comment with the prefix. I'll try to find manual for the correct model.
Jan 22, 2012 | Kenmore Washing Machines
Kenmore sewing machine manual model number 38519112. i want to buy
Manage My Life has the manual available as a free download: http://www.managemylife.com/mmh/owner_manuals/19062/KENMORE-Electronic-Sewing-L0911546?brand_name_search=385.19112 .
This site has the manual for the 385.19112 available as a hard copy ($20): http://www.sewingpartsonline.com/instruction-manual-kenmore-385-19112.aspx or a download ($10) http://www.sewingpartsonline.com/instruction-manual-kenmore-385-19112-download.aspx .
I hope this helps.
(note you will need Adobe Reader or a similar program to read the download versions from either site.)
Jan 06, 2012 | Sewing Machines
My mom has 3 machines ...needs instruction manuals on 2 ..kenmore..models 385.1664190 and model 158.17530... also needs a belt for this one.. the other machine is an..Euro-Pro model 9120...
The manual for the Kenmore 385.1664190 is available here: http://www.managemylife.com/mmh/owner_manuals/26171/KENMORE-Overlock-Machine-L9080230?brand_name_search=385.1664190 . You can purchase a copy here: http://www.sewingpartsonline.com/instruction-manual-kenmore-385-1664190.aspx . I didn't see the manual available at Sears Parts Direct on the parts lists that I checked.
An except of the manual for the 158.17530 is available here: http://www.managemylife.com/mmh/owner_manuals/13415/KENMORE-Mechanical-Sewing-L9090181?brand_name_search=158.17530 . Sears Parts Direct lists two belts (parts 26 and 27) here: http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Sewing-machine-Parts/Model-15817530/0582/1220000/00026091/00002?blt=06&prst=&shdMod= . You can probably get the belts in any Sears store. Ask for the part numbers 50013 (originally 28908) and 30083. The manual is not available at Sears Parts Direct. You can get the full manual for $13 here: http://www.sewingpartsonline.com/instruction-manual-kenmore-158-17530.aspx .
The Euro-Pro 9120 manual is not available as a free download. However, you can buy a copy for $15 here: http://www.sewingpartsonline.com/instruction-manual-euro-pro-9120.aspx .
I hope this helps.
Sep 17, 2011 | Kitchen Ranges
Need owners instruction manual to turn on clock on kenmore range
Can you provide the exact Make, Model and Kenmore model number?
Kenmore model numbers use the format ###.########
Using that format, try the Sears Parts site where (on the right of the components page) there may be a section for getting a manual,
Otherwise, use the Sears Answer Site for manuals.
http://www.managemyhome.com/
Nov 09, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
I am house sitting and i dont know how to use the washer and i cant find the manual with the instructions
If this is a Kenmore Elite front loader as you have this question listed under, you can find a FREE copy of the owner's manual at managemyhome.com. Just locate the model number (listed on a nameplate around the door opening) and enter it under the "Manuals" link. You can view online or download a copy. I hope this helps you.
Sep 05, 2009 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
14 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
