Question about Kenmore Dryers
Dryer starts but wont stay on
My kenmore dryer starts but wont stay on. I've replaced the ''on'' switch, heating element and theromstat. what else could be wrong?
  • 999 Answers
There is a switch on the motor that activates when the drum is turning at the proper speed. This switch should be checked if the drum is turning properly.
Eric
Posted on Jun 14, 2009
Kenmore 11086180100 heating element stays on even when dryer is off
The control relay is bad. Internal contacts are most likely welded together. Replace the relay.
Oct 22, 2016 | Kenmore Dryers
My Kenmore electric dryer model 417.80412700 wont heat up but the element is still good. What else could be wrong?
Some dryers have a hi limit safety switch that is a one time fuse type switch . If the dryer gets too hot this switch opens and prevents the heating element from operating it is usually about 1/2" wide x 2" long plastic part with two wires attached to it.
You can test this part with a continuity tester. Unplug dryer, remove wires and test for continuity between the terminals. No continuity means the part needs to be replaced.
Hope this helps.
Bo
Jan 05, 2015 | Kenmore Dryers
Dryer won't heat I've replaced the heater element
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 11, 2011 | Kenmore Dryers
I have a whirpool dryer model ler4634pq. I will not heat. I had the heating element and replaced the theromstats on the element but it still does heat. I had the switch checked. I checked to make sure hose...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Apr 13, 2010 | Whirlpool LER4634PQ Electric Dryer
Kenmore Dryer, heating element doesnt turn off
remove the back of dryer and remove the heating element from the heater box,check to see if the wires in the box are touching the heater box walls any where,this would make the element stay on all the time,also check the high temp thermostat on the left side bottom,this is the on off thermo for the heating element-mike
Feb 16, 2010 | Kenmore 63942 Dryer
Heating element no longer working. dryer still operating except clothes wont dry
it is the theromstats or heater element has gone the only way to tell is to meter them out u need an expert to do this
Jul 31, 2009 | Fisher and Paykel SMARTLOAD DE62TG1...
Heating element wont stay on
replace the element
click the link to get the replacement procedures
http://www.applianceaid.com/wp_element.html
thanks.
Apr 01, 2009 | Kenmore 62882 Electric Dryer
Dryers Logo
160 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
