Question about SkyCaddie SG2.5 GPS Receiver
Will not connect to skycaddie
Cannot get sky golf on computer
How do I download golf courses to my sg5.
To download courses:
  1. Launch CaddieSync and sync your SkyCaddie.
  2. Select COURSES from the upper navigation bar of the CaddieSync desktop.
  3. Select the Favorites link next to Course Search.
  4. Check the box at the left of each course you want to download to your SkyCaddie.
  5. If you want to remove a downloaded course, uncheck the course in this step.
  6. Click the Download to My SkyCaddie >> button above the Favorites list.
  7. Checked courses will be downloaded to your SkyCaddie.
  8. Unchecked courses will be removed from your SkyCaddie.
  9. Click the Disconnect button in the lower navigation bar and close CaddieSync.
If you experience problems downloading courses:
  1. Turn off the SkyCaddie and disconnect the USB cable.
  2. Close the CaddieSync application.
  3. Reconnect the USB cable from the computer to your SkyCaddie.
  4. Launch CaddieSync.
  5. Click the Sync button in the lower navigation bar to resync the SkyCaddie.
Sep 01, 2011 | SkyGolf SkyCaddie SG5 Accessory Bundle Sky...
Cant get past personal info page to activate skycaddie golf range finder
Prior to activating your SkyCaddie, you will first need to install a simple software program to your Windows-compatible PC. This software program, referred to as SkyCaddie Desktop, will allow your SkyCaddie to communicate with the SkyGolf website. This program allows you to DirectConnect with the SkyGolf website, so you can personalize your SkyCaddie, download courses and periodically update your SkyCaddie’s software. NOTE: If your computer is protected by a firewall, it may need to be set up to allow our SkyCaddie software programs to access the web. If your firewall software displays any warning messages during the activation process, simply indicate that you wish to allow access. if the software is not installed the unit will not get activated Activating Your SkyCaddie Within 30 days, please register your SkyCaddie, create a “My SkyCaddie” online account and select a SkyPlayer Club Membership Plan by going to the SkyGolf website at www.skygolf.com. Click the “Getting Started” link for information and instructions to complete the process. During this process you will be asked to create a user name and password for your online account referred to as “My SkyCaddie”. The “My SkyCaddie” online account offers a full range of member services, easy access to download courses, support and more. In addition to creating an account, you will be asked to select a SkyPlayer Club Membership Plan that best fits your needs. click this link directly to get more details http://service.alan-electronics.de/golf-electronic/sky-caddie/SG-2-UserGuide.pdf check out on page number 8 of the link to get details on this isue. This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Dec 19, 2009 | GPS
My sky caddie SG2 cable is inoperative.
Did you ever find a replacement serial cable for the SG2-serial? I have the same problem and can't find a replacement cable. my email address, par5s2ez@hawaii.rr.com
Jul 30, 2009 | SkyGolf SkyCaddie SG2 GPS Receiver
SG4 Sky Caddy driver
Make sure your cord is plugged into the SkyCaddie with the cord pointing down towards the battery, not going up. It makes sense and it is easier to plug in with the cord going up, but you will eliminate this error if you plug in the cord with the cord going up.
Apr 02, 2009 | SkyGolf SkyCaddie SG4 GPS Receiver
I can't connect to sky golf to purchase a membership. I get to direct connect, and it says retry over and over without connecting. HELP!
Don't purchase the membership...the new software is a nightmare. My unit is now frozen just before a 10 day trip to Hawaii. All my home courses are gone and I can't download or connect. Wait 30 min on hold for customer service, message says "new software release is causing unusual delays".....(how about adding some more customer service people prior to the release)?
This is a good product when it works, but frustrating when down. GPS needs reset continually.
Feb 11, 2009 | SkyGolf SkyCaddie Handheld GPS Unit
Adding a new course
You must be sure the SkyCaddie is turned on and connected to your computer. You should then launch the SkyCaddie desktop software that you should already have loaded onto your computer. The two should automatically connect and should take you to your golf course listing on the device. From this list, you can add or remove golf courses to your device by either clicking on the ADD button or the REMOVE button on the list, whichever process you want to perform.
Jan 21, 2008 | SkyGolf SkyCaddie Handheld GPS Unit
SkyCaddie SG2.5 GPS Receiver Logo
19 people viewed this question
Top SkyCaddie GPS Experts
Joseph Hoffmann
Lyle Siemens
Lyle Siemens
Are you a SkyCaddie GPS Expert? Answer questions, earn points and help others
