Question about Pioneer DV-610AV-K DVD Player
No disc signel
Audio or video cd inserting first signel comes loading after signel comes no disc
I have a kenwood MIDI M-45 /MIDI M-757 audio system. The CD player won't play. The disc loads but error comes up NO DISC, can you help????
The cd unit is not reading the disc, the laser pickup may be dirty, or the pladder motor that cd sits on may be defective. If you can get at the laser pickup lens, clean it with rubbing alcohol with a Q-Tip very carefully in circular motion and allow several minutes to dry.
Dec 29, 2010 | Kenwood Audio Players & Recorders
My cd recorder wont read blank cds help me please
Do as it asks, insert blank CD-Audio or CD-Music media.
Discs for recording
For recording, make sure to use special audio discs only.
These discs are marked with “Digital Audio” and the logos shown below.
There are two different types of audio discs for the use on this CD recorder:
– CD-Audio Recordable (CDR) discs
These discs can be recorded on once and
play in all standard CD players and CD
recorders, when they are finalized.
– CD-Audio ReWritable (CDRW) discs
These discs can be recorded on, erased and
re-recorded many times and play in CDRW
compatible CD players and CD recorders,
– All Philips CD players and CD recorders
with the sticker shown here are CDRW
compatible.
To ensure proper working of the set we recommend the use of Philips audio CDR and audio CDRW discs only.
Note: Do not use a computer CDR or CDRW as recording will not work!
Go here and download the manual. You'll need it.
http://www.p4c.philips.com/files/c/cdr602_00s/cdr602_00s_dfu_eng.pdf
Mar 04, 2010 | Philips CDR602 CD Recorder
Can't insert cd into player. I have a Jensen VM9311TS.
Is your stereo is powered on? there might be another disc inside,or there's a problem with the CD tray loading mechanism.
Sep 02, 2009 | Car Audio & Video
Eurovox 'Maestro Series' 10 stacker displaying 'E-99'
CD ERROR DISPLAYS
CD Changers
E01:
The disc magazine is not inserted in the cd changer
E02:
No disc is inserted in the disc magazine
E04:
The disc is dirty, or the disc is inserted into the disc magazine
upside down
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
FM/RF Remote Controls
E99 RESET PROCEDURE FOR REMOTES:
Remove disc magazine from changer by pressing eject button.
changer. Press RESET button on interface unit
WAIT:
The temperature is exceeding more than 55c(130f) and the cd
changer cannot be operated. When the cd changer cools off, this
wait disappears. When the RESET button on the interface unit is
pressed, this WAIT appears for a few seconds
IF THESE ERROR CODES STILL KEEP APPEARING
CONTACT YOUR DEALER.
Jun 14, 2009 | iLO CA3000V CD Player
Car cd player will not work
It sounds like it's not loading the disc propperly, it ejects immediatly yes? A mechanical loading fault.Try banging it as the disc loads..... not a cure but the knocking might dislodge something, it may have to come out and be fixed.
Apr 05, 2009 | Car Audio & Video
2 cds wedged in car CD player. how do you remove?
look for a reset button in the front panel, you might have to use a pen or small point object to insert it and hold for 5 seconds or more, the discs should come out, if not you have a problem in the loading mechanism assembly wich will need a tech to do that
good luck
caypianan@yahoo.com
Nov 02, 2008 | Audio Players & Recorders
CD player shows no disc when CD inserted
The problem of your cd player have a displayed "no disc"is the common problem of defected lense, you better change the lense ,so performance will come back again.
Jun 18, 2008 | Audio Players & Recorders
Magnavox DVD Video Player DVD609AT
DVD609AT:
The manual is available at Philips website, the number for more info in manual is out-of-date; the new number is 1-800-605-8610
This unit has a problem when playing dual-layer discs of some kinds - read the warnings on the Magnavox website - playing the wrong kind of disc will cause an error that will require svc/repalcement to fix
Playable Discs
This DVD Player will play Digital Video Discs (DVDs) and Audio CDs. In order to play a
DVD or Audio CD on this DVD Player, make sure the Disc meets the requirements for
Region Codes and Color Systems as described on this page. Also, the Discs should have
the following logos and should meet these standards.
• CD-ROM
• Compact Disc-Interactive
(CD-I)
• Compact Disc-Recordable
(CD-R)
• Digital Video Disc-Video
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Super Audio CD (SACD)
• Photo CD
• Video CD
• Video Single Disc (VSD)
Digital
Video
Disc
12 cm
12 cm
Approx. 4 hours
(single-sided)
Approx. 8 hours
(double-sided)
Approx. 80 minutes
(single-sided)
Approx. 160 minutes
(double-sided)
20 minutes
8 cm
8 cm
(singles)
Logo
Maximum
Disc Type Contents Playback Time
Sound
and
Pictures
Audio
CD
Disc Size
Sound
74 minutes
Disc
Segments
DVDs are
divided into Titles,
which are divided
into Chapters.
Titles and Chapters
are numbered.
Audio CDs are divided
into numbered Tracks, i.e.,
a track may be one song.
Unacceptable Discs
If you insert an unacceptable type of disc, “Please insert a playable disc” will appear on
the TV screen. Also, “- - - - - “ will appear on the DVD Player display panel. Insert a
DVD or Audio CD. The following Discs will not play on this DVD Player.
• CD-ROM
(CD-I)
(CD-R)
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Photo CD
• Video CD
May 28, 2008 | Philips Magnavox DVD/VCR Dual Player
Custom soundtracks
It's amazing how great music can enhance any game, particularly action games. As the movie industry has known for about a century, music can make a bad video experience seem a lot better. Xbox is the only video game device that lets you add your own custom soundtracks to your favorite games. Here's how: Insert an audio CD into the Xbox optical drive. Access the Music menu from the Xbox dashboard display. Select Music > Audio CD > Copy, then choose the Copy menu. Select the tracks you want, using Play or Pause commands to audition songs. Choose Copy, and Xbox will store the songs on the hard disk. Then insert your game disc and load the songs using the game's setup menu. P.s Not all Xbox games support the custom soundtrack features, but many of the most popular ones do.
Nov 20, 2005 | Microsoft Xbox Console
Pioneer DV-610AV-K DVD Player Logo
14 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
