Cannot open the Tablet or even obtain a password as I didnt have a password to get into it.
It is a Samsung Galaxy 3 7inch SM-T210 It starts up normally where the Screen lights up, and there it ends. \There is a Password requirement now, that I never had before, I have tried all sorts of Passwords that I have used, and none worked. There is no provision for, Forgot my Password as well. Hope you can help me please. Thank you, David Peehikuru deepdews@xtra.co.nz
  • 406 Answers
Samsung Galaxy Tab 3 SM T211 hard reset
this video might help. I dont hear any sound on it so, look at the visual and follow along
Posted on Mar 24, 2014
SOURCE: Admin Password
The master password for the Toshiba e-Studio 45 (using controller gl-1010) is 349845. Use a web browser to open the printer's built-in web access: TopAccess, and click the log-in link on the right hand side to use this password.
Posted on Feb 18, 2009
  • 26 Answers
SOURCE: Password Problem Phaser 6120
Unfortunetly, you will have to reset the printer. Using the control panel go to the default setting and scroll to reset to factory settings. Then select yes and that should take care of it. If not, then in the rear of the printer under the cover, upper left side you will find the memory button battery. Remove the battery, unplug the unit, and turn it on for about a minute. Turn it off and put it back together and you should be ok. Good luck.
Posted on Apr 27, 2009
FixinFax
  • 3085 Answers
SOURCE: sharp ar-287 network password reset
Try deleting the printer in control panel. delete the drivers and reinstall software and drivers.
Posted on Jun 13, 2009
Adi_Taticu
  • 71 Answers
SOURCE: forgot ID password of my ir2020 canon photocopier
first, you need to be an administrator with an administration id and pass to change any id and pass
please call canon Technical support, they can help you without damage.
Posted on Oct 05, 2009
  • 149 Answers
SOURCE: I lost the admin password to my 282 copier. How do
The hard drive stores the operating system for this machine so you would have to have the copier programming to reload after you changed the hard drive and I am not certain that the programming would even support a larger drive. Default code is 123456 Turn off copier, press 0 and 8 and hold down while turning copier on. enter 263, start, enter new code press enter. Turn off and on
Posted on Jan 29, 2010
I have a Galaxy Tab S2 8.0 wifi only SM-T710NZWEXAR. Is it a real model? I can't find support for it anywhere. Not even hen I search on the Samsung website
Looks like a valid model - e.g. portableone.com is selling it, but to verify, check the About information on the Settings screen. Samsung should be able to track it using the tablet's MAC address. Try Samsung Global in case this model is one sold outside North America.
Jan 03, 2017 | Samsung Tablets & eReaders
I have a Samsung galaxy tab 3 sm t210, can i connect it to my television
Yes, you can either "cast screen" using the TV settings as well as the Tab button (providing your TV is fairly modern and with that feature)
But the easiest way is to buy a HDMI cable with a micro HDMI/USB from your phone on one end that converts up to the standard size HDMI...plug and play (just adjust the input port on your TV menu)
Oct 12, 2016 | Samsung Galaxy Tab 3 7.0" - White...
My samsung t210 is not resetting i have tried button and inside setting options both look like its working but when reboots no change the accounts come back aswell
Before performing the Hard Reset:
- In case your Galaxy Tab 3 7.0 can connect to a computer, Then it is better to make a backup of your saved data using Samsung kies software, You can read this Guide to learn how.
- But in case that is not possible, Then you can check that your phone's battery has enough charging level, Otherwise you should charge it.
Samsung Galaxy Tab 3 7.0 SM-T210 and SM-T211 Hard Reset Steps:
- Turn your Galaxy Tab 3 off.
- Take out any existed SIM or memory card.
- Wait for 10 seconds.
- Press and hold the Volume Up key + Home key, Then press the Power key.
- Keep pressing the keys until Samsung logo appears,Release all keys.
- Wait until you get Factory reset / System Recovery menu on screen.
- Use the Volume Down key to select Wipe Data / Factory Reset option.
- Use the Power key to confirm the operation.
- You need to use the Volume Down key again to select "Yes -- delete all user data"
- Use the Power key to confirm.
- After performing the hard reset, Select Reboot System Now option, And confirm it using the Power key.
- Now the phone will reboots, Wait for it to be fully on and then you can start using it.
New Hard Reset / Factory Reset Method Using Odin3 Flasher:
In case you cannot put the Samsung Galaxy Tab 3 7.0 Into Recovery Mode for any reason, Or the Normal Hard Reset operation does not solve your problem, Then you can use this new method to Hard Reset the device so easy, This New Method will reprogram the User area, And it can solve many software errors too, Just follow the steps below:
- Download and Extract Samsung Galaxy Tab 3 7.0 Hard Reset File ( SM-T210 ' SM-T211 ).
- Download Odin3 flasher.
- Put your phone into Download Mode.
- Run Odin3.exe
- Click on CSC button and Select the Hard Reset file.
- Connect your phone to PC via USB cable, And wait until Odin3 detects the phone.
- Click on Start button and wait until the operation done.
- Now your Samsung Galaxy Tab 3 7.0 will be rebooted.
- Done.
Jun 02, 2016 | Samsung Tab Tablets & eReaders
Linking to tablet
here's the PDF manual link: "http://www.samsung.com/us/mobile/galaxy-tab/SM-T700NTSAXAR" , manual tab is on left side of page.
once downloaded, start at page 46 and go from there.
Mar 07, 2015 | Samsung Galaxy Tab S 16 GB 8.4" Display...
How do I log into my google sccount using a samsung tablet sm-t210-r
In setings of tablet look for something akin to 'accounts' see if you can log in there, if not simply open the app gmail or play store and login through the app
good luck
Oct 20, 2014 | Samsung Galaxy Tab 3 SM-T210 8GB 7"...
Unable to switch on my samsung T210 tablet
The charger has a function that restores the battery operation parameters by discharging then charging the battery a number of times. Refer to charging instructions in the pack but I think the cycle is a 3 hourly one, time to charge from a full discharge. If the charger thinks the battery is dead then it will try to recover the battery using this process. You may have left the charger on long enough to charge then also discharge the battery.
Start again and charge for the time in the instructions ONLY, if you are not sure of the time try it for an hour, then without disconnecting the charger turn the unit on and take particular note of any screen messages, if any.
You should be able to continue as normal now, but still be aware of the time you are leaving the charger connected for, as it may take some time before it returns to normal operation and stops trying to recover what it thinks is a dead battery.
Feb 17, 2014 | Samsung Galaxy Tab 3 SM-T210 8GB 7"...
63 people viewed this question
k24674
