Question about Toshiba REGZA Televison & Video
150uf 450v capacitor toshiba
Capacitor 150uf 450v
2 Suggested Answers
  • 12962 Answers
SOURCE: will a 16uf 450v generator capacitor work in place of a 12uf 450v generator capacitor
Yes it will. The key is to not go lower in capacitance or in rated voltage. As you go up in cap size the cost will also go up so you want to stay pretty close to rated value unless dinero is no object.
Posted on Aug 06, 2015
Testimonial: "Thanks for the info I just happen to have a 16 uf"
Will a 16uf 450v generator capacitor work in place of a 12uf 450v generator capacitor
Aug 06, 2015 | Coleman Heating & Cooling
450V 150UF WORK SAME AS 450V 68UF
no you could use a cap with the same UF rating and higher voltage without any issues but the uf rating must be the same.
Apr 06, 2013 | Televison & Video
Samsung lnt3242 has power but won.t turn on
Seems like you need to repair or replace the inverter boards you can get them here: CLICK if this helps please rate ;-)
for more information contact me here: http://tvtechwork.webs.com/
Oct 23, 2010 | Samsung Televison & Video
I have a floor fan with a bad capacitor. its a 1.5uF +-5% 450V. can i replace capacitor with a 33 uF 250 ~ 275 V capacitor ? or with some other one that i got ?
no, the capacity is way too high.... get a capacitor of at least 1,5 uF or up to max 4 uF if you happen to have one lying around
Oct 10, 2010 | Lakewood HV 18-c Floor / Box Fan
MODEL DLT37C3 KEEPS TURNING ITSELF TO STANDBY WHEN
Mine did this to. Opened up the back cover, the power circuit board is clearly visible, on it is a HUGE electrolytical capacitor 26mm in height x 35mm in diameter 150uF 450V. Changing this for a new was the cure for me. Might work for you as well! Please be careful, the capacitor can hold a high voltage even after power is off and cable removed, make sure to remove the powercord! If unsure ask someone that can solder to do it.
You will need a soldering iron (quite powerful) and some solder to change it.
Feb 28, 2010 | Daewoo Televison & Video
Sound but picture goes black after 10 min
is not the ballast. the problem is the control box
Nov 29, 2009 | Polaroid FLM-2632 Television
TV won't turn on
If that large capacitors is defective, the TV should still power up normally but it might produce a humming noise through the speakers.
I would suggest to check very carefully the capacitors on the secondary side of the circuitry, specially the 1000uF that filter the 5vdc line.
Let me know if you require further assistance.
Dec 02, 2008 | TruTech PLV16320 Television
Trutech TV PLV16320 - Power Supply Caapacitor Values
I take it you didn't save the capacitors?Or you just don't know what hole they came out of?I have someone that is supose to be sending me their power board from the same model TV.When I get it,if I do,I will let you know what they are.I did replace the bad ones on a 26" Trutech,and to me,they appeared to have the same board.If you wanted to take the chance,and replace the ones I did,here is what they were.Mine had three different diameters as well,but two had different voltages,and height.The measurements read diameter,and then height.(2) 35V 1000UF 13MM X 22MM (1) 25V 680UF 10MM X 16MM (1) 35V 680UF 10MM X 20MM (4) 10V 1000UF 8MM X 14mm When you do go to replace them,you can get ones with a higher value on both specs,but not lower.For example,if there is a 10V 1000UF,and a 16V 1000 UF,you can replace them both with 16V 1000UF,and it will work perfect.You can also use different heights as well,as long as there is enough room.How is the big black 450V 150UF,and the 400V 10UF capacitors?You have to check the bottoms of them as well.I had fixed one that these were the only two that were bad.I hope this helps.If you have any other questions,please let me know.Thank You very much!
Tyler
Oct 17, 2008 | TruTech PLV16320 Television
X20G-Naga III screen goes blank after 1-2 secs
FIXED!
Device : Spectra X20WG-Naga
Problem : monitor comes on then flickers then goes off
solution: Replace Capacitor C101 (150uf, 35V) and Fets U101 and U102 (4511GM)
Comments: This is a common problem with this monitor.
Oct 02, 2008 | Sceptre X20g-Naga III 20.1" LCD Monitor
Televison & Video Logo
26 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
