Question about Canon PC-940 Black and White Copier
Thin vertical line on copies
A thin, vertical line appears on the copies across the entire page, approximately 1 inch from the right margin. What is causing this problem and how can it be fixed?
  • Tara Latimer
    Tara Latimer Mar 26, 2014
    This is an "old" PC-940; it is a stand-alone copier, not connected to the computer, and therefore no "clean and alignment" functions from any "tool menu" are available." Do you have any other suggestion to fix the problem?
    Master:
  • 966 Answers
Tara, if the ink levels are ok, try clean and allignment functions from the tool menu. Use CLEAN UNUSED PAPER.
Posted on Mar 24, 2014
  • 41 Answers
SOURCE: thin black lines (mp 530)
Here's the link for how to clean the unit... I was going to post the instructions here, but there are pictures that might be helpful to you.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=13371
Before doing anything more drastic, I would try this.. let us know how it turns out.. if it doesn't work, we'll go from there.
Maggie B
Posted on Feb 23, 2008
SOURCE: Vertical Line on copies made from automatic feeder
i just used some dust off spray air on the ADF everywhere that there is an opening to spray. it appears to have helped some...its not perfect yet. hope this helps.
Posted on Nov 09, 2007
SOURCE: Copying with page feed results in a vertical line on every page
There must be a strip of glass about one inch wide, next to
the large glass. There is the problem !
Clean that strip thourougly. When you use the feeder the pages
are scanned thru the small strip of glass.
Posted on Mar 28, 2008
leroyal
  • 2120 Answers
SOURCE: Unwanted "line" on copied documents
Open the document feeder and clean the scanner glass.
Posted on Jan 21, 2009
Cogz
  • 1326 Answers
SOURCE: 3 thin black lines on copy
Do the black lines show up when you use the adf or if you make a copy from the copyboard glass. If the lines only show with the adf > there is a small **** of glass on the left side of the copy board glass > I would clean the slip glass with windex or a damp cloth..... Good Luck
Posted on Jun 09, 2010
Thin black/transparent vertical lines across the screen
If the lines aren't appear at least in one input or in smart apps then theres no posibility that the time-control is malfunctioning.the more logical is mainboard is isn't working right . could you provide me with more info and maybe a photo i'm sure I can get you a better and more advanced answer to that
Jun 23, 2014 | LG 55LM6200 55 1080p 120Hz 3D WiFi LED...
Mysterious fluctuation in quality of copies.
fuser drum is bad. photocopier use electricity to transfer the toner to the paper, then it is heat fused to paper. it appears that the problem is occurring around the time that the toner is attracted to the paper.
Mar 07, 2014 | Canon PC-940 Black and White Copier
A thin line also appears on the photocopy.why and what is the solution?
The page goes thro the feeder mechanism and passes over a thin strip of glass; maybe about 1/4 inch wide and runs across the fax under the cover where the paper is fed. You probably have dirt,corrector fluid or something like that on the glass this will cause the problem of a black line down the page to appear at the other end when you send a fax...and also to appear on your pages when you make a copy...open up the machine and clean the glass...cant help any more as you didnt state make or model.
Nov 04, 2010 | Office Equipment & Supplies
A thin blue line has appeared on the display from top to bottom on the right side app. 1 inch from the right margin. It appears on all pages.
This is an indication that the lcd is bad. something may have been dropped on the unit or if the front was hit by something, this can cause a bad spot on the lcd.
Nov 10, 2009 | Raymarine C80 GPS Receiver
Black line is present when copying document; not
This sounds as if you have some ink/contamination on the small scaning glass that sits to either the left or right of the main glass on the copier.(Depending on the model/make)As your original is scanned over this thin piece of glass the scanning device will see any spots and this will result in a black line down the page.Please clean the glass with a soft rag.
Oct 12, 2009 | Office Equipment & Supplies
Vertical line from document feeder
there is probably a dirt spot on the scanner glass where the document feeds in. try cleaning the thin glass under the document feed cover.
Apr 24, 2009 | HP Officejet J5780 All-In-One Printer
Samsung 26inche lcd tv has a blue thin line acrross the left side
call the repair guy, he will be able to diagnose, prbably a bord problem.
Dec 23, 2008 | Televison & Video
Mar 26, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Oct 25, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Vertical, pencil-thin blue line appears after 10 minutes of viewing (any source)
I would suspect a connection breaking down as the set heats up. A shop will probably have to put the set in a stand to hold it while they check for loose connections or defective components inside. Not a DIY job by any means. If this line went completely through the picture either vertically or horizontally and stayed there then this would have indicated a failure in the Panel itself. A thin Line any where on the screen consisting of one pixel in width is a Panel Failure according to Hitachi.
Jan 01, 2007 | Hitachi 55HDT51 55 in. HD-Ready Plasma...
Canon PC-940 Black and White Copier Logo
139 people viewed this question
old marine
old marine
