Question about Dishwashers
How do you fix GE dishwasher that stops as soon as you reach plate warmer cycle?
I have a GE GSD650X-73WB dishwasher and once you reach plate warmer cycle it quits. I have checked heating element, both cycle switches, and the timer to see if that fixed issue but they all work. What is the problem?
It's the timer. Assuming you checked everything properly then it's your time. But check all connections disconnect power for 30 seconds then try running it. But the only thing left is the timer. I hope this helps the picture is of a different timer then you have but its a timer none the less
Posted on Sep 22, 2014
  • 1462 Answers
SOURCE: dishwasher trips RCD electrics
fault is probably heating element but you need a megga to test it. other disconnect element, tape up wires then check on wash cycle. be carefull!!
Posted on Mar 20, 2007
  • 51 Answers
SOURCE: Dishwasher not completing cycles
Is the water being heated??? When the timer reaches the stage where it will not move forward any further, after 5 minutes or so, open the door & see if the water is heating up. The timer often waits for the water to reach the correct temperature. Temp is measured by the thermostat. If the element tests OK, then it could be the relay that switches the element. The relay is turned on & off by the timer. I would say that if the timer is OK & the element has the correct resistance, then it is is more likely to be the relay. Last resort would be the thermostat, but my money is on the relay.
Posted on Aug 01, 2007
  • 1462 Answers
SOURCE: Whirlpool Dishwasher ADG7540/1
an ntc is very reliable. have you checked continuity thro the heater? other common fault is a dry joint devoloped on the control card - take it out and check for dry joints
Posted on Oct 03, 2008
huuum
  • 750 Answers
SOURCE: dishwasher won't stop when door is opened mid-cycle
Welcome
You need a new door latch mechanism.
It is faulty and not doing it's job of over riding when the door is opened
Please remember to leave a solved rating before leaving
Posted on Dec 19, 2008
rockfixya
  • 679 Answers
SOURCE: Frigidaire dishwasher not completing cycle.
hi,
The cycle doesn't complete
If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle
Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
On some units, the pause is timed and the unit continues after the allotted time.
On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer
Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
I see an error code
If your dishwasher has a digital readout and you see an error code, it may indicate a problem with the unit. If this happens, look up the error code in your owner's manual to find out what the problem is.
Good Luck
Thanks for using FixYa
Posted on Jan 03, 2009
GE dishwasher won't drain or cycle
TRY TO UNPLUG THE UNIT FOR AN HOUR TO RESET THE ONLOAD SETTING THAT PROGRAMMED INTO IT..
KEEP ME UPDATED
Sep 28, 2008 | Dishwashers
DISHWASHER GE PDW7800J00BB DOES NOT WASH ,FILLS WITH WATER BUT NO WASH
It is unclear from your description if the wash pump starts and pushes the water around but never stops cycle or the dishwasher stops as soon as the water is filled.
If you do not hear the wash pump start then it is possible the wash motor is faulty. But if the wash pump starts and never completes the wash cycle then it is possible the heater is faulty and dishwasher is waiting for water to heat up before it can go to next cycle.
See the attached diagram for location of wash pump motor and heater.
Hope this helps you find the problem. Please rate the solution if you found it useful.
Oct 10, 2010 | GE 24 in. Profile PDW7800 Built-in...
My Dishwasher is DS603 and it stop on minutes 26 during a cycle and never continue.
Hi- sounds like your heater plate is bad. The cycle wont continue unless the water reaches a specific temperature for that point in the cycle.
Mar 08, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwasher pump motor stops
Water-heating cycle
Timer
Water-heating cycle Manydishwashers heat the wash and/or rinse water to a higher temperature,as the cycle calls for it. In these cycles, the dishwasher pauses afterit has filled with water, waiting for the water to reach the pre-settemperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • Onothers, the cycle can't continue until the water reaches the highertemperature. If you have this type of dishwasher and the water isn'tbeing heated (say, because of a problem with the heating element orthermostat), after the unit stops at the heating cycle, it nevercontinues. When you repair the heating-system problem, the "cycleproblem" is fixed too.
Timer Timersdon't often fail. But if every other part of the dishwasher seems to beworking properly and the timer knob seems to be stuck in oneplace--doing one function continuously--the timer may be at fault.Dishwasher timers can't be repaired. If yours is defective, replace it.
Dec 10, 2008 | GE Dishwashers
Problem with operating new dishwasher:
problem not solved. will contact the dealer.
Thank you.
mcrae891
Oct 12, 2008 | GE Dishwashers
Water won't drain, Soap Door open with soap still there and stops running at Plate Warmer cycle
Reset the washer manually. Close the machine, and slowly advance the timer till you here the fill valve start. Then let it do it's thing
Jul 21, 2008 | GE Nautilus 24" Built-in Dishwasher
Dishwasher does not dry the dishes thoroughly
I have a GE dishwasher with poor drying. One service call said to make your water hotter and us a jet dry rinse. Not any better. Another call went to GE, this time they have a vent kit to help push out the steam and the computer will be reprogrammed to allow a longer dry time. Will have this done when the parts arrive at my home. Then the repair man will install and make computer adjustments. Looks like GE knows they have a problem but won't fix it until you complain more than once and demand a fix. For all GE dishwasher owners with this problem start calling the customer service.
Feb 05, 2007 | Kenmore 18 in. 14432 / 14439 Built-in...
Dishwashers Logo
53 people viewed this question
Top Dishwashers Experts
Owen Barnes
