Question about Brother MFC 240C All-In-One InkJet Printer
Brother MFCJ5910DW how to replace ink absorber myself
Ink absorba-the-Greek is full and as I don't have a car getting this machine to a repair shop is difficult so I would really like to clean and reset the counter myself. Can anyone point me towards instructions written for someone with the manual dexterity of a Three-Toed Sloth and the technical competency of a seagull?
Inkworks
  • 87 Answers
SOURCE: Unable to continue cleaning message for Brother 5840CN
You will have to remove the scanner top to get to the absorber box, a little more complicated that I care to explain in this forum. You could just reset the absorber box count and move on...the ones I have cleaned were not that bad when this problem and error 46 occurred. Go in to maintenance mode by pressing Menu, *,2,8,6,4 withing two seconds. If the lights are not blinking, press the stop key and retry procedure. The display will not say maintenance if you have error code 46. Once in maintenance mode press 8,0 to enter equipment data log. Press the black start key until the machine displays "Purge". Press 2,7,8,3 in this order to reset purge counter to 0. Press black start key until the display says "Flushing". Press 2,7,8,3 in this order to reset flushing counter to 0. Press stop key to exit the Equipment Data Log. Press 9,9 to exit maintenance mode
Inkworks
866-381-0541
Posted on Dec 05, 2008
pineworks
  • 4041 Answers
SOURCE: Brother MFC 465CN Printer, NO YELLOW
Hi There
A good old clean out some times works do this 2 or 3 times.
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on May 06, 2010
SOURCE: Waste ink tank / absorber
you need to dismantle the printer by opening the scanner lid, pinging the blue arm out of the white retainer with a screw driver, flip the scanner lid right over onto the desk on the LH side of the printer - it will come off its hinges for this. lay it lid down on the LH side of the printer - be careful not to snap the power and data cable connecting with the base. Next you have to remove the 4 retainer screws in order to remove the plastic cover over the rest of the base. The pad and ink box are at the rear on the right hand side.
Posted on Dec 06, 2009
Samyfam
  • 379 Answers
SOURCE: Brother MFC-465CN printer. Need a fix for error 46.
The problem is due to the fact that Brother machines excessively self-clean. Each time they self-clean a small amount of ink is dumped in to a holding tank/sponge. When a predefined number of self-clean operations have been performed, the machine refuses to print and gives the error message you have stated. Brother state that the tank/sponge must be replaced before the counter is reset, again by a Brother agent.
However, there is a way of reseting the self-clean counter yourself - if you Google your model number and the error code somewhere in the results you'll find how to do it. The only risk of doing this without changing the tank/sponge is that it will eventually overflow and leak out the bottom, but I did my Brother all in one some time ago and have had no problems yet.
Posted on Jul 12, 2010
  • 700 Answers
SOURCE: error 46,the ink absorber pad is full.
first, try to establish if this really is full absorbent pad, remove power cable from the back, wait 20sec, press menu/set key, insert power mains - in most brother printer/faxes this will display machine error code. if this is code 46, you are on the money, your absorbent pad is full (not necessarily, only counter is showing it as such in most cases).
we will asssume that counter is showing full and therefore reset it again to zero:
1. after machine code is displayed, key in "80",
2. go down with arrow key till you find "purge counter"
3. type "2783" this should set counter to "0"
4. press "stop/exit"
5. press "9" twice
6. remove cartridges from craddle
7. remove power cord
8. insert power cord back
9. switch on printer
10. insert cartridges back
if that do not work, then maybe really you need to replace absorbent sponge... it is done under warranty and if not technician in service centre.
if you want to do it yourself, remove cartridges, remove fron cover and on the right hand you will have "offending" sponge. either clean it (absorbent, lint free tissue is fine to remove excess first, then few drop of water and repeat draining process with tissue several time, at least till "cake" from the top is removed. best of course will be to replace the sponge with new one.
after that you still need to reset counter. in another way - follow steps...
Posted on Jul 29, 2010
Testimonial: "Thank you! I was able to reset the counter, and print again. You were very helpful!"
Brother MCF-J4710DW says ink absorber almost full and won't print? Never heard of ink absorber. Where can I purchase replacement and how do I do it
Many ink-jet printers have a pad in the case to absorb the ink from cleaning cycles. Often these show "full" long before they are actually full, and you can reset the counter and continue using them. I found your answer here:
How To Reset Purge Counter on brother mfc j4710dw
Nov 02, 2014 | Brother MFC-J4710DW 35ppm 6000 x 1200 dpi...
Brother DCP-J4110DW. Why is the ink absorber full?
The ink absorber box or flushing box is nearly full. These components are periodic maintenance items that may require replacement after a period of time to ensure optimum performance from your Brother machine. Because these components are periodic maintenance items, the replacement is not covered under the warranty. The need to replace these items and the time period before replacement is dependent on the number of purges and flushes required to clean the ink system. These boxes acquire amounts of ink during the different purging and flushing operations. The number of times a machine purges and flushes for cleaning varies depending on different situations. For example, frequently powering the machine on and off will cause numerous cleaning cycles since the machine automatically cleans upon power up. The use of non-Brother ink may cause frequent cleanings because non-Brother ink could cause poor print quality which is resolved by cleaning. The more cleaning the machine requires the faster these boxes will fill up. http://support.brother.com/g/b/faqlist.aspx?c=as_ot&lang=en&prod=dcpj4110dw_eu_as&tabid=2
Feb 16, 2014 | Brother DCPJ125 All-In-One Inkjet Printer
How to solve ink absorber full brother mfc-j6910dw
You cannot change the ink absorbers as the machine requires a full strip down as they are located in the base. You will have to give it to a dealer for repair.
Jan 30, 2014 | Brother MFC J6910DW - Multifunction fax /...
Ink absorber full brothers
Sir/Madam
The ink absorber box or flushing box is full. These components are periodic maintenance items that may require replacement after a period of time to ensure optimum performance from your Brother machine. The need to replace these items and the time period before replacement is dependent on the number of purges and flushes required to clean the ink system. These boxes acquire amounts of ink during the different purging and flushing operations. The number of times a machine purges and flushes for cleaning varies depending on different situations. For example, frequently powering the machine on and off will cause numerous cleaning cycles since the machine automatically cleans upon power up. The use of non-Brother ink may cause frequent cleanings because non-Brother ink could cause poor print quality which is resolved by cleaning. The more cleaning the machine requires the faster these boxes will fill up.
The ink absorber box or flushing box will need to be replaced.
Other reasons for cleaning are:
  1. Machine automatically cleans after clearing a printer jam.
  2. Machine automatically cleans after sitting idle for more than 45 days (infrequent use).
In Case Your Not Able To Clear Your Problem Then Go to Official Brother Printer Website: http://welcome.solutions.brother.com/BSC/public/as/hk/en/faq/faq/000000/002700/000051/faq002751_000.html?reg=as&c=hk&lang=en&prod=mfcj6710dw_all
Or
Still Having problem Then Follow Us For On:Brother Printer Support
Jan 23, 2014 | Brother MFC J220 Multifunction Printer
Error Message- Ink Absorver Full-MFC-J415W"
Sir/Madam
Your Brother Printer Machine automatically cleans after clearing a printer jam.And Brother Printer Machine automatically cleans after sitting idle for more than 45 days (infrequent use).
To solve the problem:
The ink absorbed box or flushing box will need to be replaced.
In Case You Still Need Online Help For Brother Printer,Then I Suggest You Follow Us For Brother Printer Support
Dec 20, 2012 | Brother Ink for Mfc J415w Printer
The ink absorber near full Problem with my brother dcp j125 printer
DCP j125 Inkjet printer stopped printing showing msg. ink absorber is full. What to do?
Aug 10, 2011 | Brother DCPJ125 All-In-One Inkjet Printer
Waste ink absorber
Its not a big prob and u will have to take it in as the m/c needs to be striped down for replacement!
Apr 15, 2010 | Canon PIXMA iP90v Printer
PIXMA IP1800 INK ASBORBER IS ALMOST FULL . WHAT DO I DO TO SAVE THE PRINTER.
When the ink absorber gets full you need to take the printer to the shop. The printer has to be completely taken apart to replace the absorber which covers the whole bottom of the machine. After that you need to get to the diagnostic mode which only Canon techs can do, and reset the absorber counts. In my shop the repair runs around $80.00
Jul 02, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
WASTE INK ABSORBA FULL
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink tank full" error.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you. Once they are replaced, it'll be functional again.
May 23, 2009 | Canon Office Equipment & Supplies
Waste ink absorber
hi i am a certiffied Canon repair tech for this model. this is true this will reset the error but doing so without replacing the waste asorber pad in the bottom of the machine will cause your machine to backup waste ink into the the printing area of the machine and will start smuging ink on the page. the waste absorber is fairly cheap but the labor varies from shop to shop. there are independent Canon repair shops throughout the world. you can call 1-800-ok- canon or look on the canon website. hope this help to clairify.
Dec 22, 2007 | Canon PIXMA iP2000 InkJet Printer
Brother MFC 240C All-In-One InkJet Printer Logo
954 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
