Need lense on front of projector
No image on wall
    President:
  • 412 Answers
You didn't say what Model of Kodak projector you need a lens for. Kodak projection lenses are still available from: www.vinevalleyimaging.com
Good Luck !!! Jim.
Posted on Jan 21, 2015
When I turn on projector,image on screen is backwards. How can I fix that.
Look in the setup to see where you select from rear projection to front projection.
Mar 11, 2016 | Office Equipment & Supplies
Powerlite 420 image upside down. How do I turn it around?
you will need to change the projection mode in order to flip the image:
Turn on the projector and display an image
hold down the A/V Mute button on the remote control for 5 seconds (whilst it is pointing at projector). Image will disappear then reappear flipped.
To change back, repeat this process
Nov 24, 2014 | Epson V11H348020 - PowerLite 4200W...
Reverse image
Find the switch for front projection/rear projection and set it to front!
Nov 25, 2011 | Lenovo M500 DLP Projector
How to write on wall with some image or photo?
If I understand correctly you want to project an image on the wall.
If this is correct, then open following links to Texas Art Supply:
http://www.texasart.com/tools/light-boxes-and-projectors/projectors/artograph-tracer-projector.html
http://www.texasart.com/tools/light-boxes-and-projectors/projectors/artograph-prism-image-projectors.html
http://www.texasart.com/search/index.cfm?searchstring=projector&store=ALL&x=22&y=13
How it works.
Place image on table.
Put projector over top of image.
Turn on projector, and image is projected to wall or piece of paper hanging on wall.
Trace image or paint directly on the surface.
Feb 12, 2011 | Cycling
My unit seems to work fine, except there is a dark shadow covering the right third of the projected image. Is this a sign that the bulb is going out?
this is the light tunnel needing to be adjusted or replaced because is has collasped due to the heat given off by the lamp during the life of the projector.
Aug 27, 2010 | InFocus ScreenPlay 4805 Multimedia...
My dell projector image is at an angle not striaght
hi,
Check it's lense angle & take it in correct angle OR check setings of its angle.
Sep 22, 2009 | Sanyo PLC XU35 Multimedia Projector
Image problem
IF I understand the problem from the limited info in your question, the problem is a distorted picture on whatever surface [probably a wall, or screen] onto which the image is projected.
With all lenses, the axis [centerline of the lens projected] MUST be absolutely PERPENDICULAR [in both the vertical and horizontal planes] to the perfectly plane [flat] surface onto which the image is projected.
IF for example, the projector is mounted in a rear corner of the room, and the camera is aimed downward and to one side to project the image on the center of the opposite wall, or a screen located there, the image will be distorted. It will be larger on one edge [fartherist from the lens] and smaller on the opposite [nearest] edge.
If it is non-perpendicular in only one axis, then two opposite edges will be different lengths, and if out of perpendicular in two axis then no edges will be the same length.
The solution to this problem is that the center axis of the lens must be perpendicular to the surface projected on, in both vertical and horizontal axis.
Feb 14, 2009 | Sharp BQC-XGE630U/1 Projector Lamp for...
Getting image to project
You are going to have to read the manual, and operate the projector as you read each section
Oct 16, 2007 | Sony VPL CS2 Multimedia Projector
Projector turns off after 30 seconds.
I had the same problem I replaced the motor/lense cover unit at the cost of $AU140.00 and that fixed it.
Leckie
Oct 09, 2006 | Sony VPL CX5 Multimedia Projector
73 people viewed this question
k24674
jasbo
jasbo
